Software Archive
Read-only legacy content
17060 Discussions
CANNOT insatalll HAXm ...problem with XD bit plz help!!
Shailang_K_
 I tried to check my BIOS to enable .disable XD or VT but there is no settings ...
I have tried for so long to install Haxm but FAILED ..so plz help me find out whats the problem ...
i attached the screen shot with cpuID.
thanks .
Colleen_C_Intel
Your CPU supports both the necessary capabilities - see http://ark.intel.com/products/43529/Intel-Core-i3-350M-Processor-3M-Cache-2_26-GHz?q=i3-350M.  So if you have enabled virtualization, I would use this command to be sure the XD/NX bit.
bcdedit /set nx AlwaysOn
Shailang_K_
iv done tht and its ON , i check it using bcdedit in cmd ...but i still cannot install it ..
Colleen_C_Intel
what message are you getting
Shailang_K_
the same problem ..."this computer does not suport XD bit or is disabled in BIOS..HAXM cannot be installed..
Constantin_G_Intel
Hi
Please run this command "wmic OS Get DataExecutionPrevention_Driver"s from a terminal run with administrator privilege and write here what it returns and what computer model exactly you have.
Constantin
Shailang_K_
the output is False for data execution prevention drivers
my laptop is acerAspire 5745
Does this meant that XD bit is not suported?
Constantin_G_Intel
For more information check the website http://support.microsoft.com/kb/912923
Seems the DEP(XD) is disabled in your OS
Shailang_K_
I just dont understand , i check my BIOS and there is no option to enable XD but i check from the intel website for my model spec and it suport XD .
How do i enabled it ?
I tried wmic OS Get DataExecutionPrevention_Driver=Flase
also checked DataExecutionPrevention_Available=False, and my model supports XD...im confused.
Constantin_G_Intel
Please contact your laptop manufacturer on how to enable XD in bios since there is no such option.
Colleen_C_Intel
What message did you get when as ADMIN you ran bcdedit /set nx AlwaysOn  from the command line.?
