Software Archive
Read-only legacy content
17061 Discussions
cannot activate Intel Fortran compiler via network license manager
hiroshi_k_
I'm failing to install and activate Intel Fortran compiler on CentOS7 via network license manager. When activation, select "2. Use Intel(R) Software License Manager" and enter correct ip and port number of the license server. After that, no response from the installer over few hours. so I need to give up the activation. The client Linux is located in AWS. The license server is in company office. I verified that port 28518 is open in packet level. Are there any things should I do? Client : CentOS7 on AWS License Server : Window 2008 Server in local Application : Intel Parallel studio xe 2016 composer edition for fortran
Light_Intel
Thank you for contacting Intel Support.
This issue is being handled via IPS. To avoid duplication I am closing this issue.
Noga
Intel Developer Support
