Software Archive
Read-only legacy content
Does the TinyB bluetooth library work for non-intel hardware?
MBran5
Hey,
I read the guide here: https://software.intel.com/en-us/java-for-bluetooth-le-apps
On how to use the open-source TinyB library with Java for bluetooth LE applications.
It has information on how to use TinyB with Intel Edison boards.
Unfortunately I cannot use such boards, I have hardware that connects a sensor to an nRF52840 bluetooth chip by Nordic Semiconductor.
I need to send the bluetooth data to a Java desktop application and I am wondering if I can use TinyB to do this?
In the guide it says: "TinyB exposes simple C++ and Java APIs for using Bluetooth low energy devices."
So it seems it could work for any Bluetooth LE device? But I am not quite sure and I need to find out before I spend a lot of time researching this solution.
Any help is appreciated!
Harold_G_Intel
Hi Magnus,
You might try asking this question here:   https://communities.intel.com/community/tech/edison
or https://communities.intel.com/community/tech/iot-gateway
Regards, Hal
Intel(R) Developer Zone Support
http://software.intel.com
*Other names and brands may be claimed as the property of other
MBran5
Alright thanks, will try that.
I was a bit confused on where to post to be honest.
