Software Archive
Read-only legacy content
17060 Discussions
tool tips on buttons?
davidgraham
You can have tooltips on toolbar items.
Can you have "tooltips" on buttons?
If you can, how do you do them.
David
Jugoslav_Dujic
Valued Contributor II
Here's a snip from an actual app which does just that. To be honest, it's evolved from a working 3rd-party example and I'm not on a solid ground why and whether it has to be so complicated... but then, if it works for me, it could also work for you. The dialog actually consists only of four buttons and serves as a "sub-toolbar" like in AutoCad. Here's its dialogproc:
LOGICAL(4) FUNCTION BojenjeDlgProc(hWnd,Msg,wParam,lParam)
!DEC$ATTRIBUTES STDCALL:: BojenjeDlgProc
USE DFWIN
USE COMCTL
USE HISTORY
USE GLOBALS
USE REGISTRY
USE UKS
IMPLICIT NONE
INCLUDE "Resource.fd"
INCLUDE 'Strings.fd'     ! Contains string definitions (S_TT_ stuff)
INTEGER::                     hWnd,Msg,wParam,lParam
INTEGER::                     IDCommand(4)=(/ID_BUTTON_PONAP,ID_BUTTON_POGRA, &
                                             ID_BUTTON_POIZV,ID_BUTTON_POSTA/)
CHARACTER*32::                szTool(4)=                                &
                             (/S_TT_COLOR_LEVEL,      &
                               S_TT_COLOR_AREA,       &
                               S_TT_COLOR_FEEDER,     &
                               S_TT_COLOR_ENERGIZATION/)
TYPE(T_RECT)::                Rect
TYPE(T_POINT)::               PT
TYPE(T_TTTOOLINFO)::          TI
INTEGER::                     iSt, i, ID, iState
INTERFACE
      INTEGER(4) FUNCTION HookProc(nCode,wParam,lParam)
      !DEC$ATTRIBUTES STDCALL::      HookProc
      INTEGER,INTENT(IN)::    nCode,wParam,lParam
      END FUNCTION
END INTERFACE
SELECT CASE(Msg)
CASE (WM_INITDIALOG)
      !iSt=ScreenToClient(hMDI,PT)
      iSt=SendMessage(GetDlgItem(hWnd,ID_BUTTON_PONAP),BM_SETIMAGE,IMAGE_BITMAP,hBojenjeBmp(1))
      iSt=SendMessage(GetDlgItem(hWnd,ID_BUTTON_POGRA),BM_SETIMAGE,IMAGE_BITMAP,hBojenjeBmp(2))
      iSt=SendMessage(GetDlgItem(hWnd,ID_BUTTON_POIZV),BM_SETIMAGE,IMAGE_BITMAP,hBojenjeBmp(3))
      iSt=SendMessage(GetDlgItem(hWnd,ID_BUTTON_POSTA),BM_SETIMAGE,IMAGE_BITMAP,hBojenjeBmp(4))
      iSt=SendMessage(GetDlgItem(hWnd,ID_BUTTON_POSTA),BM_SETCHECK,BST_CHECKED,0)
      hTooltip=CreateWindowEx(WS_EX_TOPMOST, "TOOLTIPS_CLASS32"C,""C,         &
                TTS_ALWAYSTIP, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT,   &
                CW_USEDEFAULT, hFrame, NULL, hInst, NULL)
      hHook=SetWindowsHookEx(WH_GETMESSAGE,LOC(HookProc),NULL,GetCurrentThreadId())
      Rect=T_RECT(0,0,0,0)
      DO i=1,4
            TI=T_TTTOOLINFO(32,TTF_IDISHWND,hWnd,GetDlgItem(hWnd,IDCommand(i)),Rect,0,LOC(szTool(i)),0)
            iSt=SendMessage(hTooltip, TTM_ADDTOOL,0,LOC(TI))
      END DO
      BojenjeDlgProc=.FALSE.
CASE (WM_COMMAND)
      !(Stripped)
CASE DEFAULT
END SELECT
END FUNCTION BojenjeDlgProc
(To be continued...)
Jugoslav_Dujic
...here's HookProc:
USE DFWIN
USE COMCTL
USE GLOBALS
USE REGISTRY
IMPLICIT NONE
INTEGER::         iSt
TYPE(T_MSG)::     Msg,MsgOut
POINTER(pMsg,Msg)
pMsg=lParam
IF (Msg%hWnd.EQ.GetDlgItem(hBojenje,ID_BUTTON_PONAP) .OR.         &
         Msg%hWnd.EQ.GetDlgItem(hBojenje,ID_BUTTON_POGRA) .OR.   &
         Msg%hWnd.EQ.GetDlgItem(hBojenje,ID_BUTTON_POIZV) .OR.   &
         Msg%hWnd.EQ.GetDlgItem(hBojenje,ID_BUTTON_POSTA)) THEN
      SELECT CASE (Msg%Message)
      CASE (WM_MOUSEMOVE,WM_LBUTTONDOWN,WM_LBUTTONUP,WM_RBUTTONDOWN,WM_RBUTTONUP)
          MsgOut%lParam = Msg%lParam
          MsgOut%wParam = Msg%wParam
          MsgOut%Message = Msg%Message
          MsgOut%hwnd = Msg%Hwnd
          iSt=SendMessage(hTooltip, TTM_RELAYEVENT, 0, LOC(MsgOut))
      END SELECT
      HookProc=CallNextHookEx(hHook,nCode,wParam,lParam)
ELSE IF (...
      !Snipped part for other dialogs
ELSE
END IF
END FUNCTION HookProc
HTH
Jugoslav
davidgraham
Jugoslav,
Thanks again for you help.
I got the tool tips to work. I don't know how any body could work that out for themselves.
I simplified HookProc, I wanted tips for all the buttons.
! tool tips
 USE dfwin
 USE global
 INTEGER::    nCode,wParam,lParam
 INTEGER::         iSt
 TYPE(T_MSG)::     Msg
 POINTER(pMsg,Msg)
 INCLUDE 'Resource.fd'
 pMsg=lParam
 iSt=SendMessage(hTooltip, TTM_RELAYEVENT, 0, LOC(Msg))
 END SELECT
