Software Archive
Read-only legacy content
17060 Discussions
Configuring Edison Arduino Pins for Analog input Ai0
Manish_P_
I am running an Intel edison arduino board with Yocto, edison updated to libmraa 0.6.0.
When I try to set up for analog in, I get the error message below.
# echo 214 > /sys/class/gpio/export
sh: write error: No such device
(e.g. as in page 28/section 11.5 of  http://download.intel.com/support/edison/sb/edisonarduino_hg_331191007.pdf)
 I have a 12V 2A supply connected to the system. I have rebooted the board, but the error persists.
Any suggestions on how to fix this problem?
Manish_P_
Intel, any solutions to this problem?
rzr
Isnt GPIO 214 already exported ?
can you try to reboot and just ls  /sys/class/gpio/ ?
NagaVenkat_K_Intel
Yes as rzr says try reboot the board and check if gpio214 is already exported by using command ls  /sys/class/gpio/.
If it is not found then try to export and # echo 214 > /sys/class/gpio/export and check the result.
