Software Archive
Read-only legacy content
17060 Discussions
DO NOT put plugins in WWW folder or use intelxdk.config.additions.xml file for plugins
PaulF_IntelCorp
With the latest release of the Intel XDK (2496 and above) you should no longer be putting plugins inside the "source directory" (typically named "www") in your project directory AND you should no longer be referencing plugins via the intelxdk.config.additions.xml file. While this practice works with prior versions of the Intel XDK, it will cause problems with the current and future versions of the Intel XDK.
This change in policy is due to a significant change in the way the Intel XDK handles Cordova plugins. Unfortunately, the project upgrade process does not always detect all of these plugin references (especially plugins that are referenced via the intelxdk.config.additions.xml file) and may fail to include them in the Plugin Management section of the Projects tab.
For more information, please read this post: https://software.intel.com/en-us/forums/intel-xdk/topic/594986
p.s. The build system will still attempt to pull in plugins that are referenced in the intelxdk.config.additions.xml file, which can cause conflicts with plugins you have added via the plugin manager.
p.p.s. We are aware that many older forum posts (and a few doc pages that need to be updated) may recommend using the intelxdk.config.additions.xml file for referencing plugins, that was appropriate with older versions of the Intel XDK but is no more. We are working on updates to the documentation to minimize any confusion.
Alon_I_
just to add that in both cases i was using the latest version of xdk
Pamela_H_Intel
Alon,
I am not sure what you are referring to. Did you intend this post to be on a different thread? Shall I remove it from here?
Pamela
