Software Archive
Read-only legacy content
17061 Discussions
Error: Plugin "" failed to Install
Smith__J
I keep getting this error Plugin "" failed to install.
All the plugins I do have, AdMob, Splashscreen and Cordova device are installed.
So there appears to be an unidentified "ghost plugin" that is preventing me from building. It says, "Verify your assets, and try again." What can I do? Is there a way to go deeper, and find out what this missing "ghost plugin" is?
PaulF_IntelCorp
There is a link to a detailed build log. See the image below (this one is from a successful build, but the message is similar on a failed log). Some failed builds do not include a detailed log, but most will, and usually you can find the problem near the end of the log. I've seen a few of these "" plugin errors, but do not yet understand what is causing this "" name, there is a real plugin behind that "" name and it should be a plugin you've included.
