						I am using device plugin and I am displaying prperties with label as innerHTML property it's not working but when display a normal string with label it's working .whenever display device.model property using alert it's working when I tested using app preview .Please help .
Sameer Kulkarni
- Tags:
- HTML5
- Intel® XDK
If you're trying to display the device.* properties you might take a look at the "hello cordova" sample to see how it does it. I suspect it is a different technique than what you are trying, but it does work.
I got solution here
https://software.intel.com/en-us/xdk/articles/cordova-core-plugin-device-short-code-example.
Thanks for your suggestion .
Reegards
sameer kulkarni
			Topic Options
