My application does not build in Intel XDK after I upgraded my xdk to 2170. Build engine does not create error log file. It just returns Verify your build assets. I tried many things, I changed my CLI to 4.5 , I removed all spaced in project assets. But It always returns the same error.
Pls help
- Tags:
- HTML5
- Intel® XDK
Can you build the blank template?
Are you trying to build for Android, Crosswalk, iOS, other?
Can you provide a screenshot of the build error?
Hello Haluk K,
I had a similar problem with all my old projects.
Tried many different options in an attempt to use a project that has been upgraded. Nothing worked for me. Based on Paul F suggestion I started a new project using the blank template. I then populated the project with my source code (html, css, and js) from my old project.
The project built just fine.
It was a little annoying at first that I had to start a new project. So I tried even more ways to make a standard upgraded project work. Eventually I gave up totally. Now it takes my 5 minutes to start a new project, transfer source, and re-assign all the graphics. Honestly it is the graphics that's the biggest time in the process. Just clicking away until the icons and splash screens are re-assigned.
If you have project deadlines, I suggest you backup the existing project, make a new project and copy in the source files. Hopefully this will work for you just a well as it did for me.
By the way, if you ever figure out what the glitch is with an upgraded project, I'd be curious.
@haluk -- can you provide me with a ZIP file of your entire project? We can take a closer look at it to determine if something failed during the upgrade. You can send me a private message (using the "Send Author a Message" link on THIS POST) and attach the ZIP there or provide a link to a ZIP that I can download via DropBox, Google Drive, etc.
