please.
When Intel will be released drivers for GMA X3000 (HW T&L and vertex shader 2.0 or 3.0)?
in February?
tccwin:
With 14.31,I was able to playgames like World in Conflict and Crysis. After 14.32, Crysis was fine but World in Conflict started to hang. Now with the driver 14.32.3, both of the games have started giving Blue Screen Of Death. Intel tries to fix one issue and the the working thing goes bad. I think Intel should rent Nvidia Driver Developers to fix GMA issues.
Whaat??!? Well, I have not been able to run World in Conflict in all the beta drivers, or the production drivers after that. 14.31pb/14.31b/14.31/14.31.1/14.32/14.32.3 all did not run World in Conflict. My system just crashed. For Crysis, I have not seen improvements or degradation in any of the drivers.
Hi friends this is my 1st post here.Though I have been using this community for quite a while now(just by reading the comments written by you guys).I have just bought intel dg965ry motherboard.i have installed the 14.32.3 driver.The "everest" software is showing that hw tnl is not supported.Soi contacted intel and this is what they had to say............"Hello again Arpan,
Thank you for contacting Intel Technical Support.
Hardware transform and lighting and Vertex Shader have been implemented
on the drivers under PV14.32.3
You can download these drivers at the following website:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2576&OSFullName=Windows*+XP+Professional〈=eng&strOSs=44&submit=Go%21
I can't understand whats the problem .plz help me out.Thanx in advance for any kind of help.
the g965 series support h/w TnL. dont worry.
read this thread- www.thinkdigit.com/forum/showthread.php?t=60232 ,
that guy has same motherboard as yours & he has tested 50+ games
deep_chatterje:
I know that g965 express chipset has the required hw tnl support.But my point is whether 14.32.3(6.14.10.4906)driver invokes it or not.If it enables it, then why "EVEREST" shows hw tnl is not supported?Is it that we have to believe it in abstract????....confusing.
Sigh. Go back to the main page and look for the information aboutX3000's hardware T&L that I posted.
I keep telling people, it had hardware support ever since 14.31 drivers back August last year damn it.
Hi! Any news regarding when drivers will be released for GMA X3000 ?
The hardware of intel GMA X3000 is good butIntel should focus more on fixinglatest game bugs. I can play Crysis on DG965RY with 10 FPS on low settings. But even after intel has released around three drivers, after launch of crysis, why is the graphic still corrupt and lot of memory errorsin console when the map is loaded. The state of the game is still same even after appling patch 1.1 for crysis and using latest drivers ( 15.7.3 ).
Now even the driver 15.7.3 has a video bios, but its not updated in DG965RY motherboard bios. Is this the way Intel will be dealing with its loyal customers. I have been using Intel original boards since 1998 and update system every 2 years.
Does the drivers properly enable HSR at all?? I mean things like Early Z/Intermediate Z, the ones that does Hidden Surface Removal. When I purposely downclocked my memory from 800MHz to 667MHz, I found that the 20% increase in memory bandwidth was responsible for 10-11% increase in performance. 50% performance increase for every 100% increase in memory bandwidth probablymeans a bottleneck is there somewhere on the architecture.
Why is everything slow on the X3100?? I heard that Warcraft III gets 25 fps with 640x480 low, while some people report same with 800x600 low on newer games like Battlefield 2!! Maybe using too much memory bandwidth because it doesn't have HSR methods or its a bad implementation is hurting performance?? I can't believe how DX6/7 game with really outdated graphics effects and a new DX9 game performs similar in some cases.
How exactlly do you expect us to believe achieving "Gold Standard" of drivers in 2-3 years when its not even in "Lead Standard" now??
WOW, things
still that way, what a shame.
All I can say to Intel (if they at least read posts here anyway)
NEVER EVER SELL SOMETHING YOU DO NOT HAVE
This GMA driver issue is not important to me anymore, my GMA is disabled (a little workaround I found out in the BIOS) and almost forgotten.
But I still waiting for an official option in the BIOS to disable the GMA.
And, in the era of 4GB+ RAM I would like to see and be able to use an option in the BIOS to force physical address allocation for hardware above the 32bit limits (suggestion: at the limits of 36bit(PAE) extension), so finally users could have use of the full physical memory installed in the system, well, I guess this one we consumers will never see in the now available Intel MoBos
And I was surprised by a very poor performance. Warcraft 3 is slow. Really SLOW! It's much more slower than on my ancient desktop system (i440bx, Pentium-III Tualatin - 1200(1350) MHz , 512 MB PC133 SDRAM, Radeon 9200SE 64 MB, Windows XP HE). WoW, NfSU, NfSU2 much more playable than Warcraft 3 on x3100, but still - i've expected that performance in games will be better than on 7-years old PC.
First I thought that main problem here is outdated drivers. But driver update given me a little of performance boost...
And still I cannot understand what is the problem. The fps in Warcraft (with almost everything set to minimum) is around 15-20.
Can anyone give me a little of advice that might help me in this problem?
Maybe you run WC3 on desktop system with dual-core processor and Intel GMA x3000 adapter?
K, did intel launched G35 based desktop motherboards???
(like ASUS did (ASUS P5E-V/VM HDMI)???)
G35 model from intel "DG35PLM" is available in india (i dont know other models based on it)!!! i dont know how its happening without official anouncement on intel website both in global and local indian site ...???
here is the proof!! go to this site below!!!
http://compuneed.net/motherboard.asp
Have intel forgot to upload this motherboard model other than remembering uploading luxurious D5400XS motherboard???
should i try to buy this board???
because iam using DG965RY board and because of the poor driver for display made me to buy an Discreet card..!!! : ( i think this board will also have the same problem!!! ADVICE ME GUYs!!!
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
