Software Archive
Read-only legacy content
17061 Discussions
*** Evolution of Command Line options of different C++ compilers ***
SergeyKostrov
Valued Contributor II
*** Evolution of Command Line options of different C++ compilers *** [ Abstract ] Technical details on Evolution of Command Line options of different C++ compilers, more than 10, will be provided.
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 1 Usage: g++.exe [options] file... Options: -pass-exit-codes Exit with highest error code from a phase --help Display this information --target-help Display target specific command line options --help={common|optimizers|params|target|warnings|[^]{joined|separate|undocumented}}[,...] Display specific types of command line options --version Display compiler version information -dumpspecs Display all of the built in spec strings -dumpversion Display the version of the compiler -dumpmachine Display the compiler's target processor -print-search-dirs Display the directories in the compiler's search path -print-libgcc-file-name Display the name of the compiler's companion library -print-file-name= Display the full path to library -print-prog-name= Display the full path to compiler component -print-multiarch Display the target's normalized GNU triplet, used as a component in the library path -print-multi-directory Display the root directory for versions of libgcc -print-multi-lib Display the mapping between command line options and multiple library search directories -print-multi-os-directory Display the relative path to OS libraries -print-sysroot Display the target libraries directory -print-sysroot-headers-suffix Display the sysroot suffix used to find headers -Wa, Pass comma-separated on to the assembler -Wp, Pass comma-separated on to the preprocessor -Wl, Pass comma-separated on to the linker -Xassembler Pass on to the assembler -Xpreprocessor Pass on to the preprocessor -Xlinker Pass on to the linker -save-temps Do not delete intermediate files -save-temps= Do not delete intermediate files -no-canonical-prefixes Do not canonicalize paths when building relative prefixes to other gcc components -pipe Use pipes rather than intermediate files -time Time the execution of each subprocess -specs= Override built-in specs with the contents of -std= Assume that the input sources are for --sysroot= Use as the root directory for headers and libraries -B Add to the compiler's search paths -v Display the programs invoked by the compiler -### Like -v but options quoted and commands not executed -E Preprocess only; do not compile, assemble or link -S Compile only; do not assemble or link -c Compile and assemble, but do not link -o Place the output into -pie Create a position independent executable -shared Create a shared library -x Specify the language of the following input files Permissible languages include: c c++ assembler none 'none' means revert to the default behavior of guessing the language based on the file's extension Options starting with -g, -f, -m, -O, -W, or --param are automatically passed on to the various sub-processes invoked by g++.exe. In order to pass other options on to these processes the -W options must be used. The following options are specific to just the language Ada: None found. Use --help=Ada to show *all* the options supported by the Ada front-end The following options are specific to just the language AdaSCIL: None found. Use --help=AdaSCIL to show *all* the options supported by the AdaSCIL front-end The following options are specific to just the language AdaWhy: None found. Use --help=AdaWhy to show *all* the options supported by the AdaWhy front-end The following options are specific to just the language C: -lang-asm This switch lacks documentation The following options are specific to just the language C++: None found. Use --help=C++ to show *all* the options supported by the C++ front-end
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 2 The following options are specific to just the language Fortran: -J Put MODULE files in 'directory' -Waliasing Warn about possible aliasing of dummy arguments -Walign-commons Warn about alignment of COMMON blocks -Wampersand Warn about missing ampersand in continued character constants -Warray-temporaries Warn about creation of array temporaries -Wc-binding-type Warn if the type of a variable might be not interoperable with C -Wcharacter-truncation Warn about truncated character expressions -Wcompare-reals Warn about equality comparisons involving REAL or COMPLEX expressions -Wconversion-extra Warn about most implicit conversions -Wextra Print extra (possibly unwanted) warnings -Wfunction-elimination Warn about function call elimination -Wimplicit-interface Warn about calls with implicit interface -Wimplicit-procedure Warn about called procedures not explicitly declared -Wintrinsic-shadow Warn if a user-procedure has the same name as an intrinsic -Wintrinsics-std Warn on intrinsics not part of the selected standard -Wline-truncation Warn about truncated source lines -Wreal-q-constant Warn about real-literal-constants with 'q' exponent-letter -Wrealloc-lhs Warn when a left-hand-side array variable is reallocated -Wrealloc-lhs-all Warn when a left-hand-side variable is reallocated -Wsurprising Warn about "suspicious" constructs -Wtabs Permit nonconforming uses of the tab character -Wtarget-lifetime Warn if the pointer in a pointer assignment might outlive its target -Wunderflow Warn about underflow of numerical constant expressions -Wunused-dummy-argument Warn about unused dummy arguments. -Wuse-without-only Warn about USE statements that have no ONLY qualifier -Wzerotrip Warn about zero-trip DO loops -cpp Enable preprocessing -cpp= This switch lacks documentation -faggressive-function-elimination Eliminate multiple function invokations also for impure functions -falign-commons Enable alignment of COMMON blocks -fall-intrinsics All intrinsics procedures are available regardless of selected standard -fallow-leading-underscore This switch lacks documentation -fautomatic Do not treat local variables and COMMON blocks as if they were named in SAVE statements -fbackslash Specify that backslash in string introduces an escape character -fbacktrace Produce a backtrace when a runtime error is encountered -fblas-matmul-limit= Size of the smallest matrix for which matmul will use BLAS -fcheck-array-temporaries Produce a warning at runtime if a array temporary has been created for a procedure argument -fcheck=[...] Specify which runtime checks are to be performed -fcoarray= Specify which coarray parallelization should be used -fconvert= -fconvert= The endianness used for unformatted files. -fcray-pointer Use the Cray Pointer extension -fd-lines-as-code Ignore 'D' in column one in fixed form -fd-lines-as-comments Treat lines with 'D' in column one as comments -fdefault-double-8 Set the default double precision kind to an 8 byte wide type -fdefault-integer-8 Set the default integer kind to an 8 byte wide type -fdefault-real-8 Set the default real kind to an 8 byte wide type -fdollar-ok Allow dollar signs in entity names -fdump-core Does nothing. Preserved for backward compatibility. -fdump-fortran-optimized Display the code tree after front end optimization -fdump-fortran-original Display the code tree after parsing -fdump-parse-tree Display the code tree after parsing; deprecated option -fexternal-blas Specify that an external BLAS library should be used for matmul calls on large-size arrays -ff2c Use f2c calling convention -ffixed-form Assume that the source file is fixed form -ffixed-line-length- Use n as character line width in fixed mode -ffixed-line-length-none Allow arbitrary character line width in fixed mode -ffpe-summary=[...] Print summary of floating point exceptions -ffpe-trap=[...] Stop on following floating point exceptions -ffree-form Assume that the source file is free form -ffree-line-length- Use n as character line width in free mode -ffree-line-length-none Allow arbitrary character line width in free mode -ffrontend-optimize Enable front end optimization -fimplicit-none Specify that no implicit typing is allowed, unless overridden by explicit IMPLICIT statements -finit-character= Initialize local character variables to ASCII value n -finit-integer= Initialize local integer variables to n -finit-local-zero Initialize local variables to zero (from g77) -finit-logical= Initialize local logical variables -finit-real= Initialize local real variables -finteger-4-integer-8 Interpret any INTEGER(4) as an INTEGER(8) -fintrinsic-modules-path Specify where to find the compiled intrinsic modules -fintrinsic-modules-path= Specify where to find the compiled intrinsic modules -fmax-array-constructor= Maximum number of objects in an array constructor -fmax-identifier-length= Maximum identifier length -fmax-stack-var-size= Size in bytes of the largest array that will be put on the stack -fmax-subrecord-length= Maximum length for subrecords -fmodule-private Set default accessibility of module entities to PRIVATE. -fpack-derived Try to lay out derived types as compactly as possible -fprotect-parens Protect parentheses in expressions -frange-check Enable range checking during compilation -freal-4-real-10 Interpret any REAL(4) as a REAL(10) -freal-4-real-16 Interpret any REAL(4) as a REAL(16) -freal-4-real-8 Interpret any REAL(4) as a REAL(8) -freal-8-real-10 Interpret any REAL(8) as a REAL(10) -freal-8-real-16 Interpret any REAL(8) as a REAL(16) -freal-8-real-4 Interpret any REAL(8) as a REAL(4) -frealloc-lhs Reallocate the LHS in assignments -frecord-marker=4 Use a 4-byte record marker for unformatted files -frecord-marker=8 Use an 8-byte record marker for unformatted files -frecursive Allocate local variables on the stack to allow indirect recursion -frepack-arrays Copy array sections into a contiguous block on procedure entry -fsecond-underscore Append a second underscore if the name already contains an underscore -fsign-zero Apply negative sign to zero values -fstack-arrays Put all local arrays on stack. -funderscoring Append underscores to externally visible names -fwhole-file Does nothing. Preserved for backward compatibility. -nocpp Disable preprocessing -static-libgfortran Statically link the GNU Fortran helper library (libgfortran) -std=f2003 Conform to the ISO Fortran 2003 standard -std=f2008 Conform to the ISO Fortran 2008 standard -std=f2008ts Conform to the ISO Fortran 2008 standard including TS 29113 -std=f95 Conform to the ISO Fortran 95 standard -std=gnu Conform to nothing in particular -std=legacy Accept extensions to support legacy code
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 3 The following options are specific to just the language Go: -L This switch lacks documentation -fgo-check-divide-overflow Add explicit checks for division overflow in INT_MIN / -1 -fgo-check-divide-zero Add explicit checks for division by zero -fgo-dump- Dump Go frontend internal information -fgo-optimize- Turn on optimization passes in the frontend -fgo-pkgpath= Set Go package path -fgo-prefix= Set package-specific prefix for exported Go names -fgo-relative-import-path= -fgo-relative-import-path= Treat a relative import as relative to path -frequire-return-statement Functions which return values must end with return statements
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 4 The following options are specific to just the language Java: --CLASSPATH This switch lacks documentation --bootclasspath This switch lacks documentation --classpath This switch lacks documentation --encoding This switch lacks documentation --extdirs This switch lacks documentation --output-class-directory This switch lacks documentation --output-class-directory= This switch lacks documentation --resource This switch lacks documentation --resource= This switch lacks documentation -CLASSPATH This switch lacks documentation -MD_ This switch lacks documentation -MMD_ This switch lacks documentation -Wall-deprecation This switch lacks documentation -Wall-javadoc This switch lacks documentation -Wassert-identifier This switch lacks documentation -Wboxing This switch lacks documentation -Wchar-concat This switch lacks documentation -Wcondition-assign This switch lacks documentation -Wconstructor-name This switch lacks documentation -Wdep-ann This switch lacks documentation -Wdiscouraged This switch lacks documentation -Wempty-block This switch lacks documentation -Wenum-identifier This switch lacks documentation -Wenum-switch This switch lacks documentation -Wextraneous-semicolon Warn if deprecated empty statements are found -Wfallthrough This switch lacks documentation -Wfield-hiding This switch lacks documentation -Wfinal-bound This switch lacks documentation -Wfinally This switch lacks documentation -Wforbidden This switch lacks documentation -Whiding This switch lacks documentation -Windirect-static This switch lacks documentation -Wintf-annotation This switch lacks documentation -Wintf-non-inherited This switch lacks documentation -Wjavadoc This switch lacks documentation -Wlocal-hiding This switch lacks documentation -Wmasked-catch-block This switch lacks documentation -Wnls This switch lacks documentation -Wno-effect-assign This switch lacks documentation -Wnull This switch lacks documentation -Wout-of-date Warn if .class files are out of date -Wover-ann This switch lacks documentation -Wparam-assign This switch lacks documentation -Wpkg-default-method This switch lacks documentation -Wraw This switch lacks documentation -Wredundant-modifiers Warn if modifiers are specified when not necessary -Wserial This switch lacks documentation -Wspecial-param-hiding This switch lacks documentation -Wstatic-access This switch lacks documentation -Wstatic-receiver This switch lacks documentation -Wsuppress This switch lacks documentation -Wsynthetic-access This switch lacks documentation -Wtasks This switch lacks documentation -Wtype-hiding This switch lacks documentation -Wuncheck This switch lacks documentation -Wunnecessary-else This switch lacks documentation -Wunqualified-field This switch lacks documentation -Wunused-argument This switch lacks documentation -Wunused-import This switch lacks documentation -Wunused-label Warn when a label is unused -Wunused-local This switch lacks documentation -Wunused-private This switch lacks documentation -Wunused-thrown This switch lacks documentation -Wuseless-type-check This switch lacks documentation -Wvarargs-cast This switch lacks documentation -Wwarning-token This switch lacks documentation -bootclasspath This switch lacks documentation -classpath This switch lacks documentation -encoding This switch lacks documentation --CLASSPATH Deprecated; use --classpath instead -fassert Permit the use of the assert keyword -fassume-compiled This switch lacks documentation -fassume-compiled= This switch lacks documentation -faux-classpath This switch lacks documentation --bootclasspath= Replace system path -fbootstrap-classes Generated should be loaded by bootstrap loader -fcheck-references Generate checks for references to NULL --classpath= Set class path -fcompile-resource= This switch lacks documentation -fdisable-assertions This switch lacks documentation -fdisable-assertions= This switch lacks documentation -femit-class-file Output a class file -femit-class-files Alias for -femit-class-file -fenable-assertions This switch lacks documentation -fenable-assertions= This switch lacks documentation --encoding= Choose input encoding (defaults from your locale) --extdirs= Set the extension directory path -ffilelist-file Input file is a file with a list of filenames to compile -fforce-classes-archive-check Always check for non gcj generated classes archives -fhash-synchronization Assume the runtime uses a hash table to map an object to its synchronization structure -findirect-classes Generate instances of Class at runtime -findirect-dispatch Use offset tables for virtual method calls -finline-functions Integrate functions not declared "inline" into their callers when profitable -fjni Assume native functions are implemented using JNI -foptimize-static-class-initialization Enable optimization of static class initialization code -foutput-class-dir= This switch lacks documentation -freduced-reflection Reduce the amount of reflection meta-data generated -fsaw-java-file This switch lacks documentation -fsource-filename= This switch lacks documentation -fsource= Set the source language version -fstore-check Enable assignability checks for stores into object arrays -ftarget= Set the target VM version -fuse-atomic-builtins Generate code for built-in atomic operations -fuse-boehm-gc Generate code for the Boehm GC -fuse-divide-subroutine Call a library routine to do integer divisions -version Display the compiler's version The following options are specific to just the language LTO: -fltrans Run the link-time optimizer in local transformation (LTRANS) mode. -fltrans-output-list= Specify a file to which a list of files output by LTRANS is written. -fresolution= The resolution file -fwpa Run the link-time optimizer in whole program analysis (WPA) mode. -fwpa= Whole program analysis (WPA) mode with number of parallel jobs specified. The following options are specific to just the language ObjC: None found. Use --help=ObjC to show *all* the options supported by the ObjC front-end The following options are specific to just the language ObjC++: -fobjc-call-cxx-cdtors Generate special Objective-C methods to initialize/destroy non-POD C++ ivars, if needed
