Software Archive
Read-only legacy content
Compiling issue for Windows Phone
Marcondes__Marcos
Trying to compile windows phone but failing
Sending images with issue
Thanks for any help
Marcos
Swati_S_Intel1
Marcos, there was a bug in the build system and has been fixed. You should be able to build fine now.
PaulF_IntelCorp
Your Windows Phone ID is incorrect, but I don't think that is the fundamental source of the problem. See this image for an example of what the two publisher IDs look like in your Windows developer dashboard settings:
I think the real reason for the build failure is your App ID, it starts with "CON" -- here's the image from your build failure. Note the red text below it and the list of disallowed names. This is a Cordova problem that we are working on resolving, for now, it creates a limitation on the App ID:
BTW -- use CLI 5.1.1 for your Windows builds, not CLI 4.1.2.
Marcondes__Marcos
My problem my app contains my website name www.CONteudoanimal.com.br
Why this limitation ??? How many app not creating  based on this limitation
I wish best to the team to solve this asap
thx
Marcos
PaulF_IntelCorp
I don't think we can fix this. Notice that the list of restrictions is exactly the standard names for Windows devices, so I think this is actually a Microsoft limitation. See this doc page, notice that con is a restriction from Microsoft: https://msdn.microsoft.com/en-us/library/windows/apps/br211441.aspx
The App ID is not something your users will see, it is strictly used by the Windows store to uniquely identify your app. The TITLE of your app is what your users will see.
PaulF_IntelCorp
The build engineers are looking into this to determine precisely if this is something that can be fixed or if it is a Microsoft limitation.
Marcondes__Marcos
What absurd .... How microsoft permits create reserve my name with con string .... but limit use it on appid .... what the hell
Absurd
Frustrated about
Marcos
www.conteudoanimal.com.br
Marcondes__Marcos
Hello
Any idea to by pass this issue
Because I feel no idea ... absurd
PaulF_IntelCorp
Marcos, no way to get around this, right now, other than changing the names in your app. As I said, engineering is looking into the issue and, if the fault is our build system, will fix it.
Swati_S_Intel1
Marcondes__Marcos
Swati ... this is correct ... I tried again and worked fine !!!
