after successfully building our App (Intel XDK 3240 / Cordova CLI 5.4.1) we uploaded it to iTunes Connect for Review. The review was denied and apple states that it doesn´t run on iOS 9.3.1 (the newest). When testing the App ourselves on a Device with iOS 9.3.1 via Testflight it didn´t work either. Unlike Apple´s description, the app actually started up and showed the Screen it should, but interacting with functions and buttons doesn´t work at all. So basically the screen is frozen on startup.
The app is very simple and doesn´t use many plugins at all. After all the build with intel xdk finishes successfully. I would like to know, if anyone else is experiencing similar problems?
Thanks in advance
- Tags:
- HTML5
- Intel® XDK
We have not heard any such reports. What happens if you take the "hello cordova" sample app and do the same with it? Also, if you build and "share" the link via email to your device and use the OTA install link in that email to install on the device, do you get the same results?
Thank you, the sample app works. So basically xdk is not the problem...gonna continue searching the error in our app.
