I am configuring a number of workstations that use the D955XBK motherboard. Given the power consumed by the graphics card, disks and processor the chassis heat management is a must. I've installed the external temperature sensor and fans that should do the job, however I cannot seem to find any technical information on how to setup or control the fans. I plan ot write an application to manage the chassis heat and need some technical info.
Mike
mjwestkamper@weiinc.com
Mike
Hello Mike,
Thank you for posting your question on theIntel Software NetworkMessageBoard. While this forum is used primarily for software related issues, you can find technical documentation on the D955XBK motherboard at http://www.intel.com/cd/channel/reseller/asmo-na/eng/products/desktop/bdb/d955xbk/tech/index.htm. If you need additional information, there is a support link on that page to the Intel Customer Support site.
I hope this gives you the information you need to help you resolve your problem.
Jim A.
IntelSoftware NetworkSupport
http://www.intel.com/software
Contact us
Topic Options
