Software Archive
Read-only legacy content
17060 Discussions
Displaying device plugin properties within label is not working.
kulkarni__sameer
I am using device plugin and I am displaying prperties with label as innerHTML property it's not working but when display a normal string with label it's working .whenever display device.model property using alert it's working when I tested using app preview .Please help . Regards Sameer Kulkarni
PaulF_IntelCorp
If you're trying to display the device.* properties you might take a look at the "hello cordova" sample to see how it does it. I suspect it is a different technique than what you are trying, but it does work.
kulkarni__sameer
I got solution here
https://software.intel.com/en-us/xdk/articles/cordova-core-plugin-device-short-code-example.
Thanks for your suggestion .
Reegards
sameer kulkarni
