Hi there, I am trying to add "cordova.adjust.sdk" plugin located here: http://plugins.cordova.io/#/package/com.adjust.sdk But get the error: < Error: Plugin "cordova.adjust.sdk" failed to install > while building Android application. I am adding it through "Get Plugin From Web". XDK build 2323. What is wrong? Adjust is very popular tracker, so it is nice to make it working through Cordova Thanks
- Tags:
- HTML5
- Intel® XDK
See the note at the beginning of the plugin doc page:
N.B. At the moment, SDK 4.0.2 for Cordova supports Android platform version 4.0.0 and higher and iOS platform version 3.0.0 and higher.
Our current build system only builds an Android Corodova platform version 3.6 system. Our next major update will provide support for CLI 5.1.1 which supports Android Cordova framework 4.1.0. You'll have to wait for that update before you can experiment with this plugin.
Try adding plugin locally and check if this error still exist.
Here is the helpful link: https://software.intel.com/en-us/xdk/docs/adding-third-party-plugins-to-your-xdk-cordova-app
I tried it, the same issue
Thank, Paul
Does Early Access support it?
When the next major update is expected?
Nope, EA and the regular version of the XDK use the same build system. It's a function of the build system, more than anything. Our major updates occur every six to eight weeks, with occasional hotfixes in between. I cannot give a date, but here is a pointer to the release notes: https://software.intel.com/en-us/xdk/docs/release-notes-information-intel-xdk and v2323 was our last major update.
ok, thank you
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
