Software Archive
Read-only legacy content
17060 Discussions
Code Coverage in Parallel Composer
qnphan
Recently noticed that this Code Coverage feature option in the Composer
I tried it out using a working build by turned on the Code coverage feature and rebuild the project afresh.
the build failed and got the following error msg:
1>C:\\Program Files (x86)\\MSBuild\\Microsoft.Cpp\\v4.0\\Platforms\\Win32\\PlatformToolsets\\Intel Parallel Composer 2011\\Microsoft.Cpp.Win32.Intel Parallel Composer 2011.targets(196,5): error MSB6001: Invalid command line switch for "icl.exe". Parameter "path" cannot have zero length.
any suggestion to resolve it?
Is there a Code Coverage report page that can be shared? A link would help!thanks.
Brandon_H_Intel
So this project builds ok with the Intel compiler without code coverage activated? What compiler version are you using (update 1, update 2?)
qnphan
One clarification, the project buildssuccessfully with MS Visual Studio.
I went back to build the project with Intel C++, with Code Coverage feature disabled, it has the same error message!
In summary, this message shows up when using Intel Composer (update 1) with or without Code Coverage option enable.
qnphan
Lingfeng_C_Intel
This is MS Build issue related to Intel C++ compiler platform toolsets property.
For MSBuild tool, please visit below URL for more details, http://msdn.microsoft.com/en-us/library/ms171452.aspx
You can reinstall your XE version again to see if this issue is still exist or not.
Wise
Lingfeng_C_Intel
Please follow up below way to try it again:
For some reasons the paths to Intel C++ compiler headers and libraries are not registered automatically in C++ projects. I put $(ICInstallDir)\compiler\include\ and $(ICInstallDir)\compiler\lib\ia32\ as first items in "Include directories" and "Library directories" options in the Configuration properties -> VC++ Directories dialog.
I believe this is a bug in VS integration.
qnphan
I added those two paths to the directories, respectively but the issue still persisted with number of clean and rebuild.
fyi, i just reinstalled the latest Parallel Studio (PS 2011, composer wit update 3) few days ago. The issue isstill there. TIA
qnphan
qnphan
Hi Intel staff,
Sounds like you are aware of such issue associated with the Intel composer.
Any update or suggestion to uphold the code coverage feature in Composer?
