Software Archive
Read-only legacy content
17060 Discussions
Evaluation license error #10310: Failed to enable trusted storage check for licensing
Karen_K_
I'm trying to use the Fortran compiler with the trial version of Composer XE for an x64 application. When I tried to run a program, I got the following error
ifort: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
Per a previous post, it appears that I need a license file ( .lic extension ) emailed to my evaluation license. Can anyone help me?
Hubert_H_Intel
License file sent to your email address.
Regrds, Hubert
Karen_K_
Thank you for sending the license file. I'm trying to run the complier with Abaqus and it's not working. It appears that I need the Intrel Visual Fortran 9.1 or 10.1 is there a way to get one of these older versions?
Hubert_H_Intel
Kareen,
That's a little problem. Let me check if I can provide an older Fortran eval version. Could you also please clarify what exact version you need for running under Abaqus. My knowledge is that the Intel® Fortran Compilers 10.1 and 11.1 are supported by Abaqus, but this may also depend on the Abaqus version.
Regards, Hubert.
Karen_K_
Hubert,
I've contacted Abaqus support to confirm. According to their website Intel Visual Fortran 9.1 and 10.1 are supported for my Abaqus version.
http://www.3ds.com/support/certified-hardware/simulia-system-information/abaqus-69/system-requirements-for-abaqus-69-products/?xtmc=fortran&xtcr=1
Thank you for your help.
Hubert_H_Intel
Thanks, Karren,
Let me check if I can provide a 9.1 or 10.1 eval version.
Regards, Hubert.
Karen_K_
Thanks, Hubert. Looking forward to your reply.
Karen_K_
I just heard back from Abaqus. It appears I need the Intel Fortran Composer XE 2011 SP1 Update 4.
Ilshat_S_
Hello, I have same problem. I'm using evaluation and cannot start compiler from command line and from Visual Studio. Please help me to resolve this.
