Software Archive
Read-only legacy content
Don't login
Juan_Eduardo_Brennan
Hi!!, I have user and password when used Intel XDK version 1621.
In this versión don't login, but in the version 3552 login fine...
Not run the 1621 version???
In this case, how to generated APK file in the 3552 version???
PaulF_IntelCorp
We no longer support version 1621. See the note in the release notes >https://software.intel.com/en-us/xdk/docs/release-notes-information-intel-xdk < Use the Build tab in 3522 to create your APK. See the documentation here > https://software.intel.com/en-us/xdk/docs/lp-index <
Hi Paul!!
The answers you have given me only generate more doubts and bit me tell me specifically what I need.
I not think it's difficult to know because earlier versions such as 1621 (although this discontinued ) do not let me access my user name and password.
On the other hand , also it would be simple to know how to make APK , given that the 1621 version and the 3552 hacei directly does not and that truth is not practical.
Thanks anyway , I will continue checking on the subject.
PaulF_IntelCorp
The backend has changed such that you cannot login with 1621.
I'm not clear on what is preventing you from making an APK, you do it with the Build tab. With the new version you do need to "convert" your "legacy" Android certificate into a form that works with the new version. You can see that process in this video > https://software.intel.com/en-us/videos/upgrading-an-existing-intel-xdk-project-to-version-3088 <
