Software Archive
Read-only legacy content
Cordova geolocation Android
Gerald_C_
Hi everyone,
I'm having an issue with Cordova's Geolocation plugin on Android devices (and the emulator too).
First off the plugin works fine on the iphone emulator but when I try to get my location using the code:
var suc = function(p){
        if (p.coords.latitude != undefined)
            if(!is_requesting)
                findEvents(p.coords.latitude, p.coords.longitude, isForMap);
    var fail = function(errorObj){
        alert("geolocation failed");
    var options = {
        maximumAge: 90000,
        timeout: 50000,
        enableHighAccuracy: true
    navigator.geolocation.getCurrentPosition(suc,fail,options);
On Android this just times out and give me the error object message:
"Timeout expired"
I've tried setting enableHighAccuracy to true (and false) but neither seems to fix my problem.
Any help on this would be greatly appreciated!!!
Many thanks!
Anusha_M_Intel1
Please take a look at Question 21 on the this FAQs page and see if it is of help to you: https://software.intel.com/en-us/xdk/faqs/cordova
Q21: How do I resolve Geolocation issues with Cordova [Plugin]
John_H_Intel2
Did you enable to Cordova geolocation plugin?
Gerald_C_
Yes I enabled the geolocation plugin as the plugin works fine on iPhone emulators....
Only on the android emulators and phones, I am unable to get a geolocation...
Anusha_M_Intel1
Gerald_C_
Thanks Anusha!
Weirdly enough, when I actually built the app and installed it on my phone (so not using the emulator) the app was able to retrieve a GPS coordinate so I think that possibly the plugin may not work on the emulator!
Thanks again tho, that FAQ looks really useful!
Anusha_M_Intel1
I am glad it worked out for you and Thank You for your support!
