Software Archive
Read-only legacy content
17060 Discussions
Change theme of a template in xdk
Youssef_A_
I have created a new xdk project based on the listview template. But I want to change the theme of this template. Is this possible? And how do I do that?
PaulF_IntelCorp
Replace the CSS with whatever you want. You would likely want to remove the App Framework libraries and use whatever you want. Or, find another HTML5 list example and create a new app based on that.
Youssef_A_
Hi Paul, thank you for your answer. For example I have used the login template and I see just one css afui.ui.css. If I want to change this to framewrok7 look and feel, which of the css sheets should I replace? I mean framework 7 has more then 1 stylesheet.
PaulF_IntelCorp
Youssef -- we don't have the resources to help you learn how to apply CSS and other standard HTML5 resources. Your best bet is to search resources like W3C Schools, HTML5 Rocks, etc. We're here to help you get through the logistics of building and debugging your app.
Youssef_A_
Hi Paul, I know how css works. I thought XDK has a simple way for switching themes in existing templates. But thank you for your effort.
PaulF_IntelCorp
Youssef -- sorry, but there is no such mechanism available.