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 5 The following options are language-related: --all-warnings This switch lacks documentation --ansi This switch lacks documentation --assert This switch lacks documentation --assert= This switch lacks documentation --comments This switch lacks documentation --comments-in-macros This switch lacks documentation --define-macro This switch lacks documentation --define-macro= This switch lacks documentation --dependencies This switch lacks documentation --dump This switch lacks documentation --dump= This switch lacks documentation --imacros This switch lacks documentation --imacros= This switch lacks documentation --include This switch lacks documentation --include-barrier This switch lacks documentation --include-directory This switch lacks documentation --include-directory-after This switch lacks documentation --include-directory-after= This switch lacks documentation --include-directory= This switch lacks documentation --include-prefix This switch lacks documentation --include-prefix= This switch lacks documentation --include-with-prefix This switch lacks documentation --include-with-prefix-after This switch lacks documentation --include-with-prefix-after= This switch lacks documentation --include-with-prefix-before This switch lacks documentation --include-with-prefix-before= This switch lacks documentation --include-with-prefix= This switch lacks documentation --include= This switch lacks documentation --no-line-commands This switch lacks documentation --no-standard-includes This switch lacks documentation --no-standard-libraries This switch lacks documentation --no-warnings This switch lacks documentation --output This switch lacks documentation --output-pch= This switch lacks documentation --output= This switch lacks documentation --pedantic This switch lacks documentation --preprocess This switch lacks documentation --print-missing-file-dependencies This switch lacks documentation --trace-includes This switch lacks documentation --traditional-cpp This switch lacks documentation --trigraphs This switch lacks documentation --undefine-macro This switch lacks documentation --undefine-macro= This switch lacks documentation --user-dependencies This switch lacks documentation --verbose This switch lacks documentation --write-dependencies This switch lacks documentation --write-user-dependencies This switch lacks documentation -A= Assert the to . Putting '-' before disables the to -C Do not discard comments -CC Do not discard comments in macro expansions -D[=] Define a with as its value. If just is given, is taken to be 1 -E This switch lacks documentation -F Add to the end of the main framework include path -H Print the name of header files as they are used -I Add to the end of the main include path -M Generate make dependencies -MD Generate make dependencies and compile -MF Write dependency output to the given file -MG Treat missing header files as generated files -MM Like -M but ignore system header files -MMD Like -MD but ignore system header files -MP Generate phony targets for all headers -MQ Add a MAKE-quoted target -MT Add an unquoted target -P Do not generate #line directives -U Undefine -Wabi Warn about things that will change when compiling with an ABI-compliant compiler -Wabi-tag Warn if a subobject has an abi_tag attribute that the complete object type does not have -Wabi= Warn about things that change between the current -fabi-version and the specified version -Waddress Warn about suspicious uses of memory addresses -Wall Enable most warning messages -Wassign-intercept Warn whenever an Objective-C assignment is being intercepted by the garbage collector -Wbad-function-cast Warn about casting functions to incompatible types -Wbool-compare Warn about boolean expression compared with an integer value different from true/false -Wbuiltin-macro-redefined Warn when a built-in preprocessor macro is undefined or redefined -Wc++-compat Warn about C constructs that are not in the common subset of C and C++ -Wc++0x-compat Deprecated in favor of -Wc++11-compat -Wc++11-compat Warn about C++ constructs whose meaning differs between ISO C++ 1998 and ISO C++ 2011 -Wc++14-compat Warn about C++ constructs whose meaning differs between ISO C++ 2011 and ISO C++ 2014 -Wc90-c99-compat Warn about features not present in ISO C90, but present in ISO C99 -Wc99-c11-compat Warn about features not present in ISO C99, but present in ISO C11 -Wcast-qual Warn about casts which discard qualifiers -Wchar-subscripts Warn about subscripts whose type is "char" -Wchkp Warn about memory access errors found by Pointer Bounds Checker -Wclobbered Warn about variables that might be changed by "longjmp" or "vfork" -Wcomment Warn about possibly nested block comments, and C++ comments spanning more than one physical line -Wcomments Synonym for -Wcomment -Wconditionally-supported Warn for conditionally-supported constructs -Wconversion Warn for implicit type conversions that may change a value -Wconversion-null Warn for converting NULL from/to a non-pointer type -Wcpp Warn when a #warning directive is encountered -Wctor-dtor-privacy Warn when all constructors and destructors are private -Wdate-time Warn about __TIME__, __DATE__ and __TIMESTAMP__ usage -Wdeclaration-after-statement Warn when a declaration is found after a statement -Wdelete-incomplete Warn when deleting a pointer to incomplete type -Wdelete-non-virtual-dtor Warn about deleting polymorphic objects with non- virtual destructors -Wdeprecated Warn if a deprecated compiler feature, class, method, or field is used -Wdesignated-init Warn about positional initialization of structs requiring designated initializers -Wdiscarded-array-qualifiers Warn if qualifiers on arrays which are pointer targets are discarded -Wdiscarded-qualifiers Warn if type qualifiers on pointers are discarded -Wdiv-by-zero Warn about compile-time integer division by zero -Wdouble-promotion Warn about implicit conversions from "float" to "double" -Weffc++ Warn about violations of Effective C++ style rules -Wempty-body Warn about an empty body in an if or else statement -Wendif-labels Warn about stray tokens after #elif and #endif -Wenum-compare Warn about comparison of different enum types -Werror Treat all warnings as errors -Werror-implicit-function-declaration This switch is deprecated; use -Werror=implicit-function-declaration instead -Wfloat-conversion Warn for implicit type conversions that cause loss of floating point precision -Wfloat-equal Warn if testing floating point numbers for equality -Wformat Warn about printf/scanf/strftime/strfmon format string anomalies -Wformat-contains-nul Warn about format strings that contain NUL bytes -Wformat-extra-args Warn if passing too many arguments to a function for its format string -Wformat-nonliteral Warn about format strings that are not literals -Wformat-security Warn about possible security problems with format functions -Wformat-signedness Warn about sign differences with format functions -Wformat-y2k Warn about strftime formats yielding 2-digit years -Wformat-zero-length Warn about zero-length formats -Wformat= Warn about printf/scanf/strftime/strfmon format string anomalies -Wignored-qualifiers Warn whenever type qualifiers are ignored. -Wimplicit Warn about implicit declarations -Wimplicit-function-declaration Warn about implicit function declarations -Wimplicit-int Warn when a declaration does not specify a type -Wimport This switch lacks documentation -Wincompatible-pointer-types Warn when there is a conversion between pointers that have incompatible types -Winherited-variadic-ctor Warn about C++11 inheriting constructors when the base has a variadic constructor -Winit-self Warn about variables which are initialized to themselves -Wint-conversion Warn about incompatible integer to pointer and pointer to integer conversions -Wint-to-pointer-cast Warn when there is a cast to a pointer from an integer of a different size -Winvalid-offsetof Warn about invalid uses of the "offsetof" macro -Winvalid-pch Warn about PCH files that are found but not used -Wjump-misses-init Warn when a jump misses a variable initialization -Wliteral-suffix Warn when a string or character literal is followed by a ud-suffix which does not begin with an underscore. -Wlogical-not-parentheses Warn when logical not is used on the left hand side operand of a comparison -Wlogical-op Warn when a logical operator is suspiciously always evaluating to true or false -Wlong-long Do not warn about using "long long" when -pedantic -Wmain Warn about suspicious declarations of "main" -Wmaybe-uninitialized Warn about maybe uninitialized automatic variables -Wmemset-transposed-args Warn about suspicious calls to memset where the third argument is constant literal zero and the second is not -Wmissing-braces Warn about possibly missing braces around initializers -Wmissing-declarations Warn about global functions without previous declarations -Wmissing-field-initializers Warn about missing fields in struct initializers -Wmissing-format-attribute This switch lacks documentation -Wmissing-include-dirs Warn about user-specified include directories that do not exist -Wmissing-parameter-type Warn about function parameters declared without a type specifier in K&R-style functions -Wmissing-prototypes Warn about global functions without prototypes -Wmudflap This switch lacks documentation -Wmultichar Warn about use of multi-character character constants -Wnarrowing Warn about narrowing conversions within { } that are ill-formed in C++11 -Wnested-externs Warn about "extern" declarations not at file scope -Wnoexcept Warn when a noexcept expression evaluates to false even though the expression can't actually throw -Wnon-template-friend Warn when non-templatized friend functions are declared within a template -Wnon-virtual-dtor Warn about non-virtual destructors -Wnonnull Warn about NULL being passed to argument slots marked as requiring non-NULL -Wnormalized This switch lacks documentation -Wnormalized= Warn about non-normalised Unicode strings -Wold-style-cast Warn if a C-style cast is used in a program -Wold-style-declaration Warn for obsolescent usage in a declaration -Wold-style-definition Warn if an old-style parameter definition is used -Wopenmp-simd Warn if a simd directive is overridden by the vectorizer cost model -Woverlength-strings Warn if a string is longer than the maximum portable length specified by the standard -Woverloaded-virtual Warn about overloaded virtual function names -Woverride-init Warn about overriding initializers without side effects -Wpacked-bitfield-compat Warn about packed bit-fields whose offset changed in GCC 4.4 -Wparentheses Warn about possibly missing parentheses -Wpedantic Issue warnings needed for strict compliance to the standard -Wpedantic-ms-format Warn about none ISO msvcrt scanf/printf width extensions -Wpmf-conversions Warn when converting the type of pointers to member functions -Wpointer-arith Warn about function pointer arithmetic -Wpointer-sign Warn when a pointer differs in signedness in an assignment -Wpointer-to-int-cast Warn when a pointer is cast to an integer of a different size -Wpragmas Warn about misuses of pragmas -Wproperty-assign-default Warn if a property for an Objective-C object has no assign semantics specified -Wprotocol Warn if inherited methods are unimplemented -Wpsabi This switch lacks documentation -Wredundant-decls Warn about multiple declarations of the same object -Wreorder Warn when the compiler reorders code -Wreturn-type Warn whenever a function's return type defaults to "int" (C), or about inconsistent return types (C++) -Wselector Warn if a selector has multiple methods -Wsequence-point Warn about possible violations of sequence point rules -Wshadow-ivar Warn if a local declaration hides an instance variable -Wshift-count-negative Warn if shift count is negative -Wshift-count-overflow Warn if shift count >= width of type -Wsign-compare Warn about signed-unsigned comparisons -Wsign-conversion Warn for implicit type conversions between signed and unsigned integers -Wsign-promo Warn when overload promotes from unsigned to signed -Wsized-deallocation Warn about missing sized deallocation functions -Wsizeof-array-argument Warn when sizeof is applied on a parameter declared as an array -Wsizeof-pointer-memaccess Warn about suspicious length parameters to certain string functions if the argument uses sizeof -Wstrict-aliasing= Warn about code which might break strict aliasing rules -Wstrict-null-sentinel Warn about uncasted NULL used as sentinel -Wstrict-overflow= Warn about optimizations that assume that signed overflow is undefined -Wstrict-prototypes Warn about unprototyped function declarations -Wstrict-selector-match Warn if type signatures of candidate methods do not match exactly -Wsuggest-attribute=format Warn about functions which might be candidates for format attributes -Wsuggest-override Suggest that the override keyword be used when the declaration of a virtual function overrides another. -Wswitch Warn about enumerated switches, with no default, missing a case -Wswitch-bool Warn about switches with boolean controlling expression -Wswitch-default Warn about enumerated switches missing a "default:" statement -Wswitch-enum Warn about all enumerated switches missing a specific case -Wsync-nand Warn when __sync_fetch_and_nand and __sync_nand_and_fetch built-in functions are used -Wsynth Deprecated. This switch has no effect -Wsystem-headers Do not suppress warnings from system headers -Wtraditional Warn about features not present in traditional C -Wtraditional-conversion Warn of prototypes causing type conversions different from what would happen in the absence of prototype -Wtrigraphs Warn if trigraphs are encountered that might affect the meaning of the program -Wundeclared-selector Warn about @selector()s without previously declared methods -Wundef Warn if an undefined macro is used in an #if directive -Wuninitialized Warn about uninitialized automatic variables -Wunknown-pragmas Warn about unrecognized pragmas -Wunsuffixed-float-constants Warn about unsuffixed float constants -Wunused Enable all -Wunused- warnings -Wunused-local-typedefs Warn when typedefs locally defined in a function are not used -Wunused-macros Warn about macros defined in the main file that are not used -Wunused-result Warn if a caller of a function, marked with attribute warn_unused_result, does not use its return value -Wuseless-cast Warn about useless casts -Wvarargs Warn about questionable usage of the macros used to retrieve variable arguments -Wvariadic-macros Warn about using variadic macros -Wvirtual-move-assign Warn if a virtual base has a non-trivial move assignment operator -Wvla Warn if a variable length array is used -Wvolatile-register-var Warn when a register variable is declared volatile -Wwrite-strings In C++, nonzero means warn about deprecated conversion from string literals to 'char *'. In C, similar warning, except that the conversion is of course not deprecated by the ISO C standard. -Wzero-as-null-pointer-constant Warn when a literal '0' is used as null pointer
