Software Archive
Read-only legacy content
17061 Discussões
Emulator no longer see the file plugin
Mike_C_4
Novo colaborador I
1.211 Visualizações
I have upgrade my project to CLI 5xx and once I got that working I now have another problem.
I went to look at some changes I made to my CSS file and the emulator now tells me that it can't find the File plugin? I looked and yup it’s gone but I see a new File plugin in there. This new version of the plugin was not incorporated into my project correctly once I updated the plugins (as per XDK request) so I can build my project under 5xx.
Now I went to delete the old plugin and guess what?  The delete icon is now replaced by a lock or link icon and I can’t deleted it so I can add the one XDK downloaded one.
Man this is so brutal.. Any help would be great. (See screen shot)
1 Solução
PaulF_IntelCorp
Funcionário
1.211 Visualizações
The "lock" link is there because another plugin in your list requires the File plugin (take a look at the details under the File plugin and it will tell you which plugin it depends on). You need to remove that other plugin to make the File plugin go away.
Ver solução na publicação original
5 Respostas
Elroy_A_Intel
Funcionário
1.211 Visualizações
Are you able delete or modify the related file(s) in your local file system?
PaulF_IntelCorp
Funcionário
1.212 Visualizações
Mike_C_4
Novo colaborador I
1.211 Visualizações
This is what I did, however I don't understand WHY I had to do this to begin with?
PaulF_IntelCorp
Funcionário
1.211 Visualizações
Because if you remove a "locked" plugin then you end up removing a plugin that another plugin depends on being there. Without the dependent plugin the other plugin will fail to work. It's a dependency issue, nothing more.
Mike_C_4
Novo colaborador I
1.211 Visualizações
not sure whats going on but I removed all plugins and place them back in and I'm getting the same error.
Once I'm done with the project I going to do a clean install.
Mike
Responder
