Software Archive
Read-only legacy content
Error build app
zipsoft_z_
Emulate option is correct but build failed.
How can I know what is the problem?
.../TINYBAR/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: .../TINYBAR/platforms/android/gradlew with args: cdvBuildRelease,-b,.../TINYBAR/platforms/android/build.gradle,-Dorg.gradle.daemon=true
Command finished with error code 8: .../TINYBAR/platforms/android/cordova/build --release
ERROR building one of the platforms: Error: .../TINYBAR/platforms/android/cordova/build: Command failed with exit code 8
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (/Developer/cordova/cordova-cli/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:743:16)
    at Process.ChildProcess._handle.onexit (child_process.js:810:5)
PaulF_IntelCorp
There were some problems with our build system that were causing that error. The issue should be resolved now. Please try building your app again.
Konstantin_R_
I have the same error now on xdk 2727 when i build crosswalk.
Konstantin_R_
I found that i get error when I add third-party plugin, but it worked on last version xdk.
Emeka_A_
getting errors too when building my app. so annoying.. I'm supposed to demo this tommorow.
John_H_Intel2
Please provide details/images of the issues that you are seeing.
