Software Archive
Read-only legacy content
17061 Discusiones
Crosswalk 14 Embedded Now Available
PaulF_IntelCorp
Empleados
1.488 Vistas
You can now build "embedded" Crosswalk 14 apps with the Intel_XDK for Chrome 43 webviews on Android 4.x and higher devices. See Why Use Crosswalk? for why Crosswalk matters on Android devices.
You select Crosswalk 14 by selecting the pulldown in the Build Settings section of the Projects tab. This version is only selectable by using version 2170 or greater of the Intel XDK.
0 kudos
9 Respuestas
Hamilton_Tenório_da_
Colaborador Valioso I
1.488 Vistas
Great news! I will try now.
1.488 Vistas
I am using the XDK version 2170, but the Crosswalk 14 dos not appears yet. Do I need to do anything?
PaulF_IntelCorp
Empleados
1.488 Vistas
You do not need to do anything special. You have to be online, "embedded" needs to be selected and 14 should show up in the list of available Crosswalk build versions, as shown in the picture in the previous post. I just double-checked and I see 14 in my list.
1.488 Vistas
Uhn... not for me.
I am using version 2170 (Windows 8.1) --> see image 1
Options for Crosswalk: only 7, 10, 11, 12 --> see image 2
PaulF_IntelCorp
Empleados
1.488 Vistas
You may have to exit and restart the XDK, because I believe it only reads the "feed" that supplies those numbers when it starts. If that doesn't work, here's a workaround:
  • select "12" in the pulldown
  • add the following two lines to your intelxdk.config.additions.xml file
<!-- -Android-Crosswalk --><intelxdk:crosswalk version="12"/>
<!-- +Android-Crosswalk --><intelxdk:crosswalk version="14"/>
1.488 Vistas
That´s it (logout/login). Now the version 14 is present. I´ll test now. Thank you.
PaulF_IntelCorp
Empleados
1.488 Vistas
@Test -- you're not giving us much to go on. Can you be more explicit about what failed?
Hector_n_
Principiante
1.488 Vistas
My app crash when I press volume buttons.
PaulF_IntelCorp
Empleados
1.488 Vistas
@Hector, can you provide a simple example app that causes this failure and attach it to a post to this thread. Please ZIP the entire project directory.
Responder
