Software Archive
Read-only legacy content
17060 Discussions
Display drop-down menu from within program
isn-removed200637
What message can I send to a window from within the program
to display a drop-down menu
as if I had selected an item from the menu bar using the mouse or a hot-key?
TIA
Jugoslav_Dujic
Valued Contributor II
There are two ways; the one you seem to be looking for (simulating user input) can be achieved using Win32 APIs keybd_event, mouse_event or SendInput. Another, pure "programatic" would be to use TrackPopupMenu, GetMenuItemRect and GetMenuItemInfo.
Jugoslav
isn-removed200637
Sorry, for 'in DFWINTY' ead 'in DFWIN'. Meanwhile, I checked and GetMenuItemRect is in USER32.dll
isn-removed200637
Thanks. I have changed the function call to GetMenuItemRect(hWnd, hMenu , hItem, LOC(menrect), but what should the Interface block contain? At the moment I have the following:
	interface
	logical(4) function  GetMenuItemRect(hWnd, hMenu , hItem, menrect)
!DEC$ IF DEFINED(_X86_)
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_GetMenuItemRect@16' :: GetMenuItemRect
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS :  'GetMenuItemRect'   :: GetMenuItemRect
!DEC$ ENDIF
	use dfwinty
	integer hWnd
	integer hMenu
	integer hitem
	type(T_RECT) menrect
	end function GetMenuItemRect
	end interface
Where should the !DEC$ATTRIBUTES REFERENCE:: menRect. go?
I still get unsatisfied external reference when I compile and link.
GetMenuItemRect is in USER32.dll (which is referenced by USER32.LIB)
and that library is included in my link list.
BTW, my last two posts to this thread have got lost, even though I got an e-mail
confirmation of each being accepted. There were some annoying problems with the message
board software on Tuesday which probably caused this.
Jugoslav_Dujic
!DEC$ATTRIBUTES REFERENCE should go anywhere within interface block.
(preferrably next to TYPE(menRect):: Rect). See ...DFIncludeDFWIN.f90 for samples on how various argument combinations are translated. I believe link error is just a consequence of that.
Jugoslav
isn-removed200637
Thanks Jugoslav.
I found the following works: the linker finds the routine _getmenuitemrect@16. Note that I removed STDCALL from the first !DEC$ATTRIBUTES compiler directive, which I think otherwise adds a(nother?) leading underline to the alias:
	interface
!DEC$ ATTRIBUTES ALIAS : '_GetMenuItemRect@16' :: GetMenuItemRect
!DEC$ ATTRIBUTES REFERENCE :: menrect
!DEC$ ELSE
!DEC$ ENDIF
	use dfwinty
	integer hWnd
	integer hMenu
	integer hitem
	type (T_RECT) menrect
C	integer menrect
	end interface
C FLAGS REQUIRED BY TRACKPOPUPMENU (Taken from WINUSER.H)
C THAT ARE NOT IN DFWINTY.F90
	integer, parameter:: TPM_TOPALIGN        =#0000
	integer, parameter:: TPM_VCENTERALIGN    =#0010
	integer, parameter:: TPM_BOTTOMALIGN     =#0020
	integer, parameter:: TPM_HORIZONTAL      =#0000
	integer, parameter:: TPM_VERTICAL        =#0040
	integer, parameter:: TPM_NONOTIFY        =#0080
	integer, parameter:: TPM_RETURNCMD       =#0100
However, when I call GETMENUITEMRECT, it returns zero (and the RECT structure menrect contains all zeros) and GETLASTERROR gives error code = 1400, which
shows that it failed because of an invalid window handle. I do not understand this, because I used the same window handle as I used to get the handle to the pop-up menu that I display. I even tried using the handle returned by GETACTIVEWINDOW(), but with the same failure.
TRACKPOPUPMENU works ok though and I can display the drop-down menu that I want, but I cannot display it in its usual relationship to the window's menu because of the failure to get the co-ordinates for the menuitem which normally activates the drop-down menu. Sigh.
Jugoslav_Dujic
hWnd should be the handle of frame window (or the window that contains the main menu). However, I find very odd that the interface block without STDCALL works. I tried it on my 5.0D, and your first version with only REFERENCE added works fine. The way you declared it now hWnd, hMenu and iItem arguments will be passed by reference instead of by value and you'll surely get an error like that (the linking will pass fine, but the API will get wrong numbers at run-time). (STDCALL attribute introduces call-by-value as default).
Jugoslav
isn-removed200637
OK jugoslav, I get the point..so I went back to this...
	interface
cDEC$ ATTRIBUTES STDCALL, ALIAS : '_GetMenuItemRect@16' :: GetMenuItemRect
cDEC$ ATTRIBUTES REFERENCE :: menrect
	use dfwinty
	integer hWnd
	integer hMenu
	integer hitem
	end interface
and used the following call
RETLOG=GetMenuItemRect(ghWnd,hMenu,2, dropdrect )< p>
The routine compiled ok (with dropdrect defined as TYPE (T_RECT) ), but I am still getting the link error
OPENFILE.OBJ : error LNK2001: unresolved external symbol _GETMENUITEMRECT@16
Release/generic.exe : fatal error LNK1120: 1 unresolved externals
With the above interface block, the alias '_GetMenuItemRect@16' should ensure that the required routine is recognised. I know that TrackPopUpMenu has exactly similar interface(but with 7 arguments, hence @28 is appended to the alias '_TrackPopUpMenu' ) and it is found and linked ok and I know that both routines are
in USER32.DLL. It is frustrating that the linker is still refusing to find GetMenuItemRect !!
I give up!
regards
tony richards
Jugoslav_Dujic
Heck, Tony, I've got a feeling that you're doing something terribly wrong, but I can't figure out what. The linker error suggests that the caller doesn't see ALIAS.
Where are you trying to put that INTERFACE in? If in ...DFWIN.f90, that won't work, because it's dfwin.mod file that matters, and it's not recompiled. You should put it in your calling code. Alternatively, you could also edit and recompile dfwin.f90, but you should copy dfwin.mod to ...DFInclude. (But I don't recommend that, since I did it once and had pains when upgrading and moving code to other machines).
If I'm wrong, I guess I'll give up too :-).
See my reply regarding the interface block.
Steve
