Software Archive
Read-only legacy content
17060 Discussions
Dialog queries
Intel_C_Intel
I am developing a quickwin app using cvf 6.6 .
Is there any way I can make the "return" key act like a tab key within a dialog box ? At the moment I trap the "return" key (IDOK) using a dummy callback routine. Could I change the dummy routine to move forward to the next control ? Can I in fact set the focus on a given control ?
Of lesser concern, is there a way to change the text of an existing list item in a list box ? At the moment I reload the entire list box.
Bill Buchholz
Jugoslav_Dujic
Valued Contributor II
See here. You can set focus explicitly using SetFocus(GetDlgItem(Dlg%hWnd, IDC_CONTROL)) or adjust tab stops in dialog editor (Ctrl+D) and send WM_NEXTDLGCTL.
Yes, that was always possible, though docs could be a bit clearer. Use
j = DlgSet(Dlg, IDC_LIST1, "nTh Item", n)
where n is index of the item in the list.
Jugoslav
Intel_C_Intel
Thanks for your reply. The link certainly made it clear that it can be
done but I just could not get it to work. I am not sure how to set the parameters.
I had the line:
STATUS = DLGSENDCTRLMESSAGE (DLG,IDOK,WM_NEXTDLGCTL,0,0)
which returns false after executing.
IDOK is the invisible default button mentioned in the link and the
callback routine is certainly called when return key is pressed.
The problem is that I don't know the previous and next controls so that
I can put useful information in the wparam and lparam. And I don't know the usefulness of setting controlid = idok which is simply the ID of the
callback routine.
Would really appreciate any help,
Bill
Jugoslav_Dujic
WM_NEXTDLGCTL should be sent to the dialog, i.e.
j = SendMessage(Dlg%hWnd, WM_NEXTDLGCTL, 0, 0) !next control
j = SendMessage(Dlg%hWnd, WM_NEXTDLGCTL, 1, 0) !previous control
If you want finer control, you might play with GetNextDlgTabItem combined with WM_NEXTDLGCTL(but with 1 as lParam), GetDlgItem, GetDlgCtrlID.
Jugoslav
Intel_C_Intel
Just to say thanks for the help.
Now for some retro-fitting of older dialog boxes.
Being a humble quickwin programmer, it seems to be a lot of guesswork
before getting these system calls to work. It would be nice to have
a few more samples showing how to use these system calls.
Bill
to work.