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 6 -ansi A synonym for -std=c89 (for C) or -std=c++98 (for C++) -d Enable dumps from specific passes of the compiler -fRTS= Select the runtime -fabi-compat-version= The version of the C++ ABI used for -Wabi warnings and link compatibility aliases -faccess-control Enforce class member access control semantics -fada-spec-parent= -fada-spec-parent=unit Dump Ada specs as child units of given parent -fall-virtual This switch lacks documentation -fallow-parameterless-variadic-functions Allow variadic functions without named parameter -falt-external-templates No longer supported -fasm Recognize the "asm" keyword -fbuilding-libgcc This switch lacks documentation -fbuiltin Recognize built-in functions -fbuiltin- This switch lacks documentation -fcanonical-system-headers Where shorter, use canonicalized paths to systems headers. -fcheck-pointer-bounds Add Pointer Bounds Checker instrumentation. fchkp-* flags are used to control instrumentation. Currently available for C, C++ and ObjC. -fchkp-check-incomplete-type Generate pointer bounds checks for variables with incomplete type -fchkp-check-read Generate checks for all read accesses to memory. -fchkp-check-write Generate checks for all write accesses to memory. -fchkp-first-field-has-own-bounds Forces Pointer Bounds Checker to use narrowed bounds for address of the first field in the structure. By default pointer to the first field has the same bounds as pointer to the whole structure. -fchkp-instrument-calls Generate bounds passing for calls. -fchkp-instrument-marked-only Instrument only functions marked with bnd_instrument attribute. -fchkp-narrow-bounds Control how Pointer Bounds Checker handle pointers to object fields. When narrowing is on, field bounds are used. Otherwise full object bounds are used. -fchkp-narrow-to-innermost-array Forces Pointer Bounds Checker to use bounds of the innermost arrays in case of nested static arryas access. By default outermost array is used. -fchkp-optimize Allow Pointer Bounds Checker optimizations. By default allowed on optimization levels >0. -fchkp-store-bounds Generate bounds stores for pointer writes. -fchkp-treat-zero-dynamic-size-as-infinite With this option zero size obtained dynamically for objects with incomplete type will be treated as infinite. -fchkp-use-fast-string-functions Allow to use *_nobnd versions of string functions by Pointer Bounds Checker. -fchkp-use-nochk-string-functions Allow to use *_nochk versions of string functions by Pointer Bounds Checker. -fchkp-use-static-bounds Use statically initialized variable for vars bounds instead of generating them each time it is required. -fchkp-use-static-const-bounds Use statically initialized variable for constant bounds instead of generating them each time it is required. -fchkp-use-wrappers Transform instrumented builtin calls into calls to wrappers. -fchkp-zero-input-bounds-for-main Use zero bounds for all incoming arguments in 'main' function. It helps when instrumented binaries are used with legacy libs. -fcilkplus Enable Cilk Plus -fcond-mismatch Allow the arguments of the '?' operator to have different types -fconserve-space Does nothing. Preserved for backward compatibility. -fconst-string-class= Use class for constant strings -fconstexpr-depth= Specify maximum constexpr recursion depth -fdebug-cpp Emit debug annotations during preprocessing -fdeclone-ctor-dtor Factor complex constructors and destructors to favor space over speed -fdeduce-init-list enable deduction of std::initializer_list for a template type parameter from a brace-enclosed initializer-list -fdefault-inline Does nothing. Preserved for backward compatibility. -fdirectives-only Preprocess directives only. -fdollars-in-identifiers Permit '$' as an identifier character -fdump-ada-spec Write all declarations as Ada code transitively -fdump-ada-spec-slim Write all declarations as Ada code for the given file only -felide-constructors This switch lacks documentation -femit-struct-debug-baseonly Aggressive reduced debug info for structs -femit-struct-debug-detailed= Detailed reduced debug info for structs -femit-struct-debug-reduced Conservative reduced debug info for structs -fenforce-eh-specs Generate code to check exception specifications -fenum-int-equiv This switch lacks documentation -fexec-charset= Convert all strings and character constants to character set -fext-numeric-literals Interpret imaginary, fixed-point, or other gnu number suffix as the corresponding number literal rather than a user-defined number literal. -fextended-identifiers Permit universal character names (\u and \U) in identifiers -fextern-tls-init Support dynamic initialization of thread-local variables in a different translation unit -fexternal-templates This switch lacks documentation -ffor-scope Scope of for-init-statement variables is local to the loop -ffreestanding Do not assume that standard C libraries and "main" exist -ffriend-injection Inject friend functions into enclosing namespace -fgnu-keywords Recognize GNU-defined keywords -fgnu-runtime Generate code for GNU runtime environment -fgnu89-inline Use traditional GNU semantics for inline functions -fguiding-decls This switch lacks documentation -fhandle-exceptions This switch lacks documentation -fhonor-std This switch lacks documentation -fhosted Assume normal C execution environment -fhuge-objects No longer supported -fimplement-inlines Export functions even if they can be inlined -fimplicit-inline-templates Emit implicit instantiations of inline templates -fimplicit-templates Emit implicit instantiations of templates -finput-charset= Specify the default character set for source files -fvisibility=[private|protected|public|package] Set the default symbol visibility -fkeep-inline-dllexport Don't emit dllexported inline functions unless needed -flabels-ok This switch lacks documentation -flax-vector-conversions Allow implicit conversions between vectors with differing numbers of subparts and/or differing element types. -flocal-ivars Allow access to instance variables as if they were local declarations within instance method implementations. -fms-extensions Don't warn about uses of Microsoft extensions -fmudflap This switch lacks documentation -fmudflapir This switch lacks documentation -fmudflapth This switch lacks documentation -fname-mangling-version- This switch lacks documentation -fnew-abi This switch lacks documentation -fnext-runtime Generate code for NeXT (Apple Mac OS X) runtime environment -fnil-receivers Assume that receivers of Objective-C messages may be nil -fnonansi-builtins This switch lacks documentation -fnonnull-objects This switch lacks documentation -fnothrow-opt Treat a throw() exception specification as noexcept to improve code size -fobjc-abi-version= Specify which ABI to use for Objective-C family code and meta-data generation. -fobjc-direct-dispatch Allow fast jumps to the message dispatcher -fobjc-exceptions Enable Objective-C exception and synchronization syntax -fobjc-gc Enable garbage collection (GC) in Objective-C/ Objective-C++ programs -fobjc-nilcheck Enable inline checks for nil receivers with the NeXT runtime and ABI version 2. -fobjc-sjlj-exceptions Enable Objective-C setjmp exception handling runtime -fobjc-std=objc1 Conform to the Objective-C 1.0 language as implemented in GCC 4.0 -fopenacc Enable OpenACC -fopenmp Enable OpenMP (implies -frecursive in Fortran) -fopenmp-simd Enable OpenMP's SIMD directives -foperator-names Recognize C++ keywords like "compl" and "xor" -foptional-diags Does nothing. Preserved for backward compatibility. -fpch-deps This switch lacks documentation -fpch-preprocess Look for and use PCH files even when preprocessing -fpermissive Downgrade conformance errors to warnings -fplan9-extensions Enable Plan 9 language extensions -fpreprocessed Treat the input file as already preprocessed -fpretty-templates -fno-pretty-templates Do not pretty-print template specializations as the template signature followed by the arguments -freplace-objc-classes Used in Fix-and-Continue mode to indicate that object files may be swapped in at runtime -frepo Enable automatic template instantiation -frtti Generate run time type descriptor information -fshort-double Use the same size for double as for float -fshort-enums Use the narrowest integer type possible for enumeration types -fshort-wchar Force the underlying type for "wchar_t" to be "unsigned short" -fsigned-bitfields When "signed" or "unsigned" is not given make the bitfield signed -fsigned-char Make "char" signed by default -fsized-deallocation Enable C++14 sized deallocation support -fsquangle This switch lacks documentation -fstats Display statistics accumulated during compilation -fstrict-enums Assume that values of enumeration type are always within the minimum range of that type -fstrict-prototype This switch lacks documentation -ftabstop= Distance between tab stops for column reporting -ftemplate-backtrace-limit= Set the maximum number of template instantiation notes for a single warning or error -ftemplate-depth- This switch lacks documentation -ftemplate-depth= Specify maximum template instantiation depth -fthis-is-variable This switch lacks documentation -fno-threadsafe-statics Do not generate thread-safe code for initializing local statics -ftrack-macro-expansion This switch lacks documentation -ftrack-macro-expansion= -ftrack-macro-expansion=<0|1|2> Track locations of tokens coming from macro expansion and display them in error messages -funsigned-bitfields When "signed" or "unsigned" is not given make the bitfield unsigned -funsigned-char Make "char" unsigned by default -fuse-cxa-atexit Use __cxa_atexit to register destructors -fuse-cxa-get-exception-ptr Use __cxa_get_exception_ptr in exception handling -fvisibility-inlines-hidden Marks all inlined functions and methods as having hidden visibility -fvisibility-ms-compat Changes visibility to match Microsoft Visual Studio by default -fvtable-gc No longer supported -fvtable-thunks No longer supported -fweak Emit common-like symbols as weak symbols -fwide-exec-charset= Convert all wide strings and character constants to character set -fworking-directory Generate a #line directive pointing at the current working directory -fxref No longer supported -fzero-link Generate lazy class lookup (via objc_getClass()) for use in Zero-Link mode
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 7 -gant Catch typos -gen-decls Dump declarations to a .decl file -gnat Specify options to GNAT -gnatO Set name of output ALI file (internal switch) -idirafter Add to the end of the system include path -imacros Accept definition of macros in -imultilib Set to be the multilib include subdirectory -include Include the contents of before other files -iprefix Specify as a prefix for next two options -iquote Add to the end of the quote include path -isysroot Set to be the system root directory -isystem Add to the start of the system include path -iwithprefix Add to the end of the system include path -iwithprefixbefore Add to the end of the main include path -nostdinc Do not search standard system include directories (those specified with -isystem will still be used) -nostdinc++ Do not search standard system include directories for C++ -nostdlib Do not look for object files in standard path -o Place output into -pedantic This switch lacks documentation -print-objc-runtime-info Generate C header of platform-specific features -remap Remap file names when including files -std=c++03 Conform to the ISO 1998 C++ standard revised by the 2003 technical corrigendum -std=c++0x Deprecated in favor of -std=c++11 -std=c++11 Conform to the ISO 2011 C++ standard -std=c++14 Conform to the ISO 2014 C++ standard (experimental and incomplete support) -std=c++17 This switch lacks documentation -std=c++1y Deprecated in favor of -std=c++14 -std=c++1z Conform to the ISO 2017(?) C++ draft standard (experimental and incomplete support) -std=c++98 Conform to the ISO 1998 C++ standard revised by the 2003 technical corrigendum -std=c11 Conform to the ISO 2011 C standard (experimental and incomplete support) -std=c1x Deprecated in favor of -std=c11 -std=c89 Conform to the ISO 1990 C standard -std=c90 Conform to the ISO 1990 C standard -std=c99 Conform to the ISO 1999 C standard -std=c9x Deprecated in favor of -std=c99 -std=gnu++03 Conform to the ISO 1998 C++ standard revised by the 2003 technical corrigendum with GNU extensions -std=gnu++0x Deprecated in favor of -std=gnu++11 -std=gnu++11 Conform to the ISO 2011 C++ standard with GNU extensions (experimental and incomplete support) -std=gnu++14 Conform to the ISO 2014 C++ standard with GNU extensions (experimental and incomplete support) -std=gnu++17 This switch lacks documentation -std=gnu++1y This switch lacks documentation -std=gnu++1z Conform to the ISO 201z(7?) C++ draft standard with GNU extensions (experimental and incomplete support) -std=gnu++98 Conform to the ISO 1998 C++ standard revised by the 2003 technical corrigendum with GNU extensions -std=gnu11 Conform to the ISO 2011 C standard with GNU extensions (experimental and incomplete support) -std=gnu1x Deprecated in favor of -std=gnu11 -std=gnu89 Conform to the ISO 1990 C standard with GNU extensions -std=gnu90 Conform to the ISO 1990 C standard with GNU extensions -std=gnu99 Conform to the ISO 1999 C standard with GNU extensions -std=gnu9x Deprecated in favor of -std=gnu99 -std=iso9899:1990 Conform to the ISO 1990 C standard -std=iso9899:199409 Conform to the ISO 1990 C standard as amended in 1994 -std=iso9899:1999 Conform to the ISO 1999 C standard -std=iso9899:199x Deprecated in favor of -std=iso9899:1999 -std=iso9899:2011 Conform to the ISO 2011 C standard (experimental and incomplete support) -traditional-cpp Enable traditional preprocessing -trigraphs Support ISO C trigraphs -undef Do not predefine system-specific and GCC-specific macros -v Enable verbose output -w Suppress warnings
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 8 The --param option recognizes the following as parameters: predictable-branch-outcome Maximal estimated outcome of branch considered predictable inline-min-speedup The minimal estimated speedup allowing inliner to ignore inline-insns-single and inline-isnsns-auto max-inline-insns-single The maximum number of instructions in a single function eligible for inlining max-inline-insns-auto The maximum number of instructions when automatically inlining max-inline-insns-recursive The maximum number of instructions inline function can grow to via recursive inlining max-inline-insns-recursive-auto The maximum number of instructions non-inline function can grow to via recursive inlining max-inline-recursive-depth The maximum depth of recursive inlining for inline functions max-inline-recursive-depth-auto The maximum depth of recursive inlining for non-inline functions min-inline-recursive-probability Inline recursively only when the probability of call being executed exceeds the parameter max-early-inliner-iterations The maximum number of nested indirect inlining performed by early inliner comdat-sharing-probability Probability that COMDAT function will be shared with different compilation unit partial-inlining-entry-probability Maximum probability of the entry BB of split region (in percent relative to entry BB of the function) to make partial inlining happen max-variable-expansions-in-unroller If -fvariable-expansion-in-unroller is used, the maximum number of times that an individual variable will be expanded during loop unrolling min-vect-loop-bound If -ftree-vectorize is used, the minimal loop bound of a loop to be considered for vectorization max-delay-slot-insn-search The maximum number of instructions to consider to fill a delay slot max-delay-slot-live-search The maximum number of instructions to consider to find accurate live register information max-pending-list-length The maximum length of scheduling's pending operations list max-modulo-backtrack-attempts The maximum number of backtrack attempts the scheduler should make when modulo scheduling a loop large-function-insns The size of function body to be considered large large-function-growth Maximal growth due to inlining of large function (in percent) large-unit-insns The size of translation unit to be considered large inline-unit-growth How much can given compilation unit grow because of the inlining (in percent) ipcp-unit-growth How much can given compilation unit grow because of the interprocedural constant propagation (in percent) early-inlining-insns Maximal estimated growth of function body caused by early inlining of single call large-stack-frame The size of stack frame to be considered large large-stack-frame-growth Maximal stack frame growth due to inlining (in percent) max-gcse-memory The maximum amount of memory to be allocated by GCSE max-gcse-insertion-ratio The maximum ratio of insertions to deletions of expressions in GCSE gcse-after-reload-partial-fraction The threshold ratio for performing partial redundancy elimination after reload gcse-after-reload-critical-fraction The threshold ratio of critical edges execution count that permit performing redundancy elimination after reload gcse-cost-distance-ratio Scaling factor in calculation of maximum distance an expression can be moved by GCSE optimizations gcse-unrestricted-cost Cost at which GCSE optimizations will not constraint the distance an expression can travel max-hoist-depth Maximum depth of search in the dominator tree for expressions to hoist max-unrolled-insns The maximum number of instructions to consider to unroll in a loop max-average-unrolled-insns The maximum number of instructions to consider to unroll in a loop on average max-unroll-times The maximum number of unrollings of a single loop max-peeled-insns The maximum number of insns of a peeled loop max-peel-times The maximum number of peelings of a single loop max-peel-branches The maximum number of branches on the path through the peeled sequence max-completely-peeled-insns The maximum number of insns of a completely peeled loop max-completely-peel-times The maximum number of peelings of a single loop that is peeled completely max-once-peeled-insns The maximum number of insns of a peeled loop that rolls only once max-completely-peel-loop-nest-depth The maximum depth of a loop nest we completely peel max-unswitch-insns The maximum number of insns of an unswitched loop max-unswitch-level The maximum number of unswitchings in a single loop max-iterations-to-track Bound on the number of iterations the brute force # of iterations analysis algorithm evaluates max-iterations-computation-cost Bound on the cost of an expression to compute the number of iterations sms-max-ii-factor A factor for tuning the upper bound that swing modulo scheduler uses for scheduling a loop sms-min-sc The minimum value of stage count that swing modulo scheduler will generate. sms-dfa-history The number of cycles the swing modulo scheduler considers when checking conflicts using DFA sms-loop-average-count-threshold A threshold on the average loop count considered by the swing modulo scheduler hot-bb-count-ws-permille A basic block profile count is considered hot if it contributes to the given permillage of the entire profiled execution hot-bb-frequency-fraction Select fraction of the maximal frequency of executions of basic block in function given basic block needs to have to be considered hot unlikely-bb-count-fraction The minimum fraction of profile runs a given basic block execution count must be not to be considered unlikely align-threshold Select fraction of the maximal frequency of executions of basic block in function given basic block get alignment align-loop-iterations Loops iterating at least selected number of iterations will get loop alignement. max-predicted-iterations The maximum number of loop iterations we predict statically builtin-expect-probability Set the estimated probability in percentage for builtin expect. The default value is 90% probability. tracer-dynamic-coverage-feedback The percentage of function, weighted by execution frequency, that must be covered by trace formation. Used when profile feedback is available tracer-dynamic-coverage The percentage of