Software Archive
Read-only legacy content
17060 Discussions
How to get the elapsed time of each function in Amplifier?
paul_shu
I notice that the elapsed time of each function is not shown in the Bottom-up or Top-down Tree windows. I just can get the elapsed time of entire application on the summary panel. But I really want to know whether Amplifier does support this feature or not? If yes, how I can get these info?
Peter_W_Intel
You can't use Bottom-up report to know total time of function (elapsed time) since that is only for self-time.
You can useTop-down treeto know "CPU Time:Total" forany function, even its self time is zero. It showed as percentage value, you get seconds by using: Elapsed time (from summary panel) * ??%
Regards, Peter
paul_shu
Hi Peter,
Thanks for your reply.
But CPU time of a function is not the real elapsed time of this function. For example, a function is divided to two threads to run tasks. I can get: CPU time of this function = CPU Time of Thread1 + CPU Time of Thread2. But this CPU time of this function is not the real elapsed time of this function. Right?
Kind Regards,
Paul
Peter_W_Intel
Hi Paul,
There is no EXACT elapsed time of the function. For example, functionA and function B may be overlapped in real time, running inmultiple threads (cores), so what I talked is total CPU time.
Summary panel has "elapsed time" - it is real execution time, parallelled from multi-cores.
Regards, Peter
paul_shu
Hi Peter,
OK, I got it.
I am appreciate your help.
Paul
