Software Archive
Read-only legacy content
17060 Discussions
Dimensioning Arrays
Intel_C_Intel
I am new to Fortran, so I hope this question is not too simple.
I have a fortran dll, being called by vb 6.0, and in the dll, I am having a problem using automatic arrays.
For example, in the following line of code, NoComp=3, NoChain=1, but when I use quickwatch, InitInv is set up as an array with greter than 1000 elements (array expansion limited to 1000 nodes)
REAL(KIND=8), Dimension(NoComp*NoChain)::InitInv
Any help would be appreciated,
Ciara
Steven_L_Intel1
Are NoComp and NoChain arguments passed in? If so, it seems likely that they are not being passed correctly. Without seeing the actual code, and how it is called, it's difficult to say what is wrong.
Steve
Intel_C_Intel
NoComp and NoChain are passed in, but by checking with quick watch, the correct values have been passed in. I have included the call statements and declaration statements below,
Ciara
SUBROUTINE COMA (NoChain, Decay, Conv,
     &   NoComp,InitTime, NoChgTran,
     &   ChgTranTime,NoChgSou,ChgSouTime,
     &   NoSou, NucSou, CompSou,
     &   InpSou, InitInvFlag,NoChgInv,
     &   ChgInvTime, NoOutTime, OutTime,
     &   OutOption,NoOut, OutComp,Idisc
     &   ,OutVal, Ifail,InpInitInv,
     &   CompFrom,CompTo,
     &   InpTranRate, SetInvToZero
     &  ,NoSetComp,SetToZeroComp, NoOutVal,InpNoTran)
      !MS$ ATTRIBUTES DLLEXPORT :: COMA
      !MS$ ATTRIBUTES ALIAS:'_COMA':: COMA
      !MS$ ATTRIBUTES STDCALL :: COMA
	!MS$ ATTRIBUTES REFERENCE :: CONV, NoComp
      !MS$ ATTRIBUTES REFERENCE :: NoChain, Decay
	!MS$ ATTRIBUTES REFERENCE :: InitTime, NoChgTran, ChgTranTime
	!MS$ ATTRIBUTES REFERENCE :: NoChgSou,ChgSouTime, NoSou
      !MS$ ATTRIBUTES REFERENCE :: NucSou, CompSou,InpSou, InitInvFlag
      !MS$ ATTRIBUTES REFERENCE :: NoChgInv,ChgInvTime, NoOutTime
	!MS$ ATTRIBUTES REFERENCE :: OutTime
	!MS$ ATTRIBUTES REFERENCE :: OutOption,NoOut, OutComp,Idisc
	!MS$ ATTRIBUTES REFERENCE :: OutVal,Ifail
	!MS$ ATTRIBUTES REFERENCE :: InpInitInv,CompFrom,CompTo
	!MS$ ATTRIBUTES REFERENCE :: InpTranRate, SetInvToZero
	!MS$ ATTRIBUTES REFERENCE :: NoSetComp,SetToZeroComp, NoOutVal
	!MS$ ATTRIBUTES REFERENCE :: InpNoTran
	IMPLICIT NONE
* Declare and initialise variables
    INTEGER(2):: Iyr, Imon, Iday, Ihr, Imin, Isec, I100th
    INTEGER(4):: Conv, FirstOutTime, I, Ibx, Ich, Icm, Icomp, Id
    INTEGER(4):: Idisc, Ifail, Ifind, Ineg, InitInvFlag
	INTEGER(2):: InpNoTran
	INTEGER(4):: Inv, Iop, Iot
    INTEGER(4):: Irn,Iso, Isp, Itm, Itr, Jfind, Jtm, Kfind
	INTEGER(4):: LastOutTime, LastRunTime,NoBox, NoChgInv, NoChgSou
	INTEGER(4):: NoChgTran, NoComp, NoOut,NoChain,NoOutTime, NoOutVal
	INTEGER(4):: NoRank, NoRun, NoRunTime, NoSetComp, NoSou,NoSpace
	INTEGER(4):: NoTran, OutOption, SetInvToZero
	Integer, Dimension(4*NoComp*NoChain)::BoxFrom
    Integer, Dimension(NoChain)::BoxNoInv
	Integer, Dimension(NoComp*NoChain)::BoxSou
	Integer, Dimension(4*NoComp*NoChain)::BoxTo
	Integer, Dimension(NoChgTran+1)::CompFrom
	Integer, Dimension(NoSou)::CompSou
	Integer, Dimension(NoChgTran+1)::CompTo
	Integer, Dimension(3*NoChgTran+1)::FlagInv
	Integer, Dimension(3*NoChgTran+1)::FlagTran
	Integer, Dimension(3*NoChgTran+1)::IndInv
	Integer, Dimension(3*NoChgTran+1)::IndSou
	Integer, Dimension(3*NoChgTran+1)::IndTime
	Integer, Dimension(3*NoChgTran+1)::IndOutTime
	Integer, Dimension(3*NoChgTran+1)::IndTran
    Integer, Dimension(NoSou)::NucSou
	Integer, Dimension(2)::OutOpt
    Integer, Dimension(NoComp*NoChain)::Rank
	Integer, Dimension(NoChgTran+1*NoSetComp)::SetToZeroComp
    Integer, Dimension(NoOut)::OutComp
    REAL(KIND=4), Dimension(NoChgInv+1,NoComp*NoChain)::InpInitInv
    REAL(KIND=4), Dimension(NoSou,NoChgSou+1)::InpSou
	REAL(KIND=4), Dimension(InpNoTran,NoChain)::InpTranRate
    REAL(KIND=8)::InitTime
	REAL(KIND=8), Dimension(NoChgInv)::ChgInvTime
	REAL(KIND=8), Dimension(NoChgSou)::ChgSouTime
	REAL(KIND=8), Dimension(NoChgTran)::ChgTranTime
	REAL(KIND=8), Dimension(NoChain)::Decay
	REAL(KIND=8), Dimension(NoComp*NoChain)::InitInt
p*NoChain)::InitInv
	REAL(KIND=8), Dimension(NoComp*NoChain,NoChgInv+1)::RINV
	REAL(KIND=8), Dimension(NoComp*NoChain,NoChgInv+1)::RINT
	REAL(KIND=8), Dimension(4*NoChgInv+1)::RunTime
	REAL(KIND=8), Dimension(NoComp*NoChain)::Sou
    REAL(KIND=8), Dimension(4*NoChgInv+1)::Times
    REAL(KIND=8), Dimension(NoComp*NoChain*NoChain+1)::TranRate
	REAL(KIND=8), Dimension(NoChain)::OutFac
	REAL(KIND=8), Dimension(NoOutTime)::OutTime
	RE
Steven_L_Intel1
I suggest you send a reproducible example, including the calling VB code, to us at vf-support@compaq.com.
Steve