function, weighted by execution frequency, that must be covered by trace formation. Used when profile feedback is not available tracer-max-code-growth Maximal code growth caused by tail duplication (in percent) tracer-min-branch-ratio Stop reverse growth if the reverse probability of best edge is less than this threshold (in percent) tracer-min-branch-probability-feedback Stop forward growth if the probability of best edge is less than this threshold (in percent). Used when profile feedback is available tracer-min-branch-probability Stop forward growth if the probability of best edge is less than this threshold (in percent). Used when profile feedback is not available max-crossjump-edges The maximum number of incoming edges to consider for crossjumping min-crossjump-insns The minimum number of matching instructions to consider for crossjumping max-grow-copy-bb-insns The maximum expansion factor when copying basic blocks max-goto-duplication-insns The maximum number of insns to duplicate when unfactoring computed gotos max-cse-path-length The maximum length of path considered in cse max-cse-insns The maximum instructions CSE process before flushing lim-expensive The minimum cost of an expensive expression in the loop invariant motion iv-consider-all-candidates-bound Bound on number of candidates below that all candidates are considered in iv optimizations iv-max-considered-uses Bound on number of iv uses in loop optimized in iv optimizations iv-always-prune-cand-set-bound If number of candidates in the set is smaller, we always try to remove unused ivs during its optimization scev-max-expr-size Bound on size of expressions used in the scalar evolutions analyzer scev-max-expr-complexity Bound on the complexity of the expressions in the scalar evolutions analyzer omega-max-vars Bound on the number of variables in Omega constraint systems omega-max-geqs Bound on the number of inequalities in Omega constraint systems omega-max-eqs Bound on the number of equalities in Omega constraint systems omega-max-wild-cards Bound on the number of wild cards in Omega constraint systems omega-hash-table-size Bound on the size of the hash table in Omega constraint systems omega-max-keys Bound on the number of keys in Omega constraint systems omega-eliminate-redundant-constraints When set to 1, use expensive methods to eliminate all redundant constraints vect-max-version-for-alignment-checks Bound on number of runtime checks inserted by the vectorizer's loop versioning for alignment check vect-max-version-for-alias-checks Bound on number of runtime checks inserted by the vectorizer's loop versioning for alias check vect-max-peeling-for-alignment Max number of loop peels to enhancement alignment of data references in a loop max-cselib-memory-locations The maximum memory locations recorded by cselib ggc-min-expand Minimum heap expansion to trigger garbage collection, as a percentage of the total size of the heap ggc-min-heapsize Minimum heap size before we start collecting garbage, in kilobytes
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 9 max-reload-search-insns The maximum number of instructions to search backward when looking for equivalent reload sink-frequency-threshold Target block's relative execution frequency (as a percentage) required to sink a statement max-sched-region-blocks The maximum number of blocks in a region to be considered for interblock scheduling max-sched-region-insns The maximum number of insns in a region to be considered for interblock scheduling max-pipeline-region-blocks The maximum number of blocks in a region to be considered for interblock scheduling max-pipeline-region-insns The maximum number of insns in a region to be considered for interblock scheduling min-spec-prob The minimum probability of reaching a source block for interblock speculative scheduling max-sched-extend-regions-iters The maximum number of iterations through CFG to extend regions max-sched-insn-conflict-delay The maximum conflict delay for an insn to be considered for speculative motion sched-spec-prob-cutoff The minimal probability of speculation success (in percents), so that speculative insn will be scheduled. sched-state-edge-prob-cutoff The minimum probability an edge must have for the scheduler to save its state across it. selsched-max-lookahead The maximum size of the lookahead window of selective scheduling selsched-max-sched-times Maximum number of times that an insn could be scheduled selsched-insns-to-rename Maximum number of instructions in the ready list that are considered eligible for renaming sched-mem-true-dep-cost Minimal distance between possibly conflicting store and load sched-autopref-queue-depth Hardware autoprefetcher scheduler model control flag. Number of lookahead cycles the model looks into; at '0' only enable instruction sorting heuristic. Disabled by default. max-last-value-rtl The maximum number of RTL nodes that can be recorded as combiner's last value max-combine-insns The maximum number of insns combine tries to combine integer-share-limit The upper bound for sharing integer constants ssp-buffer-size The lower bound for a buffer to be considered for stack smashing protection min-size-for-stack-sharing The minimum size of variables taking part in stack slot sharing when not optimizing max-jump-thread-duplication-stmts Maximum number of statements allowed in a block that needs to be duplicated when threading jumps max-fields-for-field-sensitive Maximum number of fields in a structure before pointer analysis treats the structure as a single variable max-sched-ready-insns The maximum number of instructions ready to be issued to be considered by the scheduler during the first scheduling pass max-dse-active-local-stores Maximum number of active local stores in RTL dead store elimination prefetch-latency The number of insns executed before prefetch is completed simultaneous-prefetches The number of prefetches that can run at the same time l1-cache-size The size of L1 cache l1-cache-line-size The size of L1 cache line l2-cache-size The size of L2 cache use-canonical-types Whether to use canonical types max-partial-antic-length Maximum length of partial antic set when performing tree pre optimization sccvn-max-scc-size Maximum size of a SCC before SCCVN stops processing a function sccvn-max-alias-queries-per-access Maximum number of disambiguations to perform per memory access ira-max-loops-num Max loops number for regional RA ira-max-conflict-table-size Max size of conflict table in MB ira-loop-reserved-regs The number of registers in each class kept unused by loop invariant motion lra-max-considered-reload-pseudos The max number of reload pseudos which are considered during spilling a non-reload pseudo lra-inheritance-ebb-probability-cutoff Minimal fall-through edge probability in percentage used to add BB to inheritance EBB in LRA switch-conversion-max-branch-ratio The maximum ratio between array size and switch branches for a switch conversion to take place loop-block-tile-size size of tiles for loop blocking loop-unroll-jam-size size of unrolling factor for unroll-and-jam loop-unroll-jam-depth depth of unrolled loop for unroll-and-jam graphite-max-nb-scop-params maximum number of parameters in a SCoP graphite-max-bbs-per-function maximum number of basic blocks per function to be analyzed by Graphite loop-max-datarefs-for-datadeps Maximum number of datarefs in loop for building loop data dependencies loop-invariant-max-bbs-in-loop Max basic blocks number in loop for loop invariant motion profile-func-internal-id use internal function id in profile lookup indir-call-topn-profile track topn target addresses in indirect-call profile slp-max-insns-in-bb Maximum number of instructions in basic block to be considered for SLP vectorization min-insn-to-prefetch-ratio Min. ratio of insns to prefetches to enable prefetching for a loop with an unknown trip count prefetch-min-insn-to-mem-ratio Min. ratio of insns to mem ops to enable prefetching in a loop max-vartrack-size Max. size of var tracking hash tables max-vartrack-expr-depth Max. recursion depth for expanding var tracking expressions max-vartrack-reverse-op-size Max. size of loc list for which reverse ops should be added min-nondebug-insn-uid The minimum UID to be used for a nondebug insn ipa-sra-ptr-growth-factor Maximum allowed growth of size of new parameters ipa-sra replaces a pointer to an aggregate with tm-max-aggregate-size Size in bytes after which thread-local aggregates should be instrumented with the logging functions instead of save/restore pairs sra-max-scalarization-size-Ospeed Maximum size, in storage units, of an aggregate which should be considered for scalarization when compiling for speed sra-max-scalarization-size-Osize Maximum size, in storage units, of an aggregate which should be considered for scalarization when compiling for size ipa-cp-value-list-size Maximum size of a list of values associated with each parameter for interprocedural constant propagation ipa-cp-eval-threshold Threshold ipa-cp opportunity evaluation that is still considered beneficial to clone. ipa-cp-recursion-penalty Percentage penalty the recursive functions will receive when they are evaluated for cloning. ipa-cp-single-call-penalty Percentage penalty functions containg a single call to another function will receive when they are evaluated for cloning. ipa-max-agg-items Maximum number of aggregate content items for a parameter in jump functions and lattices ipa-cp-loop-hint-bonus Compile-time bonus IPA-CP assigns to candidates which make loop bounds or strides known. ipa-cp-array-index-hint-bonus Compile-time bonus IPA-CP assigns to candidates which make an array index known. ipa-max-aa-steps Maximum number of statements that will be visited by IPA formal parameter analysis based on alias analysis in any given function lto-partitions Number of partitions the program should be split to lto-min-partition Minimal size of a partition for LTO (in estimated instructions) cxx-max-namespaces-for-diagnostic-help Maximum number of namespaces to search for alternatives when name lookup fails max-stores-to-sink Maximum number of conditional store pairs that can be sunk case-values-threshold The smallest number of different values for which it is best to use a jump-table instead of a tree of conditional branches, if 0, use the default for the machine allow-store-data-races Allow new data races on stores to be introduced tree-reassoc-width Set the maximum number of instructions executed in parallel in reassociated tree. If 0, use the target dependent heuristic. max-tail-merge-comparisons Maximum amount of similar bbs to compare a bb with max-tail-merge-iterations Maximum amount of iterations of the pass over a function max-tracked-strlens Maximum number of strings for which strlen optimization pass will track string lengths sched-pressure-algorithm Which -fsched-pressure algorithm to apply max-slsr-cand-scan Maximum length of candidate scans for straight- line strength reduction asan-stack Enable asan stack protection asan-globals Enable asan globals protection asan-instrument-writes Enable asan store operations protection asan-instrument-reads Enable asan load operations protection asan-memintrin Enable asan builtin functions protection asan-use-after-return Enable asan detection of use-after-return bugs asan-instrumentation-with-call-threshold Use callbacks instead of inline code if number of accesses in function becomes greater or equal to this number uninit-control-dep-attempts Maximum number of nested calls to search for control dependencies during uninitialized variable analysis chkp-max-ctor-size Maximum number of statements to be included into a single static constructor generated by Pointer Bounds Checker max-fsm-thread-path-insns Maximum number of instructions to copy when duplicating blocks on a finite state automaton jump thread path max-fsm-thread-length Maximum number of basic blocks on a finite state automaton jump thread path max-fsm-thread-paths Maximum number of new jump thread paths to create for a finite state automaton
SergeyKostrov
Valued Contributor II
MinGW v5.1.0 64-bit Options - Group 10 The following options control compiler warning messages: --extra-warnings This switch lacks documentation -W This switch is deprecated; use -Wextra instead -Waggregate-return Warn about returning structures, unions or arrays -Waggressive-loop-optimizations Warn if a loop with constant number of iterations triggers undefined behavior -Warray-bounds Warn if an array is accessed out of bounds -Warray-bounds= Warn if an array is accessed out of bounds -Wattributes Warn about inappropriate attribute usage -Wcast-align Warn about pointer casts which increase alignment -Wcoverage-mismatch Warn in case profiles in -fprofile-use do not match -Wdeprecated-declarations Warn about uses of __attribute__((deprecated)) declarations -Wdisabled-optimization Warn when an optimization pass is disabled -Wfree-nonheap-object Warn when attempting to free a non-heap object -Winline Warn when an inlined function cannot be inlined -Winvalid-memory-model Warn when an atomic memory model parameter is known to be outside the valid range. -Wlarger-than- This switch lacks documentation -Wlarger-than= Warn if an object is larger than bytes -Wodr Warn about some C++ One Definition Rule violations during link time optimization -Woverflow Warn about overflow in arithmetic expressions -Wpacked Warn when the packed attribute has no effect on struct layout -Wpadded Warn when padding is required to align structure members -Wreturn-local-addr Warn about returning a pointer/reference to a local or temporary variable. -Wshadow Warn when one local variable shadows another -Wstack-protector Warn when not issuing stack smashing protection for some reason -Wstack-usage= Warn if stack usage might be larger than specified amount -Wstrict-aliasing Warn about code which might break strict aliasing rules -Wstrict-overflow Warn about optimizations that assume that signed overflow is undefined -Wsuggest-attribute=const Warn about functions which might be candidates for __attribute__((const)) -Wsuggest-attribute=noreturn Warn about functions which might be candidates for __attribute__((noreturn)) -Wsuggest-attribute=pure Warn about functions which might be candidates for __attribute__((pure)) -Wsuggest-final-methods Warn about C++ virtual methods where adding final keyword would improve code quality -Wsuggest-final-types Warn about C++ polymorphic types where adding final keyword would improve code quality -Wtrampolines Warn whenever a trampoline is generated -Wtype-limits Warn if a comparison is always true or always false due to the limited range of the data type -Wunsafe-loop-optimizations Warn if the loop cannot be optimized due to nontrivial assumptions. -Wunused-but-set-parameter Warn when a function parameter is only set, otherwise unused -Wunused-but-set-variable Warn when a variable is only set, otherwise unused -Wunused-function Warn when a function is unused -Wunused-parameter Warn when a function parameter is unused -Wunused-value Warn when an expression value is unused -Wunused-variable Warn when a variable is unused -Wvector-operation-performance Warn when a vector operation is compiled outside the SIMD
