Software Archive
Read-only legacy content
Crasswalk fail with Facebook connect + PushPlugin
gabry_p_
I've been trying to use Facebook Connect and PhoneGap push plugin but the combination creates some problems.
I'm using 2496, creating new blank cordova project (default setting, CLI5.1.1) and trying to build with Crosswalk.
I add the last version of facebook connect from "Featured plugin", then include the push plugin as a third party on local and upload successfully. Then when I click build, IntelXDK give me a build fail with the attached report.
Some other times instead it crashes, and when it does then I've to create a new project.
After failing the build I have to create a new project, unless it will fail even removing all the plugins.
Tried unsuccessfully to:
Uninstall/reinstall
Use different version of both (tried 4 combinations)
Download and import locally them
C
reate different projects
Amrita_C_Intel
I have escalated this issue. I will keep you posted.
gabry_p_
I guess it is related to this
