Software Archive
Read-only legacy content
Debug Module Error
xxx_x_
Could not gererate debug module
Debug Module Error
  • The App ID is "com.intel.appx.gobaby.xwalk10"
  • The App Name is "AP Debug x10 gobaby"
  • Application will be signed.
  • Plugin "org.apache.cordova.device" (0.2.9) installed.
  • Plugin "org.apache.cordova.splashscreen" (0.3.0) installed.
  • Plugin "org.apache.cordova.camera" (0.2.9) installed.
  • Plugin "org.apache.cordova.file" (1.3.3) installed.
  • Plugin "cordova-plugin-geolocation" (1.0.1) installed.
  • Plugin "com.intel.xdk.ppfa" (1.0) installed.
Matthew_G_6
I am having a similar issue +1
PaulF_IntelCorp
There may be a build issue, not sure. In the meantime, as a workaround, try switching your Crosswalk Runtime build settings to use the "shared" mode library, this may work better. In the Build Settings section of the Projects tab, on the Android-Crosswalk tab:
PaulF_IntelCorp
Another option to try is switching to CLI 4.1.2 rather than CLI 5.1.1 (or vice-versa) before building your debug module.
Shahab_L_Intel
Matthew G, what's your app id?  If you can share that we might be able to find the build log for it.
Eric_H_Intel
I am looking into the issue.
Can you do a test for me?
1 - Make a change (add and extra plugin), build again.
2 - Remove the extra plugin, build again.
Can you let me know what the results of that are?
Eric
Matthew_G_6
@Shahab - this is log I'm getting:
  • The App ID is "com.intel.appx.KendoUI.xwalk11"
  • The App Name is "AP Debug x11 KendoUI"
  • Plugin "cordova-plugin-inappbrowser" (1.0.1) installed.
  • Plugin "cordova-plugin-camera" (1.2.0) installed.
  • Plugin "com.danielcwilson.plugins.googleanalytics" (0.6.1) installed.
  • Plugin "cordova-plugin-file" (3.0.0) installed.
  • Plugin "cordova-plugin-file-transfer" (1.2.1) installed.
  • Plugin "cordova-plugin-device" (1.0.1) installed.
  • Plugin "cordova-plugin-device-motion" (1.1.1) installed.
  • Plugin "cordova-plugin-network-information" (1.0.1) installed.
  • Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
  • Plugin "cordova-plugin-statusbar" (1.0.0) installed.
  • Plugin "cordova-plugin-vibration" (1.2.0) installed.
  • Updated "package" to "com.intel.appx.KendoUI.xwalk11"
  • App name updated to [AP Debug x11 KendoUI]
  • Updated "minSdkVersion" with "14"
  • Updated "targetSdkVersion" with "19"
  • Updated "installLocation" to "auto"
  • Updated "versionCode" to "1"
  • Updated "versionName" to "0.0.1"
  • Added "debuggable" to "false"
@Eric - Adding / removing a plugin does not produce any change in result
Eric_H_Intel
Matthew G.,
The debug module is built using Crosswalk.   There is a known incompatibility with the newer version of the SplashScreen and Crosswalk.  A call "webView.canGoBack()" is not currently in the Crosswalk API.
You can revert to an older version of the SplashScreen plugin (version 0.3.5) to get around the issue.
Eric
PaulF_IntelCorp
Matthew, did you try switching to CLLI 5.1.1?
xxx_x_
I convert old project to new xdk version, then problem occurs.
My fix is to create a new project in new XDK version, then everything run.
thank everybody!
Shailesh_S_
hi
I am facing issue like :
  • Building a Cordova 5.4.1 Project Preview application with Crosswalk 18.
  • Using platform cordova-android 5.0.0.
  • The application name is "AP Debug x18 Gallery"
  • The package name is "com.intel.appx.Gallery.xwalk18"
  • Crosswalk version 18 is currently not supported in Project Preview for Applications.
Have any solution o​r suggestion
PaulF_IntelCorp
The Debug tab does not currently support building with CW18, this will be fixed with the next release. In the meantime, change your CW version in the Build Settings to CW17 and it should work.
Ronaldo_M_
I've never been able to use XDK Debug, it never worked for me. What I have done is to use Android Studio's logCat by filtering on error or info.
