Software Archive
Read-only legacy content
17061 Discussions
Error: Plugin "cordova.adjust.sdk" failed to install
Mister_J_
Hi there, I am trying to add "cordova.adjust.sdk" plugin located here: http://plugins.cordova.io/#/package/com.adjust.sdk But get the error: < Error: Plugin "cordova.adjust.sdk" failed to install > while building Android application. I am adding it through "Get Plugin From Web". XDK build 2323. What is wrong? Adjust is very popular tracker, so it is nice to make it working through Cordova Thanks
PaulF_IntelCorp
See the note at the beginning of the plugin doc page:
N.B. At the moment, SDK 4.0.2 for Cordova supports Android platform version 4.0.0 and higher and iOS platform version 3.0.0 and higher.
Our current build system only builds an Android Corodova platform version 3.6 system. Our next major update will provide support for CLI 5.1.1 which supports Android Cordova framework 4.1.0. You'll have to wait for that update before you can experiment with this plugin.
Amrita_C_Intel
Try adding plugin locally and check if this error still exist.
Here is the helpful link: https://software.intel.com/en-us/xdk/docs/adding-third-party-plugins-to-your-xdk-cordova-app
Mister_J_
I tried it, the same issue
PaulF_IntelCorp
Mister_J_
Thank, Paul
Does Early Access support it?
When the next major update is expected?
PaulF_IntelCorp
Nope, EA and the regular version of the XDK use the same build system. It's a function of the build system, more than anything. Our major updates occur every six to eight weeks, with occasional hotfixes in between. I cannot give a date, but here is a pointer to the release notes: https://software.intel.com/en-us/xdk/docs/release-notes-information-intel-xdk and v2323 was our last major update.
Mister_J_
ok, thank you
