- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I've had the developer kit camera for a week now, and have attempted installation on several machines, running both windows 8.1 and windows 10.
On every machine I try, I can not install the current DCM - it fails with an error of -4, and suggests that the firmware may be corrupted and I should contact my provider for instructions on how to recover. (That would be Intel?). I am able to install the previous version of the DCM, and have been able to run some of the SDK samples, but I can not get the current DCM to work. All machines are haswell, USB3, both desktop and laptop. Thoughts?
- Balises:
- Intel® RealSense™ Technology
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi, I have now the same problem.
I had installed F200 with DCM1.4 in OS 8.1Pro. The image device in the device manager showned me all 3 devices (Virtual Driver/RGB/Depth). By end of installation DCM there comes a message from a known problem Hotfix.
I upgraded to Win10Pro and there I saw only the virtual Driver. By opening properties there is the message: the device "Root\image\0000" was deleted. I deinstalled the USB device RealSense F200 and installed the DCM once more.
The end: init failed code -4
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Please send in the logs from C:\Users\<loginname>\AppData\Local\Temp\micl_tmp_<loginname>\
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I have tried with all versions of DCM, from 1.2.14.24922 to 1.4.27.41944, all are giving the same error -4 (error during firmware update).
I am using Window 10
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Still having the same problem all was ok until updating to a version that forces us to update the firmware
I totally gave up on this on my previous computer on the assumption that something might have been wrong with
my computer today on a totally new system more powerful than the previous one I ran into the same problem,
here are my logs from today's brief try with 1.4
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I have the same problem.
Please tell me how to slove it .
Thank you.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
