hola cree un archivo de texto y lo grabe a traves de mi aplicacion en el directorio Dcim/Camera.
ahora quiero ller los archivos que se encuentran en ese directorio, por leer me refiero a listar el nombre de los archivos.
encontre una aplicacion que supuestamente hace eso pero el codigo no funciona , aqui esta
Read Contents of a File
Using FileEntry object we can read contents of a file. In the above code we saw how to get FileEntry object using DirectoryEntry object.
Here is the code to read content of the file we created
function onDeviceReady()
requestFileSystem(LocalFileSystem.PERSISTENT, 0, onSuccess,onError);
function onSuccess(fileSystem)
var directoryEntry = fileSystem.root;
directoryEntry.getFile("readme.txt", {create: true,exclusive: false}, function(fileEntry){
//lets read the content of the file.
fileEntry.file(function(file){
//FileReader object streams the content of the file from storage disk to app
var reader = new FileReader();
reader.onloadend = function (evt) {
//result property is string type if you read data as string. If you read data as array buffer then its assigned to a array buffer object.
console.log(evt.target.result);
//to read the content as binary use readAsArrayBuffer function.
reader.readAsText(file);
}, function(error){
console.log("Error occurred while readline file. Error code is: " + error.code);
}, function(error){
console.log("Error occurred while getting a pointer to file. Error code is: " + error.code);
function onError(evt)
console.log("Error occurred during request to file system pointer. Error code is: " + evt.code);
si aguien me puede ayuda de lo agradeceria, el plugins File esa agregado a mi app
saludos
- Tags:
- HTML5
- Intel® XDK
I recommend you look at the following pages for help:
- https://www.neontribe.co.uk/cordova-file-plugin-examples/
- https://www.raymondcamden.com/2014/07/15/Cordova-Sample-Reading-a-text-file/
- https://www.raymondcamden.com/2014/11/05/Cordova-Example-Writing-to-a-file/
- http://www.html5rocks.com/en/tutorials/file/filesystem/
Mr. Raymond Camden has been involved in the Cordova and PhoneGap projects for a very long time and is very accomplished in the art of creating Cordova apps. His blogs contain very useful information.
thankyou but the example on the web no work for me
I don't know why