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 11 The following options control optimizations: -O Set optimization level to -Ofast Optimize for speed disregarding exact standards compliance -Og Optimize for debugging experience rather than speed or size -Os Optimize for space rather than speed -faggressive-loop-optimizations Aggressively optimize loops using language constraints -falign-functions Align the start of functions -falign-jumps Align labels which are only reached by jumping -falign-labels Align all labels -falign-loops Align the start of loops -fassociative-math Allow optimization for floating-point arithmetic which may change the result of the operation due to rounding. -fasynchronous-unwind-tables Generate unwind tables that are exact at each instruction boundary -fauto-inc-dec Generate auto-inc/dec instructions -fbranch-count-reg Replace add, compare, branch with branch on count register -fbranch-probabilities Use profiling information for branch probabilities -fbranch-target-load-optimize Perform branch target load optimization before prologue / epilogue threading -fbranch-target-load-optimize2 Perform branch target load optimization after prologue / epilogue threading -fbtr-bb-exclusive Restrict target load migration not to re-use registers in any basic block -fcaller-saves Save registers around function calls -fcombine-stack-adjustments Looks for opportunities to reduce stack adjustments and stack references. -fcompare-elim Perform comparison elimination after register allocation has finished -fconserve-stack Do not perform optimizations increasing noticeably stack usage -fcprop-registers Perform a register copy-propagation optimization pass -fcrossjumping Perform cross-jumping optimization -fcse-follow-jumps When running CSE, follow jumps to their targets -fcx-fortran-rules Complex multiplication and division follow Fortran rules -fcx-limited-range Omit range reduction step when performing complex division -fdce Use the RTL dead code elimination pass -fdefer-pop Defer popping functions args from stack until later -fdelayed-branch Attempt to fill delay slots of branch instructions -fdelete-dead-exceptions Delete dead instructions that may throw exceptions -fdelete-null-pointer-checks Delete useless null pointer checks -fdevirtualize Try to convert virtual calls to direct ones. -fdevirtualize-speculatively Perform speculative devirtualization -fdse Use the RTL dead store elimination pass -fearly-inlining Perform early inlining -fexceptions Enable exception handling -fexpensive-optimizations Perform a number of minor, expensive optimizations -ffinite-math-only Assume no NaNs or infinities are generated -ffloat-store Don't allocate floats and doubles in extended- precision registers -fforward-propagate Perform a forward propagation pass on RTL -ffp-contract= -ffp-contract=[off|on|fast] Perform floating- point expression contraction. -ffunction-cse Allow function addresses to be held in registers -fgcse Perform global common subexpression elimination -fgcse-after-reload Perform global common subexpression elimination after register allocation has finished -fgcse-las Perform redundant load after store elimination in global common subexpression elimination -fgcse-lm Perform enhanced load motion during global common subexpression elimination -fgcse-sm Perform store motion after global common subexpression elimination -fgraphite Enable in and out of Graphite representation -fgraphite-identity Enable Graphite Identity transformation -fguess-branch-probability Enable guessing of branch probabilities -fhoist-adjacent-loads Enable hoisting adjacent loads to encourage generating conditional move instructions -fif-conversion Perform conversion of conditional jumps to branchless equivalents -fif-conversion2 Perform conversion of conditional jumps to conditional execution -findirect-inlining Perform indirect inlining -finline Enable inlining of function declared "inline", disabling disables all inlining -finline-atomics Inline __atomic operations when a lock free instruction sequence is available. -finline-functions-called-once Integrate functions only required by their single caller -finline-small-functions Integrate functions into their callers when code size is known not to grow -fipa-cp Perform interprocedural constant propagation -fipa-cp-alignment Perform alignment discovery and propagation to make Interprocedural constant propagation stronger -fipa-cp-clone Perform cloning to make Interprocedural constant propagation stronger -fipa-icf Perform Identical Code Folding for functions and read-only variables -fipa-icf-functions Perform Identical Code Folding for functions -fipa-profile Perform interprocedural profile propagation -fipa-pta Perform interprocedural points-to analysis -fipa-pure-const Discover pure and const functions -fipa-ra Use caller save register across calls if possible -fipa-reference Discover readonly and non addressable static variables -fipa-sra Perform interprocedural reduction of aggregates -fira-algorithm= -fira-algorithm=[CB|priority] Set the used IRA algorithm -fira-hoist-pressure Use IRA based register pressure calculation in RTL hoist optimizations. -fira-loop-pressure Use IRA based register pressure calculation in RTL loop optimizations. -fira-region= -fira-region=[one|all|mixed] Set regions for IRA -fira-share-save-slots Share slots for saving different hard registers. -fira-share-spill-slots Share stack slots for spilled pseudo-registers. -fisolate-erroneous-paths-attribute Detect paths that trigger erroneous or undefined behavior due a null value being used in a way forbidden by a returns_nonnull or nonnull attribute. Isolate those paths from the main control flow and turn the statement with erroneous or undefined behavior into a trap. -fisolate-erroneous-paths-dereference Detect paths that trigger erroneous or undefined behavior due to dereferencing a null pointer. Isolate those paths from the main control flow and turn the statement with erroneous or undefined behavior into a trap. -fivopts Optimize induction variables on trees -fjump-tables Use jump tables for sufficiently large switch statements -flifetime-dse Tell DSE that the storage for a C++ object is dead when the constructor starts and when the destructor finishes. -flive-range-shrinkage Relief of register pressure through live range shrinkage -floop-block Enable Loop Blocking transformation -floop-interchange Enable Loop Interchange transformation -floop-nest-optimize Enable the ISL based loop nest optimizer -floop-parallelize-all Mark all loops as parallel -floop-strip-mine Enable Loop Strip Mining transformation -floop-unroll-and-jam Enable Loop Unroll Jam transformation -flra-remat Do CFG-sensitive rematerialization in LRA -fmath-errno Set errno after built-in math functions -fmodulo-sched Perform SMS based modulo scheduling before the first scheduling pass -fmodulo-sched-allow-regmoves Perform SMS based modulo scheduling with register moves allowed -fmove-loop-invariants Move loop invariant computations out of loops -fnon-call-exceptions Support synchronous non-call exceptions -fomit-frame-pointer When possible do not generate stack frames -fopt-info Enable all optimization info dumps on stderr -foptimize-sibling-calls Optimize sibling and tail recursive calls -foptimize-strlen Enable string length optimizations on trees -fpack-struct Pack structure members together without holes -fpack-struct= Set initial maximum structure member alignment -fpartial-inlining Perform partial inlining -fpeel-loops Perform loop peeling -fpeephole Enable machine specific peephole optimizations -fpeephole2 Enable an RTL peephole pass before sched2 -fpredictive-commoning Run predictive commoning optimization. -fprefetch-loop-arrays Generate prefetch instructions, if available, for arrays in loops -freciprocal-math Same as -fassociative-math for expressions which include division. -freg-struct-return Return small aggregates in registers -frename-registers Perform a register renaming optimization pass -freorder-blocks Reorder basic blocks to improve code placement -freorder-blocks-and-partition Reorder basic blocks and partition into hot and cold sections -freorder-functions Reorder functions to improve code placement -frerun-cse-after-loop Add a common subexpression elimination pass after loop optimizations -freschedule-modulo-scheduled-loops Enable/Disable the traditional scheduling in loops that already passed modulo scheduling -frounding-math Disable optimizations that assume default FP rounding behavior -fsched-critical-path-heuristic Enable the critical path heuristic in the scheduler -fsched-dep-count-heuristic Enable the dependent count heuristic in the scheduler -fsched-group-heuristic Enable the group heuristic in the scheduler -fsched-interblock Enable scheduling across basic blocks -fsched-last-insn-heuristic Enable the last instruction heuristic in the scheduler -fsched-pressure Enable register pressure sensitive insn scheduling -fsched-rank-heuristic Enable the rank heuristic in the scheduler -fsched-spec Allow speculative motion of non-loads -fsched-spec-insn-heuristic Enable the speculative instruction heuristic in the scheduler -fsched-spec-load Allow speculative motion of some loads -fsched-spec-load-dangerous Allow speculative motion of more loads -fsched-stalled-insns Allow premature scheduling of queued insns -fsched-stalled-insns-dep Set dependence distance checking in premature scheduling of queued insns -fsched-stalled-insns-dep= Set dependence distance checking in premature scheduling of queued insns -fsched-stalled-insns= Set number of queued insns that can be prematurely scheduled -fsched2-use-superblocks If scheduling post reload, do superblock scheduling -fschedule-fusion Perform a target dependent instruction fusion optimization pass -fschedule-insns Reschedule instructions before register allocation -fschedule-insns2 Reschedule instructions after register allocation -fsection-anchors Access data in the same section from shared anchor points -fsel-sched-pipelining Perform software pipelining of inner loops during selective scheduling -fsel-sched-pipelining-outer-loops Perform software pipelining of outer loops during selective scheduling -fsel-sched-reschedule-pipelined Reschedule pipelined regions without pipelining -fselective-scheduling Schedule instructions using selective scheduling algorithm -fselective-scheduling2 Run selective scheduling after reload -fset-stack-executable For nested functions on stack executable permission is set. -fshrink-wrap Emit function prologues only before parts of the function that need it, rather than at the top of the function. -fsignaling-nans Disable optimizations observable by IEEE signaling NaNs -fsigned-zeros Disable floating point optimizations that ignore the IEEE signedness of zero -fsimd-cost-model= Specifies the vectorization cost model for code marked with a simd directive -fsingle-precision-constant Convert floating point constants to single precision constants -fsplit-ivs-in-unroller Split lifetimes of induction variables when loops are unrolled -fsplit-wide-types Split wide types into independent registers -fssa-phiopt Optimize conditional patterns using SSA PHI nodes -fstack-reuse= -fstack-reuse=[all|named_vars|none] Set stack reuse level for local variables. -fstdarg-opt Optimize amount of stdarg registers saved to stack at start of function -fstrict-aliasing Assume strict aliasing rules apply -fstrict-overflow Treat signed overflow as undefined -fstrict-volatile-bitfields Force bitfield accesses to match their type width -fthread-jumps Perform jump threading optimizations -ftracer Perform superblock formation via tail duplication -ftrapping-math Assume floating-point operations can trap -ftrapv Trap for signed overflow in addition, subtraction and multiplication -ftree-bit-ccp Enable SSA-BIT-CCP optimization on trees -ftree-builtin-call-dce Enable conditional dead code elimination for builtin calls -ftree-ccp Enable SSA-CCP optimization on trees -ftree-ch Enable loop header copying on trees -ftree-coalesce-inlined-vars Enable coalescing of copy-related user variables that are inlined -ftree-coalesce-vars Enable coalescing of all copy-related user variables -ftree-copy-prop Enable copy propagation on trees -ftree-copyrename Replace SSA temporaries with better names in copies -ftree-cselim Transform condition stores into unconditional ones -ftree-dce Enable SSA dead code elimination optimization on trees -ftree-dominator-opts Enable dominator optimizations -ftree-dse Enable dead store elimination -ftree-forwprop Enable forward propagation on trees -ftree-fre Enable Full Redundancy Elimination (FRE) on trees -ftree-loop-distribute-patterns Enable loop distribution for patterns transformed into a library call -ftree-loop-distribution Enable loop distribution on trees -ftree-loop-if-convert Convert conditional jumps in innermost loops to branchless equivalents -ftree-loop-if-convert-stores Also if-convert conditional jumps containing memory writes -ftree-loop-im Enable loop invariant motion on trees -ftree-loop-ivcanon Create canonical induction variables in loops -ftree-loop-optimize Enable loop optimizations on tree level -ftree-loop-vectorize Enable loop vectorization on trees -ftree-lrs Perform live range splitting during the SSA- >normal pass -ftree-parallelize-loops= Enable automatic parallelization of loops -ftree-partial-pre In SSA-PRE optimization on trees, enable partial- partial redundancy elimination -ftree-phiprop Enable hoisting loads from conditional pointers. -ftree-pre Enable SSA-PRE optimization on trees -ftree-pta Perform function-local points-to analysis on trees. -ftree-reassoc Enable reassociation on tree level -ftree-scev-cprop Enable copy propagation of scalar-evolution information. -ftree-sink Enable SSA code sinking on trees -ftree-slp-vectorize Enable basic block vectorization (SLP) on trees -ftree-slsr Perform straight-line strength reduction -ftree-sra Perform scalar replacement of aggregates -ftree-switch-conversion Perform conversions of switch initializations. -ftree-tail-merge Enable tail merging on trees -ftree-ter Replace temporary expressions in the SSA->normal pass -ftree-vectorize Enable vectorization on trees -ftree-vrp Perform Value Range Propagation on trees -funroll-all-loops Perform loop unrolling for all loops -funroll-loops Perform loop unrolling when iteration count is known -funsafe-loop-optimizations Allow loop optimizations to assume that the loops behave in normal way -funsafe-math-optimizations Allow math optimizations that may violate IEEE or ISO standards -funswitch-loops Perform loop unswitching -funwind-tables Just generate unwind tables for exception handling -fvar-tracking Perform variable tracking -fvar-tracking-assignments Perform variable tracking by annotating assignments -fvar-tracking-assignments-toggle Toggle -fvar-tracking-assignments -fvar-tracking-uninit Perform variable tracking and also tag variables that are uninitialized -fvariable-expansion-in-unroller Apply variable expansion when loops are unrolled -fvect-cost-model= Specifies the cost model for vectorization -fvpt Use expression value profiles in optimizations -fweb Construct webs and split unrelated uses of single variable -fwrapv Assume signed arithmetic overflow wraps around
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 12 The following options are target specific: -m128bit-long-double sizeof(long double) is 16 -m16 Generate 16bit i386 code -m32 Generate 32bit i386 code -m3dnow Support 3DNow! built-in functions -m3dnowa Support Athlon 3Dnow! built-in functions -m64 Generate 64bit x86-64 code -m80387 Use hardware fp -m8bit-idiv Expand 32bit/64bit integer divide into 8bit unsigned integer divide with run-time check -m96bit-long-double sizeof(long double) is 12 -mabi= Generate code that conforms to the given ABI -mabm Support code generation of Advanced Bit Manipulation (ABM) instructions. -maccumulate-outgoing-args Reserve space for outgoing arguments in the function prologue -maddress-mode= Use given address mode -madx Support flag-preserving add-carry instructions -maes Support AES built-in functions and code generation -malign-data= Use the given data alignment -malign-double Align some doubles on dword boundary -malign-functions= Function starts are aligned to this power of 2 -malign-jumps= Jump targets are aligned to this power of 2 -malign-loops= Loop code aligned to this power of 2 -malign-stringops Align destination of the string operations -march= Generate code for given CPU -masm= Use given assembler dialect -mavx Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2 and AVX built-in functions and code generation -mavx2 Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX and AVX2 built-in functions and code generation -mavx256-split-unaligned-load Split 32-byte AVX unaligned load -mavx256-split-unaligned-store Split 32-byte AVX unaligned store -mavx512bw Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2 and AVX512F and AVX512BW built- in functions and code generation -mavx512cd Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2 and AVX512F and AVX512CD built- in functions and code generation -mavx512dq Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2 and AVX512F and AVX512DQ built- in functions and code generation -mavx512er Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2 and AVX512F and AVX512ER built- in functions and code generation -mavx512f Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2 and AVX512F built-in functions and code generation -mavx512ifma Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2 and AVX512F and AVX512IFMA built-in functions and code generation -mavx512pf Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2 and AVX512F and AVX512PF built- in functions and code generation -mavx512vbmi Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2 and AVX512F and AVX512VBMI built-in functions and code generation -mavx512vl Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2 and AVX512F and AVX512VL built- in functions and code generation -mbmi Support BMI built-in functions and code generation -mbmi2 Support BMI2 built-in functions and code generation -mbranch-cost= Branches are this expensive (1-5, arbitrary units) -mcld Generate cld instruction in the function prologue. -mclflushopt Support CLFLUSHOPT instructions -mclwb Support CLWB instruction -mcmodel= Use given x86-64 code model -mconsole Create console application -mcpu= This switch lacks documentation -mcrc32 Support code generation of crc32 instruction. -mcx16 Support code generation of cmpxchg16b instruction. -mdispatch-scheduler Do dispatch scheduling if processor is bdver1 or bdver2 or bdver3 or bdver4 and Haifa scheduling is selected. -mdll Generate code for a DLL -mdump-tune-features This switch lacks documentation -mf16c Support F16C built-in functions and code generation -mfancy-math-387 Generate sin, cos, sqrt for FPU -mfentry Emit profiling counter call at function entry before prologue. -mfma Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX and FMA built-in functions and code generation -mfma4 Support FMA4 built-in functions and code generation -mforce-drap Always use Dynamic Realigned Argument Pointer (DRAP) to realign stack -mfp-ret-in-387 Return values of functions in FPU registers -mfpmath= Generate floating point mathematics using given instruction set -mfsgsbase Support FSGSBASE built-in functions and code generation -mfused-madd This switch lacks documentation -mfxsr Support FXSAVE and FXRSTOR instructions -mhard-float Use hardware fp -mhle Support Hardware Lock Elision prefixes -mieee-fp Use IEEE math for fp comparisons -mincoming-stack-boundary= Assume incoming stack aligned to this power of 2 -minline-all-stringops Inline all known string operations -minline-stringops-dynamically Inline memset/memcpy string operations, but perform inline version only for small blocks -mintel-syntax This switch