Software Archive
Read-only legacy content
17060 Discussions
Distributing run-time libraries
Intel_C_Intel
I checked the FAQ's and Knowledge Base, and didn't see an answer. Two quick questions:
1. I need to provide documentation regarding the legal implications of distributing the run-time libraries (DFORRT.DLL, DFORRM.DLL, etc.) with our DLL. As I understand it, if we have a license, we may distribute legally without royalty compensation, is this true?
2. Is there anyway to package the necessary run-time library inside the dll we are distributing? (I suspect not, but I need confirmation)
dfh
This is spelled out in your license agreement.
You can distribute our dlls along with yours - I do not recommend linking in a static version of the run-time library unless you know for certain that no other Fortran code will be used in the application. Note that you probably need only one of DFORRT.DLL and DFORMD.DLL - the latter is if you build against the threaded libraries.
Steve
isn-removed200637
To DFH, Just a thought: If you use QuickWin help, don't forget to include FQWIN.HLP also, or else extract the QuickWIn help topics from it (using HCW.EXE) and include them in your own help
file.
A question for Steve: with the exception of the help file noted above, under what circumstances could a statically-linked executable still require
access to other VF routines not included at the link stage?
Anthony,
If an application uses the modeless dialog support in DFLOGM, it needs DFDLG100.DLL, but otherwise, I can't think of any other Fortran components needed by a statically linked application.
Steve
