Anything happening with the cordova android builds? I'm getting failures while iOS is building successfully.
- Tags:
- HTML5
- Intel® XDK
Are you still having trouble building for Android? There has been an issue when you build for Crosswalk and then follow-up with building for Android that sometimes your Android build will fail. I believe that should have been fixed today, but have not heard if the fix made it into our production build system, yet.
still having issue with builds
I haven't built any crosswalk builds for a few months now, just android cordova
also to note, I'm on the latest intel xdk 2323 (and again, the ios builds are fine)
Update: Cordova Android builds are building fine for me now
Note: The issue might not have stemmed from Intel XDK afterall, I have a plugin "de.appplant.cordova.plugin.email-composer" that *might* have been causing builds to fail.
3rd party plugins can cause builds to fail depending on the particular plugin. If you are having issues, the best way to track it down is to remove 3rd party plugins, then build, then add them back in one at a time until you find the offending plugin.