lacks documentation -mlarge-data-threshold= Data greater than given threshold will go into .ldata section in x86-64 medium model -mlong-double-128 Use 128-bit long double -mlong-double-64 Use 64-bit long double -mlong-double-80 Use 80-bit long double -mlwp Support LWP built-in functions and code generation -mlzcnt Support LZCNT built-in function and code generation -mmemcpy-strategy= Specify memcpy expansion strategy when expected size is known -mmemset-strategy= Specify memset expansion strategy when expected size is known -mmmx Support MMX built-in functions -mmovbe Support code generation of movbe instruction. -mmpx Support MPX code generation -mms-bitfields Use native (MS) bitfield layout -mno-align-stringops This switch lacks documentation -mno-default Clear all tune features -mno-fancy-math-387 This switch lacks documentation -mno-push-args This switch lacks documentation -mno-red-zone This switch lacks documentation -mno-sse4 Do not support SSE4.1 and SSE4.2 built-in functions and code generation -mnop-fun-dllimport Ignore dllimport for functions -mnop-mcount Generate mcount/__fentry__ calls as nops. To activate they need to be patched in. -momit-leaf-frame-pointer Omit the frame pointer in leaf functions -mpc32 Set 80387 floating-point precision to 32-bit -mpc64 Set 80387 floating-point precision to 64-bit -mpc80 Set 80387 floating-point precision to 80-bit -mpclmul Support PCLMUL built-in functions and code generation -mpcommit Support PCOMMIT instruction -mpe-aligned-commons Use the GNU extension to the PE format for aligned common data -mpopcnt Support code generation of popcnt instruction. -mprefer-avx128 Use 128-bit AVX instructions instead of 256-bit AVX instructions in the auto-vectorizer. -mpreferred-stack-boundary= Attempt to keep stack aligned to this power of 2 -mprefetchwt1 Support PREFETCHWT1 built-in functions and code generation -mprfchw Support PREFETCHW instruction -mpush-args Use push instructions to save outgoing arguments -mrdrnd Support RDRND built-in functions and code generation -mrdseed Support RDSEED instruction -mrecip Generate reciprocals instead of divss and sqrtss. -mrecip= Control generation of reciprocal estimates. -mrecord-mcount Generate __mcount_loc section with all mcount or __fentry__ calls. -mred-zone Use red-zone in the x86-64 code -mregparm= Number of registers used to pass integer arguments -mrtd Alternate calling convention -mrtm Support RTM built-in functions and code generation -msahf Support code generation of sahf instruction in 64bit x86-64 code. -msha Support SHA1 and SHA256 built-in functions and code generation -mskip-rax-setup Skip setting up RAX register when passing variable arguments. -msoft-float Do not use hardware fp -msse Support MMX and SSE built-in functions and code generation -msse2 Support MMX, SSE and SSE2 built-in functions and code generation -msse2avx Encode SSE instructions with VEX prefix -msse3 Support MMX, SSE, SSE2 and SSE3 built-in functions and code generation -msse4 Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1 and SSE4.2 built-in functions and code generation -msse4.1 Support MMX, SSE, SSE2, SSE3, SSSE3 and SSE4.1 built-in functions and code generation -msse4.2 Support MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1 and SSE4.2 built-in functions and code generation -msse4a Support MMX, SSE, SSE2, SSE3 and SSE4A built-in functions and code generation -msse5 This switch lacks documentation -msseregparm Use SSE register passing conventions for SF and DF mode -mssse3 Support MMX, SSE, SSE2, SSE3 and SSSE3 built-in functions and code generation -mstack-arg-probe Enable stack probing -mstack-protector-guard= Use given stack-protector guard -mstackrealign Realign stack in prologue -mstringop-strategy= Chose strategy to generate stringop using -mtbm Support TBM built-in functions and code generation -mthreads Use Mingw-specific thread support -mtls-dialect= Use given thread-local storage dialect -mtls-direct-seg-refs Use direct references against %gs when accessing tls data -mtune-ctrl= Fine grain control of tune features -mtune= Schedule code for given CPU -municode Use unicode startup and define UNICODE macro -mveclibabi= Vector library ABI to use -mvect8-ret-in-mem Return 8-byte vectors in memory -mvzeroupper Generate vzeroupper instruction before a transfer of control flow out of the function. -mwin32 Set Windows defines -mwindows Create GUI application -mx32 Generate 32bit x86-64 code -mxop Support XOP built-in functions and code generation -mxsave Support XSAVE and XRSTOR instructions -mxsavec Support XSAVEC instructions -mxsaveopt Support XSAVEOPT instruction -mxsaves Support XSAVES and XRSTORS instructions Known assembler dialects (for use with the -masm-dialect= option): att intel Known ABIs (for use with the -mabi= option): ms sysv Known code models (for use with the -mcmodel= option): 32 kernel large medium small Valid arguments to -mfpmath=: 387 387+sse 387,sse both sse sse+387 sse,387 Known data alignment choices (for use with the -malign-data= option): abi cacheline compat Known vectorization library ABIs (for use with the -mveclibabi= option): acml svml Known address mode (for use with the -maddress-mode= option): long short Known stack protector guard (for use with the -mstack-protector-guard= option): global tls Valid arguments to -mstringop-strategy=: byte_loop libcall loop rep_4byte rep_8byte rep_byte unrolled_loop vector_loop Known TLS dialects (for use with the -mtls-dialect= option): gnu gnu2
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 13 The following options are language-independent: --debug This switch lacks documentation --dumpbase This switch lacks documentation --dumpdir This switch lacks documentation --help Display this information --help= Display descriptions of a specific class of options. is one or more of optimizers, target, warnings, undocumented, params --optimize This switch lacks documentation --param = Set parameter to value. See below for a complete list of parameters --param= This switch lacks documentation --pedantic-errors This switch lacks documentation --profile This switch lacks documentation --target-help Alias for --help=target --version This switch lacks documentation -Werror= Treat specified warning as error -Wfatal-errors Exit on the first error occurred -Wframe-larger-than= Warn if a function's stack frame requires more than bytes -Wmissing-noreturn This switch lacks documentation -Wunreachable-code Does nothing. Preserved for backward compatibility. -aux-info Emit declaration information into -aux-info= This switch lacks documentation -auxbase This switch lacks documentation -auxbase-strip This switch lacks documentation -dumpbase Set the file basename to be used for dumps -dumpdir Set the directory name to be used for dumps -fPIC Generate position-independent code if possible (large mode) -fPIE Generate position-independent code for executables if possible (large mode) -fabi-version= The version of the C++ ABI in use -falign-functions= This switch lacks documentation -falign-jumps= This switch lacks documentation -falign-labels= This switch lacks documentation -falign-loops= This switch lacks documentation -fargument-alias Does nothing. Preserved for backward compatibility. -fargument-noalias Does nothing. Preserved for backward compatibility. -fargument-noalias-anything Does nothing. Preserved for backward compatibility. -fargument-noalias-global Does nothing. Preserved for backward compatibility. -fasan-shadow-offset= Use custom shadow memory offset. -fauto-profile Use sample profile information for call graph node weights. The default profile file is fbdata.afdo in 'pwd'. -fauto-profile= Use sample profile information for call graph node weights. The profile file is specified in the argument. -fbounds-check Generate code to check bounds before indexing arrays -fcall-saved- Mark as being preserved across functions -fcall-used- Mark as being corrupted by function calls -fcheck-data-deps Compare the results of several data dependence analyzers. -fcheck-new Check the return value of new in C++ -fcommon Do not put uninitialized globals in the common section -fcompare-debug-second Run only the second compilation of -fcompare-debug -fcompare-debug[=] Compile with and without e.g. -gtoggle, and compare the final-insns dump -fcse-skip-blocks Does nothing. Preserved for backward compatibility. -fdata-sections Place data items into their own section -fdbg-cnt-list List all available debugging counters with their limits and counts. -fdbg-cnt=:[,:,...] Set the debug counter limit. -fdebug-prefix-map= Map one directory name to another in debug information -fdebug-types-section Output .debug_types section when using DWARF v4 debuginfo. -fdevirtualize-at-ltrans Stream extra data to support more aggressive devirtualization in LTO local transformation mode -fdiagnostics-color This switch lacks documentation -fdiagnostics-color=[never|always|auto] Colorize diagnostics -fdiagnostics-show-caret Show the source line with a caret indicating the column -fdiagnostics-show-location=[once|every-line] How often to emit source location at the beginning of line-wrapped diagnostics -fdiagnostics-show-option Amend appropriate diagnostic messages with the command line option that controls them -fdisable- -fdisable-[tree|rtl|ipa]-=range1+range2 disables an optimization pass -fdump- Dump various compiler internals to a file -fdump-final-insns=filename Dump to filename the insns at the end of translation -fdump-go-spec=filename Write all declarations to file as Go code -fdump-noaddr Suppress output of addresses in debugging dumps -fdump-passes Dump optimization passes -fdump-unnumbered Suppress output of instruction numbers, line number notes and addresses in debugging dumps -fdump-unnumbered-links Suppress output of previous and next insn numbers in debugging dumps -fdwarf2-cfi-asm Enable CFI tables via GAS assembler directives. -feliminate-dwarf2-dups Perform DWARF2 duplicate elimination -feliminate-unused-debug-symbols Perform unused symbol elimination in debug info -feliminate-unused-debug-types Perform unused type elimination in debug info -femit-class-debug-always Do not suppress C++ class debug information. -fenable- -fenable-[tree|rtl|ipa]-=range1+range2 enables an optimization pass -fexcess-precision=[fast|standard] Specify handling of excess floating-point precision -ffast-math This switch lacks documentation -ffat-lto-objects Output lto objects containing both the intermediate language and binary output. -ffixed- Mark as being unavailable to the compiler -fforce-addr Does nothing. Preserved for backward compatibility. -ffunction-sections Place each function into its own section -fgnu-tm Enable support for GNU transactional memory -fgnu-unique Use STB_GNU_UNIQUE if supported by the assembler -fhelp This switch lacks documentation -fhelp= This switch lacks documentation -fident Process #ident directives -finhibit-size-directive Do not generate .size directives -finline-limit- This switch lacks documentation -finline-limit= Limit the size of inlined functions to -finstrument-functions Instrument function entry and exit with profiling calls -finstrument-functions-exclude-file-list= -finstrument-functions-exclude-file- list=filename,... Do not instrument functions listed in files -finstrument-functions-exclude-function-list= -finstrument-functions-exclude- function-list=name,... Do not instrument listed functions -fipa-icf-variables Perform Identical Code Folding for variables -fipa-matrix-reorg Does nothing. Preserved for backward compatibility. -fipa-struct-reorg Does nothing. Preserved for backward compatibility. -fira-verbose= Control IRA's level of diagnostic messages. -fkeep-inline-functions Generate code for functions even if they are fully inlined -fkeep-static-consts Emit static const variables even if they are not used -fleading-underscore Give external symbols a leading underscore -floop-flatten Does nothing. Preserved for backward compatibility. -floop-optimize Does nothing. Preserved for backward compatibility. -flto Enable link-time optimization. -flto-compression-level= Use zlib compression level for IL -flto-odr-type-merging Merge C++ types using One Definition Rule -flto-partition= Specify the algorithm to partition symbols and vars at linktime -flto-report Report various link-time optimization statistics -flto-report-wpa Report various link-time optimization statistics for WPA only -flto= Link-time optimization with number of parallel jobs or jobserver. -fmax-errors= Maximum number of errors to report -fmem-report Report on permanent memory allocation -fmem-report-wpa Report on permanent memory allocation in WPA only -fmerge-all-constants Attempt to merge identical constants and constant variables -fmerge-constants Attempt to merge identical constants across compilation units -fmerge-debug-strings Attempt to merge identical debug strings across compilation units -fmessage-length= Limit diagnostics to characters per line. 0 suppresses line-wrapping -fno-vect-cost-model Enables the unlimited vectorizer cost model. Preserved for backward compatibility. -foffload-abi= -foffload-abi=[lp64|ilp32] Set the ABI to use in an offload compiler -foffload= -foffload== Specify offloading targets and options for them -fopt-info[-=filename] Dump compiler optimization details -foptimize-register-move Does nothing. Preserved for backward compatibility. -fpcc-struct-return Return small aggregates in memory, not registers -fpic Generate position-independent code if possible (small mode) -fpie Generate position-independent code for executables if possible (small mode) -fplugin-arg--[=] Specify argument = for plugin -fplugin= Specify a plugin to load -fpost-ipa-mem-report Report on memory allocation before interprocedural optimization -fpre-ipa-mem-report Report on memory allocation before interprocedural optimization -fprofile Enable basic program profiling code -fprofile-arcs Insert arc-based program profiling code -fprofile-correction Enable correction of flow inconsistent profile data input -fprofile-dir= Set the top-level directory for storing the profile data. The default is 'pwd'. -fprofile-generate Enable common options for generating profile info for profile feedback directed optimizations -fprofile-generate= Enable common options for generating profile info for profile feedback directed optimizations, and set -fprofile-dir= -fprofile-reorder-functions Enable function reordering that improves code placement -fprofile-report Report on consistency of profile -fprofile-use Enable common options for performing profile feedback directed optimizations -fprofile-use= Enable common options for performing profile feedback directed optimizations, and set -fprofile-dir= -fprofile-values Insert code to profile values of expressions -frandom-seed This switch lacks documentation -frandom-seed= Make compile reproducible using -frecord-gcc-switches Record gcc command line switches in the object file. -free Turn on Redundant Extensions Elimination pass. -fregmove Does nothing. Preserved for backward compatibility. -freport-bug Collect and dump debug information into temporary file if ICE in C/C++ compiler occured. -frerun-loop-opt Does nothing. Preserved for backward compatibility. -fsanitize-recover This switch is deprecated; use -fsanitize- recover= instead -fsanitize-recover= After diagnosing undefined behavior attempt to continue execution -fsanitize-undefined-trap-on-error Use trap instead of a library function for undefined behavior sanitization -fsanitize= Select what to sanitize -fsched-verbose= Set the verbosity level of the scheduler -fsched2-use-traces Does nothing. Preserved for backward compatibility. -fsee Does nothing. Preserved for backward compatibility. -fsemantic-interposition Allow interposing function (or variables) by ones with different semantics (or initializer) respectively by dynamic linker -fshow-column Show column numbers in diagnostics, when available. Default on -fsplit-stack Generate discontiguous stack frames -fstack-check Insert stack checking code into the program. Same as -fstack-check=specific -fstack-check=[no|generic|specific] Insert stack checking code into the program -fstack-limit This switch lacks documentation -fstack-limit-register= Trap if the stack goes past -fstack-limit-symbol= Trap if the stack goes past symbol -fstack-protector Use propolice as a stack protection method -fstack-protector-all Use a stack protection method for every function -fstack-protector-explicit Use stack protection method only for functions with the stack_protect attribute -fstack-protector-strong Use a smart stack protection method for certain functions -fstack-usage Output stack usage information on a per-function basis -fstrength-reduce Does nothing. Preserved for backward compatibility. -fsync-libcalls Implement __atomic operations via libcalls to legacy __sync functions -fsyntax-only Check for syntax errors, then stop -ftarget-help This switch lacks documentation -ftest-coverage Create data files needed by "gcov" -ftime-report Report the time taken by each compiler pass -ftls-model=[global-dynamic|local-dynamic|initial-exec|local-exec] Set the default thread-local storage code generation model -ftoplevel-reorder Reorder top level functions, variables, and asms -ftree-loop-linear Enable loop interchange transforms. Same as -floop-interchange -ftree-salias Does nothing. Preserved for backward compatibility. -ftree-store-ccp Does nothing. Preserved for backward compatibility. -ftree-store-copy-prop Does nothing. Preserved for backward compatibility. -ftree-vect-loop-version Does nothing. Preserved for backward compatibility. -ftree-vectorizer-verbose= Does nothing. Preserved for backward compatibility. -funit-at-a-time Compile whole compilation unit at a time -fuse-ld=bfd Use the bfd linker instead of the default linker -fuse-ld=gold Use the gold linker instead of the default linker -fuse-linker-plugin This switch lacks documentation -fvect-cost-model Enables the dynamic vectorizer cost model. Preserved for backward compatibility. -fverbose-asm Add extra commentary to assembler output -fversion This switch lacks documentation -fvisibility=[default|internal|hidden|protected] Set the default symbol visibility -fvtable-verify= Validate vtable pointers before using them. -fvtv-counts Output vtable verification counters. -fvtv-debug Output vtable verification pointer sets information. -fwhole-program Perform whole program optimizations -fwritable-relocated-rdata Put relocated read-only data into .data section. -fzee Does nothing. Preserved for backward compatibility. -fzero-initialized-in-bss Put zero initialized data in the bss section
