- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi, I got an error code -1005 when I run the depth camera manager R200. I re-tried a couple times and the result is still the same. Would you please help me? Thanks!
Link kopiert
3 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Please check the USB 3.0 cable has good connection to both camera and computer. One developer has found the connection issue and it works after he fixed it.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi David:
I did try with another cable and it is still not working. It is strange that it is working as a webcam. I use Windows Movie Maker and I can select the RealSense as video source. Should I return it?
Wik
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Could you provide the detail info? Such as,
- Your system configuration, CPU and OS
- Are you sure you connect with USB 3.0 part?
- Provide me the screenshot of your device manager.
Thanks!
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
