Software Archive
Read-only legacy content
17060 Discussions
Could not generate debug module after add plugin pushwoosh
Maurizio_B_1
Hi all,
On debug tab, after I add the plugin com.pushwoosh.plugins.pushwoosh 3.6.13, I obtain this error
Debug Module Error
  • The App ID is "com.intel.appx.FOW.xwalk15"
  • The App Name is "AP Debug x15 FOW"
  • Application will be signed.
  • Plugin "cordova-plugin-dialogs" (1.1.1) installed.
  • Plugin "cordova-plugin-screen-orientation" (1.4.0) installed.
  • Plugin "cordova-plugin-device" (1.0.1) installed.
  • Plugin "cordova-plugin-inappbrowser" (1.0.1) installed.
  • Plugin "cordova-plugin-file" (2.1.0) installed.
  • Plugin "cordova-plugin-file-transfer" (1.2.1) installed.
  • Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
  • Plugin "com.intel.xdk.ppfa" (1.0) installed.
How i can solve this? How I can find a debug log?
Thx
Maurizio
Dale_S_Intel
This is a bit of a known issue at the moment.  I'm given to understand that if you set it up as a third-party plugin, it should work.  Just go to the projects page choose Plugin Management->Add Plugins to this Project->Third-Party Plugins, choose "Cordovoa plugin registry" and use the plugin id “pushwoosh-pgb-plugin”.
I was able to build a debug module that way, so please give it a try and let us know if that fixes it for you or not.
Note, I didn't specify the version, just relied on it to use the latest version.
Dale
Maurizio_B_1
Thanks Dale,
It works great for me!!