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 14 -g Generate debug information in default format -gcoff Generate debug information in COFF format -gdwarf Generate debug information in default version of DWARF format -gdwarf- Generate debug information in DWARF v2 (or later) format -ggdb Generate debug information in default extended format -ggnu-pubnames Generate DWARF pubnames and pubtypes sections with GNU extensions. -gno-pubnames Don't generate DWARF pubnames and pubtypes sections. -gno-record-gcc-switches Don't record gcc command line switches in DWARF DW_AT_producer. -gno-split-dwarf Don't generate debug information in separate .dwo files -gno-strict-dwarf Emit DWARF additions beyond selected version -gpubnames Generate DWARF pubnames and pubtypes sections. -grecord-gcc-switches Record gcc command line switches in DWARF DW_AT_producer. -gsplit-dwarf Generate debug information in separate .dwo files -gstabs Generate debug information in STABS format -gstabs+ Generate debug information in extended STABS format -gstrict-dwarf Don't emit DWARF additions beyond selected version -gtoggle Toggle debug information generation -gvms Generate debug information in VMS format -gxcoff Generate debug information in XCOFF format -gxcoff+ Generate debug information in extended XCOFF format -gz Generate compressed debug sections -gz= Generate compressed debug sections in format -imultiarch Set to be the multiarch include subdirectory -iplugindir= Set to be the default plugin directory -p Enable function profiling -pedantic-errors Like -pedantic but issue them as errors -quiet Do not display functions compiled or elapsed time
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 15 Usage: C:/WorkLib/MinGW/Bin/../lib/gcc/x86_64-w64-mingw32/5.1.0/../../../../x86_64-w64-mingw32/bin/as.exe [option...] [asmfile...] Options: -a[sub-option...] turn on listings Sub-options [default hls]: c omit false conditionals d omit debugging directives g include general info h include high-level source l include assembly m include macro expansions n omit forms processing s include symbols =FILE list to FILE (must be last sub-option) --alternate initially turn on alternate macro syntax --compress-debug-sections compress DWARF debug sections using zlib --nocompress-debug-sections don't compress DWARF debug sections -D produce assembler debugging messages --debug-prefix-map OLD=NEW map OLD to NEW in debug information --defsym SYM=VAL define symbol SYM to given value -f skip whitespace and comment preprocessing -g --gen-debug generate debugging information --gstabs generate STABS debugging information --gstabs+ generate STABS debug info with GNU extensions --gdwarf-2 generate DWARF2 debugging information --gdwarf-sections generate per-function section names for DWARF line information --hash-size= set the hash table size close to --help show this message and exit --target-help show target specific options -I DIR add DIR to search list for .include directives -J don't warn about signed overflow -K warn when differences altered for long displacements -L,--keep-locals keep local symbols (e.g. starting with `L') -M,--mri assemble in MRI compatibility mode --MD FILE write dependency information in FILE (default none) -nocpp ignored -o OBJFILE name the object-file output OBJFILE (default a.out) -R fold data section into text section --reduce-memory-overheads prefer smaller memory use at the cost of longer assembly times --statistics print various measured statistics from execution --strip-local-absolute strip local absolute symbols --traditional-format Use same format as native assembler when possible --version print assembler version number and exit -W --no-warn suppress warnings --warn don't suppress warnings --fatal-warnings treat warnings as errors -w ignored -X ignored -Z generate object file even after errors --listing-lhs-width set the width in words of the output data column of the listing --listing-lhs-width2 set the width in words of the continuation lines of the output data column; ignored if smaller than the width of the first line --listing-rhs-width set the max width in characters of the lines from the source file --listing-cont-lines set the maximum number of continuation lines used for the output data column of the listing @FILE read options from FILE -n Do not optimize code alignment -q quieten some warnings --32/--64/--x32 generate 32bit/64bit/x32 code --divide ignored -march=CPU[,+EXTENSION...] generate code for CPU and EXTENSION, CPU is one of: generic32, generic64, i386, i486, i586, i686, pentium, pentiumpro, pentiumii, pentiumiii, pentium4, prescott, nocona, core, core2, corei7, l1om, k1om, k6, k6_2, athlon, opteron, k8, amdfam10, bdver1, bdver2, bdver3, bdver4, btver1, btver2 EXTENSION is combination of: 8087, 287, 387, no87, mmx, nommx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, sse4, nosse, avx, avx2, avx512f, avx512cd, avx512er, avx512pf, avx512dq, avx512bw, avx512vl, noavx, vmx, vmfunc, smx, xsave, xsaveopt, xsavec, xsaves, aes, pclmul, fsgsbase, rdrnd, f16c, bmi2, fma, fma4, xop, lwp, movbe, cx16, ept, lzcnt, hle, rtm, invpcid, clflush, nop, syscall, rdtscp, 3dnow, 3dnowa, padlock, svme, sse4a, abm, bmi, tbm, adx, rdseed, prfchw, smap, mpx, sha, clflushopt, prefetchwt1, se1, clwb, pcommit, avx512ifma, avx512vbmi -mtune=CPU optimize for CPU, CPU is one of: generic32, generic64, i8086, i186, i286, i386, i486, i586, i686, pentium, pentiumpro, pentiumii, pentiumiii, pentium4, prescott, nocona, core, core2, corei7, l1om, k1om, k6, k6_2, athlon, opteron, k8, amdfam10, bdver1, bdver2, bdver3, bdver4, btver1, btver2 -msse2avx encode SSE instructions with VEX prefix -msse-check=[none|error|warning] check SSE instructions -moperand-check=[none|error|warning] check operand combinations for validity -mavxscalar=[128|256] encode scalar AVX instructions with specific vector length -mevexlig=[128|256|512] encode scalar EVEX instructions with specific vector length -mevexwig=[0|1] encode EVEX instructions with specific EVEX.W value for EVEX.W bit ignored instructions -mevexrcig=[rne|rd|ru|rz] encode EVEX instructions with specific EVEX.RC value for SAE-only ignored instructions -mmnemonic=[att|intel] use AT&T/Intel mnemonic -msyntax=[att|intel] use AT&T/Intel syntax -mindex-reg support pseudo index registers -mnaked-reg don't require `%' prefix for registers -mold-gcc support old (<= 2.8.1) versions of gcc -madd-bnd-prefix add BND prefix for all valid branches -mbig-obj generate big object files -momit-lock-prefix=[no|yes] strip all lock prefixes
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 16 Report bugs to <> Usage: collect2 [options] Wrap linker and generate constructor code if needed. Options: -debug Enable debug output --help Display this information -v, --version Display this program's version number Overview: http://gcc.gnu.org/onlinedocs/gccint/Collect2.html Report bugs: <> Usage: C:/WorkLib/MinGW/Bin/../lib/gcc/x86_64-w64-mingw32/5.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe [options] file... Options: -a KEYWORD Shared library control for HP/UX compatibility -A ARCH, --architecture ARCH Set architecture -b TARGET, --format TARGET Specify target for following input files -c FILE, --mri-script FILE Read MRI format linker script -d, -dc, -dp Force common symbols to be defined -e ADDRESS, --entry ADDRESS Set start address -E, --export-dynamic Export all dynamic symbols --no-export-dynamic Undo the effect of --export-dynamic -EB Link big-endian objects -EL Link little-endian objects -f SHLIB, --auxiliary SHLIB Auxiliary filter for shared object symbol table -F SHLIB, --filter SHLIB Filter for shared object symbol table -g Ignored -G SIZE, --gpsize SIZE Small data size (if no size, same as --shared) -h FILENAME, -soname FILENAME Set internal name of shared library -I PROGRAM, --dynamic-linker PROGRAM Set PROGRAM as the dynamic linker to use -l LIBNAME, --library LIBNAME Search for library LIBNAME -L DIRECTORY, --library-path DIRECTORY Add DIRECTORY to library search path --sysroot= Override the default sysroot location -m EMULATION Set emulation -M, --print-map Print map file on standard output -n, --nmagic Do not page align data -N, --omagic Do not page align data, do not make text readonly --no-omagic Page align data, make text readonly -o FILE, --output FILE Set output file name -O Optimize output file -plugin PLUGIN Load named plugin -plugin-opt ARG Send arg to last-loaded plugin -flto Ignored for GCC LTO option compatibility -flto-partition= Ignored for GCC LTO option compatibility -fuse-ld= Ignored for GCC linker option compatibility -Qy Ignored for SVR4 compatibility -q, --emit-relocs Generate relocations in final output -r, -i, --relocatable Generate relocatable output -R FILE, --just-symbols FILE Just link symbols (if directory, same as --rpath) -s, --strip-all Strip all symbols -S, --strip-debug Strip debugging symbols --strip-discarded Strip symbols in discarded sections --no-strip-discarded Do not strip symbols in discarded sections -t, --trace Trace file opens -T FILE, --script FILE Read linker script --default-script FILE, -dT Read default linker script -u SYMBOL, --undefined SYMBOL Start with undefined reference to SYMBOL --unique [=SECTION] Don't merge input [SECTION | orphan] sections -Ur Build global constructor/destructor tables -v, --version Print version information -V Print version and emulation information -x, --discard-all Discard all local symbols -X, --discard-locals Discard temporary local symbols (default) --discard-none Don't discard any local symbols -y SYMBOL, --trace-symbol SYMBOL Trace mentions of SYMBOL -Y PATH Default search path for Solaris compatibility -(, --start-group Start a group -), --end-group End a group --accept-unknown-input-arch Accept input files whose architecture cannot be determined --no-accept-unknown-input-arch Reject input files whose architecture is unknown --as-needed Only set DT_NEEDED for following dynamic libs if used --no-as-needed Always set DT_NEEDED for dynamic libraries mentioned on the command line -assert KEYWORD Ignored for SunOS compatibility -Bdynamic, -dy, -call_shared Link against shared libraries -Bstatic, -dn, -non_shared, -static Do not link against shared libraries -Bsymbolic Bind global references locally -Bsymbolic-functions Bind global function references locally --check-sections Check section addresses for overlaps (default) --no-check-sections Do not check section addresses for overlaps --copy-dt-needed-entries Copy DT_NEEDED links mentioned inside DSOs that follow --no-copy-dt-needed-entries Do not copy DT_NEEDED links mentioned inside DSOs that follow --cref Output cross reference table --defsym SYMBOL=EXPRESSION Define a symbol --demangle [=STYLE] Demangle symbol names [using STYLE] --embedded-relocs Generate embedded relocs --fatal-warnings Treat warnings as errors --no-fatal-warnings Do not treat warnings as errors (default) -fini SYMBOL Call SYMBOL at unload-time --force-exe-suffix Force generation of file with .exe suffix --gc-sections Remove unused sections (on some targets) --no-gc-sections Don't remove unused sections (default) --print-gc-sections List removed unused sections on stderr --no-print-gc-sections Do not list removed unused sections --hash-size= Set default hash table size close to --help Print option help -init SYMBOL Call SYMBOL at load-time -Map FILE Write a map file --no-define-common Do not define Common storage --no-demangle Do not demangle symbol names --no-keep-memory Use less memory and more disk I/O --no-undefined Do not allow unresolved references in object files --allow-shlib-undefined Allow unresolved references in shared libraries --no-allow-shlib-undefined Do not allow unresolved references in shared libs --allow-multiple-definition Allow multiple definitions --no-undefined-version Disallow undefined version --default-symver Create default symbol version --default-imported-symver Create default symbol version for imported symbols --no-warn-mismatch Don't warn about mismatched input files --no-warn-search-mismatch Don't warn on finding an incompatible library --no-whole-archive Turn off --whole-archive --noinhibit-exec Create an output file even if errors occur -nostdlib Only use library directories specified on the command line --oformat TARGET Specify target of output file --print-output-format Print default output format --print-sysroot Print current sysroot -qmagic Ignored for Linux compatibility --reduce-memory-overheads Reduce memory overheads, possibly taking much longer --relax Reduce code size by using target specific optimizations --no-relax Do not use relaxation techniques to reduce code size --retain-symbols-file FILE Keep only symbols listed in FILE -rpath PATH Set runtime shared library search path -rpath-link PATH Set link time shared library search path -shared, -Bshareable Create a shared library -pie, --pic-executable Create a position independent executable --sort-common [=ascending|descending] Sort common symbols by alignment [in specified order] --sort-section name|alignment Sort sections by name or maximum alignment --spare-dynamic-tags COUNT How many tags to reserve in .dynamic section --split-by-file [=SIZE] Split output sections every SIZE octets --split-by-reloc [=COUNT] Split output sections every COUNT relocs --stats Print memory usage statistics --target-help Display target specific options --task-link SYMBOL Do task level linking --traditional-format Use same format as native linker --section-start SECTION=ADDRESS Set address of named section -Tbss ADDRESS Set address of .bss section -Tdata ADDRESS Set address of .data section -Ttext ADDRESS Set address of .text section -Ttext-segment ADDRESS Set address of text segment -Trodata-segment ADDRESS Set address of rodata segment -Tldata-segment ADDRESS Set address of ldata segment --unresolved-symbols= How to handle unresolved symbols. is: ignore-all, report-all, ignore-in-object-files, ignore-in-shared-libs --verbose [=NUMBER] Output lots of information during link --version-script FILE Read version information script --version-exports-section SYMBOL Take export symbols list from .exports, using SYMBOL as the version. --dynamic-list-data Add data symbols to dynamic list --dynamic-list-cpp-new Use C++ operator new/delete dynamic list --dynamic-list-cpp-typeinfo Use C++ typeinfo dynamic list --dynamic-list FILE Read dynamic list --warn-common Warn about duplicate common symbols --warn-constructors Warn if global constructors/destructors are seen --warn-multiple-gp Warn if the multiple GP values are used --warn-once Warn only once per undefined symbol --warn-section-align Warn if start of section changes due to alignment --warn-shared-textrel Warn if shared object has DT_TEXTREL --warn-alternate-em Warn if an object has alternate ELF machine code --warn-unresolved-symbols Report unresolved symbols as warnings --error-unresolved-symbols Report unresolved symbols as errors --whole-archive Include all objects from following archives --wrap SYMBOL Use wrapper functions for SYMBOL --ignore-unresolved-symbol SYMBOL Unresolved SYMBOL will not cause an error or warning --push-state Push state of flags governing input file handling --pop-state Pop state of flags governing input file handling @FILE Read options from FILE
SergeyKostrov
MinGW v5.1.0 64-bit Options - Group 17 C:/WorkLib/MinGW/Bin/../lib/gcc/x86_64-w64-mingw32/5.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: supported targets: pe-x86-64 pei-x86-64 pe-bigobj-x86-64 elf64-x86-64 elf64-l1om elf64-k1om pe-i386 pei-i386 elf32-i386 elf64-little elf64-big elf32-little elf32-big plugin srec symbolsrec verilog tekhex binary ihex C:/WorkLib/MinGW/Bin/../lib/gcc/x86_64-w64-mingw32/5.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: supported emulations: i386pep i386pe C:/WorkLib/MinGW/Bin/../lib/gcc/x86_64-w64-mingw32/5.1.0/../../../../x86_64-w64-mingw32/bin/ld.exe: emulation specific options: i386pep: --base_file Generate a base file for relocatable DLLs --dll Set image base to the default for DLLs --file-alignment Set file alignment --heap Set initial size of the heap --image-base
