Software Archive
Read-only legacy content
17060 Discussions
Effective Address calculation time on 8086/8088 [old school]
Matthieu_W_
I've started to implement a 8086/8088 with the goal of being cycle-exact. I can understand the reasoning behind the number of clock cycles for most instructions, however I must say I'm quite puzzled by the Effective Address (EA) calculation time.
More specifically, why does computing BP + DI or BX + SI take 7 cycles, but computing BP + SI or BX + DI take 8 cycles?
I could just wait for a given number of cycles, but I'm really interested in knowing why there's this 1-cycle difference (and overall why it takes so many cycles to do any EA calculation, since EA uses the ALU for computing addresses, and an ADD between registers is just 3 cycles).
The designers of the chip probably are retired by now, but hopefully there is somebody at Intel who has the knowledge, or can point me to the people who have it :-)
zalia64
I suggest you check out the encoding of the instructions. Each additional byte means an additional cycle.
Matthieu_W_
I have, there is the same number of bytes in the instruction, whether it's for example BX (5 cycles) or BX + SI (7 cycles) or BX + DI (8 cycles), all of it is encoded using the "mod" + "r/m" fields.
SergeyKostrov
Valued Contributor II
>>...More specifically, why does computing BP + DI or BX + SI take 7 cycles, but computing BP + SI or BX + DI take 8 cycles? Q1. Are you absolutely confident that your measurements are correct? Q2. How did you get these numbers? ( I mean 7 and 8 cycles )
Matthieu_W_
Q1 + Q2. These are not measurements, these numbers come from Intel's own reference manual :-)
I have had the answer since then, the difference has to do with how the effective addressing was implemented with the microcode. So effectively, some modes (such as BP + DI) were more optimized than others (like BX + SI).
