Software Archive
Read-only legacy content
17060 Discussions
Clean up the intel xdk Develop coding
Muhammad_Y_Efendi
Does anyone know how to clean up Develop javascript coding?
Sometime my javascript is not clean very well, and I need to clean it up to get better understanding.
PaulF_IntelCorp
Use a beautify tool for JavaScript. There are many out there, that can be added as extensions or plugins to your editor or run directly at the command-line. If you're using the XDK, there is a beautify plugin that can be added to the built-in Brackets editor. Just click the "lego block" icon near the upper right of the edit window and search for "beautify" in the dialog box that appears.
PaulF_IntelCorp
Muhammad_Y_Efendi
Wow, perfect!!
Thanks, Paul