Set start address of the executable --major-image-version Set version number of the executable --major-os-version Set minimum required OS version --major-subsystem-version Set minimum required OS subsystem version --minor-image-version Set revision number of the executable --minor-os-version Set minimum required OS revision --minor-subsystem-version Set minimum required OS subsystem revision --section-alignment Set section alignment --stack Set size of the initial stack --subsystem [:] Set required OS subsystem [& version] --support-old-code Support interworking with old code --[no-]leading-underscore Set explicit symbol underscore prefix mode --[no-]insert-timestamp Use a real timestamp rather than zero. (default) This makes binaries non-deterministic --add-stdcall-alias Export symbols with and without @nn --disable-stdcall-fixup Don't link _sym to _sym@nn --enable-stdcall-fixup Link _sym to _sym@nn without warnings --exclude-symbols sym,sym,... Exclude symbols from automatic export --exclude-all-symbols Exclude all symbols from automatic export --exclude-libs lib,lib,... Exclude libraries from automatic export --exclude-modules-for-implib mod,mod,... Exclude objects, archive members from auto export, place into import library instead. --export-all-symbols Automatically export all globals to DLL --kill-at Remove @nn from exported symbols --out-implib Generate import library --output-def Generate a .DEF file for the built DLL --warn-duplicate-exports Warn about duplicate exports. --compat-implib Create backward compatible import libs; create __imp_ as well. --enable-auto-image-base Automatically choose image base for DLLs unless user specifies one --disable-auto-image-base Do not auto-choose image base. (default) --dll-search-prefix= When linking dynamically to a dll without an importlib, use .dll in preference to lib.dll --enable-auto-import Do sophisticated linking of _sym to __imp_sym for DATA references --disable-auto-import Do not auto-import DATA items from DLLs --enable-runtime-pseudo-reloc Work around auto-import limitations by adding pseudo-relocations resolved at runtime. --disable-runtime-pseudo-reloc Do not add runtime pseudo-relocations for auto-imported DATA. --enable-extra-pep-debug Enable verbose debug output when building or linking to DLLs (esp. auto-import) --enable-long-section-names Use long COFF section names even in executable image files --disable-long-section-names Never use long COFF section names, even in object files --high-entropy-va Image is compatible with 64-bit address space layout randomization (ASLR) --dynamicbase Image base address may be relocated using address space layout randomization (ASLR) --forceinteg Code integrity checks are enforced --nxcompat Image is compatible with data execution prevention --no-isolation Image understands isolation but do not isolate the image --no-seh Image does not use SEH. No SE handler may be called in this image --no-bind Do not bind this image --wdmdriver Driver uses the WDM model --tsaware Image is Terminal Server aware --build-id[=STYLE] Generate build ID i386pe: --base_file Generate a base file for relocatable DLLs --dll Set image base to the default for DLLs --file-alignment Set file alignment --heap Set initial size of the heap --image-base
Set start address of the executable --major-image-version Set version number of the executable --major-os-version Set minimum required OS version --major-subsystem-version Set minimum required OS subsystem version --minor-image-version Set revision number of the executable --minor-os-version Set minimum required OS revision --minor-subsystem-version Set minimum required OS subsystem revision --section-alignment Set section alignment --stack Set size of the initial stack --subsystem [:] Set required OS subsystem [& version] --support-old-code Support interworking with old code --[no-]leading-underscore Set explicit symbol underscore prefix mode --thumb-entry= Set the entry point to be Thumb --[no-]insert-timestamp Use a real timestamp rather than zero (default). This makes binaries non-deterministic --add-stdcall-alias Export symbols with and without @nn --disable-stdcall-fixup Don't link _sym to _sym@nn --enable-stdcall-fixup Link _sym to _sym@nn without warnings --exclude-symbols sym,sym,... Exclude symbols from automatic export --exclude-all-symbols Exclude all symbols from automatic export --exclude-libs lib,lib,... Exclude libraries from automatic export --exclude-modules-for-implib mod,mod,... Exclude objects, archive members from auto export, place into import library instead. --export-all-symbols Automatically export all globals to DLL --kill-at Remove @nn from exported symbols --out-implib Generate import library --output-def Generate a .DEF file for the built DLL --warn-duplicate-exports Warn about duplicate exports --compat-implib Create backward compatible import libs; create __imp_ as well. --enable-auto-image-base[=
] Automatically choose image base for DLLs (optionally starting with address) unless specifically set with --image-base --disable-auto-image-base Do not auto-choose image base. (default) --dll-search-prefix= When linking dynamically to a dll without an importlib, use .dll in preference to lib.dll --enable-auto-import Do sophisticated linking of _sym to __imp_sym for DATA references --disable-auto-import Do not auto-import DATA items from DLLs --enable-runtime-pseudo-reloc Work around auto-import limitations by adding pseudo-relocations resolved at runtime. --disable-runtime-pseudo-reloc Do not add runtime pseudo-relocations for auto-imported DATA. --enable-extra-pe-debug Enable verbose debug output when building or linking to DLLs (esp. auto-import) --large-address-aware Executable supports virtual addresses greater than 2 gigabytes --disable-large-address-aware Executable does not support virtual addresses greater than 2 gigabytes --enable-long-section-names Use long COFF section names even in executable image files --disable-long-section-names Never use long COFF section names, even in object files --dynamicbase Image base address may be relocated using address space layout randomization (ASLR) --forceinteg Code integrity checks are enforced --nxcompat Image is compatible with data execution prevention --no-isolation Image understands isolation but do not isolate the image --no-seh Image does not use SEH. No SE handler may be called in this image --no-bind Do not bind this image --wdmdriver Driver uses the WDM model --tsaware Image is Terminal Server aware --build-id[=STYLE] Generate build ID Report bugs to <> For bug reporting instructions, please see: http://sourceforge.net/projects/mingw-w64
SergeyKostrov
Valued Contributor II
Command line options for MinGW C++ compiler version 6.1.0 will be posted soon.
SergeyKostrov
MinGW v6.1.0 32-bit Options - Group 1 Usage: g++.exe [options] file... Options: -pass-exit-codes Exit with highest error code from a phase. --help Display this information. --target-help Display target specific command line options. --help={common|optimizers|params|target|warnings|[^]{joined|separate|undocumented}}[,...]. Display specific types of command line options. --version Display compiler version information. -dumpspecs Display all of the built in spec strings. -dumpversion Display the version of the compiler. -dumpmachine Display the compiler's target processor. -print-search-dirs Display the directories in the compiler's search path. -print-libgcc-file-name Display the name of the compiler's companion library. -print-file-name= Display the full path to library . -print-prog-name= Display the full path to compiler component . -print-multiarch Display the target's normalized GNU triplet, used as a component in the library path. -print-multi-directory Display the root directory for versions of libgcc. -print-multi-lib Display the mapping between command line options and multiple library search directories. -print-multi-os-directory Display the relative path to OS libraries. -print-sysroot Display the target libraries directory. -print-sysroot-headers-suffix Display the sysroot suffix used to find headers. -Wa, Pass comma-separated on to the assembler. -Wp, Pass comma-separated on to the preprocessor. -Wl, Pass comma-separated on to the linker. -Xassembler Pass on to the assembler. -Xpreprocessor Pass on to the preprocessor. -Xlinker Pass on to the linker. -save-temps Do not delete intermediate files. -save-temps= Do not delete intermediate files. -no-canonical-prefixes Do not canonicalize paths when building relative prefixes to other gcc components. -pipe Use pipes rather than intermediate files. -time Time the execution of each subprocess. -specs= Override built-in specs with the contents of . -std= Assume that the input sources are for . --sysroot= Use as the root directory for headers and libraries. -B Add to the compiler's search paths. -v Display the programs invoked by the compiler. -### Like -v but options quoted and commands not executed. -E Preprocess only; do not compile, assemble or link. -S Compile only; do not assemble or link. -c Compile and assemble, but do not link. -o Place the output into . -pie Create a position independent executable. -shared Create a shared library. -x Specify the language of the following input files. Permissible languages include: c c++ assembler none 'none' means revert to the default behavior of guessing the language based on the file's extension. Options starting with -g, -f, -m, -O, -W, or --param are automatically passed on to the various sub-processes invoked by g++.exe. In order to pass other options on to these processes the -W options must be used. The following options are specific to just the language Ada: -fbuiltin-printf Ignored. The following options are specific to just the language AdaSCIL: None found. Use --help=AdaSCIL to show *all* the options supported by the AdaSCIL front-end. The following options are specific to just the language AdaWhy: None found. Use --help=AdaWhy to show *all* the options supported by the AdaWhy front-end. The following options are specific to just the language C: -lang-asm This option lacks documentation. The following options are specific to just the language C++: -Wplacement-new Warn for placement new expressions with undefined behavior. Same as -Wplacement-new=. -Wplacement-new= Warn for placement new expressions with undefined behavior.
SergeyKostrov
MinGW v6.1.0 32-bit Options - Group 2 The following options are specific to just the language Fortran: -J Put MODULE files in 'directory'. -Waliasing Warn about possible aliasing of dummy arguments. -Walign-commons Warn about alignment of COMMON blocks. -Wampersand Warn about missing ampersand in continued character constants. -Warray-temporaries Warn about creation of array temporaries. -Wc-binding-type Warn if the type of a variable might be not interoperable with C. -Wcharacter-truncation Warn about truncated character expressions. -Wcompare-reals Warn about equality comparisons involving REAL or COMPLEX expressions. -Wconversion-extra Warn about most implicit conversions. -Wextra Print extra (possibly unwanted) warnings. -Wfunction-elimination Warn about function call elimination. -Wimplicit-interface Warn about calls with implicit interface. -Wimplicit-procedure Warn about called procedures not explicitly declared. -Winteger-division Warn about constant integer divisions with truncated results. -Wintrinsic-shadow Warn if a user-procedure has the same name as an intrinsic. -Wintrinsics-std Warn on intrinsics not part of the selected standard. -Wline-truncation Warn about truncated source lines. -Wreal-q-constant Warn about real-literal-constants with 'q' exponent-letter. -Wrealloc-lhs Warn when a left-hand-side array variable is reallocated. -Wrealloc-lhs-all Warn when a left-hand-side variable is reallocated. -Wsurprising Warn about "suspicious" constructs. -Wtabs Permit nonconforming uses of the tab character. -Wtarget-lifetime Warn if the pointer in a pointer assignment might outlive its target. -Wunderflow Warn about underflow of numerical constant expressions. -Wunused-dummy-argument Warn about unused dummy arguments. -Wuse-without-only Warn about USE statements that have no ONLY qualifier. -Wzerotrip Warn about zero-trip DO loops. -cpp Enable preprocessing. -cpp= This option lacks documentation. -faggressive-function-elimination Eliminate multiple function invokations also for impure functions. -falign-commons Enable alignment of COMMON blocks. -fall-intrinsics All intrinsics procedures are available regardless of selected standard. -fallow-leading-underscore This option lacks documentation. -fautomatic Do not treat local variables and COMMON blocks as if they were named in SAVE statements. -fbackslash Specify that backslash in string introduces an escape character. -fbacktrace Produce a backtrace when a runtime error is encountered. -fblas-matmul-limit= Size of the smallest matrix for which matmul will use BLAS. -fcheck-array-temporaries Produce a warning at runtime if a array temporary has been created for a procedure argument. -fcheck=[...] Specify which runtime checks are to be performed. -fcoarray= Specify which coarray parallelization should be used. -fconvert= -fconvert= The endianness used for unformatted files. -fcray-pointer Use the Cray Pointer extension. -fd-lines-as-code Ignore 'D' in column one in fixed form. -fd-lines-as-comments Treat lines with 'D' in column one as comments. -fdefault-double-8 Set the default double precision kind to an 8 byte wide type. -fdefault-integer-8 Set the default integer kind to an 8 byte wide type. -fdefault-real-8 Set the default real kind to an 8 byte wide type. -fdollar-ok Allow dollar signs in entity names. -fdump-core Does nothing. Preserved for backward compatibility. -fdump-fortran-optimized Display the code tree after front end optimization. -fdump-fortran-original Display the code tree after parsing. -fdump-parse-tree Display the code tree after parsing; deprecated option. Same as -fdump-fortran-original. -fexternal-blas Specify that an external BLAS library should be used for matmul calls on large-size arrays. -ff2c Use f2c calling convention. -ffixed-form Assume that the source file is fixed form. -ffixed-line-length- Use n as character line width in fixed mode. -ffixed-line-length-none Allow arbitrary character line width in fixed mode. -ffpe-summary=[...] Print summary of floating point exceptions. -ffpe-trap=[...] Stop on following floating point exceptions. -ffree-form Assume that the source file is free form. -ffree-line-length- Use n as character line width in free mode. -ffree-line-length-none Allow arbitrary character line width in free mode. -ffrontend-optimize Enable front end optimization. -fimplicit-none Specify that no implicit typing is allowed, unless overridden by explicit IMPLICIT statements. -finit-character= Initialize local character variables to ASCII value n. -finit-integer= Initialize local integer variables to n. -finit-local-zero Initialize local variables to zero (from g77). -finit-logical= Initialize local logical variables. -finit-real= Initialize local real variables. -finline-matmul-limit= Specify the size of the largest matrix for which matmul will be inlined. -finteger-4-integer-8 Interpret any INTEGER(4) as an INTEGER(8). -fintrinsic-modules-path Specify where to find the compiled intrinsic modules. -fintrinsic-modules-path= Specify where to find the compiled intrinsic modules. -fmax-array-constructor= Maximum number of objects in an array constructor. -fmax-identifier-length= Maximum identifier length. -fmax-stack-var-size= Size in bytes of the largest array that will be put on the stack. -fmax-subrecord-length= Maximum length for subrecords. -fmodule-private Set default accessibility of module entities to PRIVATE. -fpack-derived Try to lay out derived types as compactly as possible. -fprotect-parens Protect parentheses in expressions. -frange-check Enable range checking during compilation. -freal-4-real-10 Interpret any REAL(4) as a REAL(10). -freal-4-real-16 Interpret any REAL(4) as a REAL(16). -freal-4-real-8 Interpret any REAL(4) as a REAL(8). -freal-8-real-10 Interpret any REAL(8) as a REAL(10). -freal-8-real-16 Interpret any REAL(8) as a REAL(16). -freal-8-real-4 Interpret any REAL(8) as a REAL(4). -frealloc-lhs Reallocate the LHS in assignments. -frecord-marker=4 Use a 4-byte record marker for unformatted files. -frecord-marker=8 Use an 8-byte record marker for unformatted files. -frecursive Allocate local variables on the stack to allow indirect recursion. -frepack-arrays Copy array sections into a contiguous block on procedure entry. -fsecond-underscore Append a second underscore if the name already contains an underscore. -fsign-zero Apply negative sign to zero values. -fstack-arrays Put all local arrays on stack. -funderscoring Append underscores to externally visible names. -fwhole-file Does nothing. Preserved for backward compatibility. -nocpp Disable preprocessing. -static-libgfortran Statically link the GNU Fortran helper library (libgfortran). -std=f2003 Conform to the ISO Fortran 2003 standard. -std=f2008 Conform to the ISO Fortran 2008 standard. -std=f2008ts Conform to the ISO Fortran 2008 standard including TS 29113. -std=f95 Conform to the ISO Fortran 95 standard. -std=gnu Conform to nothing in particular. -std=legacy Accept extensions to support legacy code.
SergeyKostrov
MinGW v6.1.0 32-bit Options - Group 3 The following options are specific to just the language Go: -L This option lacks documentation. -fgo-check-divide-overflow Add explicit checks for division overflow in INT_MIN / -1. -fgo-check-divide-zero Add explicit checks for division by zero. -fgo-dump- Dump Go frontend internal information. -fgo-optimize- Turn on optimization passes in the frontend. -fgo-pkgpath= Set Go package path. -fgo-prefix= Set package-specific prefix for exported Go names. -fgo-relative-import-path= -fgo-relative-import-path= Treat a relative import as relative to path. -frequire-return-statement Functions which return values must end with return statements.
