Hi all,
On debug tab, after I add the plugin com.pushwoosh.plugins.pushwoosh 3.6.13, I obtain this error
Debug Module Error
- The App ID is "com.intel.appx.FOW.xwalk15"
- The App Name is "AP Debug x15 FOW"
- Application will be signed.
- Plugin "cordova-plugin-dialogs" (1.1.1) installed.
- Plugin "cordova-plugin-screen-orientation" (1.4.0) installed.
- Plugin "cordova-plugin-device" (1.0.1) installed.
- Plugin "cordova-plugin-inappbrowser" (1.0.1) installed.
- Plugin "cordova-plugin-file" (2.1.0) installed.
- Plugin "cordova-plugin-file-transfer" (1.2.1) installed.
- Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
- Plugin "com.intel.xdk.ppfa" (1.0) installed.
How i can solve this? How I can find a debug log?
Thx
Maurizio
- Tags:
- HTML5
- Intel® XDK
This is a bit of a known issue at the moment. I'm given to understand that if you set it up as a third-party plugin, it should work. Just go to the projects page choose Plugin Management->Add Plugins to this Project->Third-Party Plugins, choose "Cordovoa plugin registry" and use the plugin id “pushwoosh-pgb-plugin”.
I was able to build a debug module that way, so please give it a try and let us know if that fixes it for you or not.
Note, I didn't specify the version, just relied on it to use the latest version.
Dale
Thanks Dale,
It works great for me!!
