Software Archive
Read-only legacy content
17061 讨论
Example project work, then freeze after a few seconds
Shane_M_
初学者
1,149 次查看
Hi All,
Thanks for taking the time to read my post. I recently received my Realsense developer kit. Everything installs fine and my camera is detected but  I haven't had any success in running any of the examples.  When I open  an example (e.g. facetracking), I can see the camera feed and all the lights go on, but then the app freezes and does not update the camera feed view.   All the buttons in the app become non responsive and I have to force-quit to close it.
I am running windows 8.1,  on an intel -7-4700MQ CPU.
If anyone could shed some light on how to resolve thi  I would be greatly appreciative
0 项奖励
9 回复数
Vidyasagar_MSC
创新者
1,149 次查看
How is the CPU and memory usage? Can you just check your RealSense related processes on the task manager??
0 项奖励
Brendan_P_
初学者
1,149 次查看
I am experiencing the exact same issue. I also have the same specs as OP.
0 项奖励
samontab
重要分销商 II
1,149 次查看
SDK version?
If it is R2, did you install both drivers?
0 项奖励
samontab
重要分销商 II
1,149 次查看
Also, try using an external powered usb hub
0 项奖励
Vidyasagar_MSC
创新者
1,149 次查看
Also,Run all the pending Windows OS updates if any.
0 项奖励
Brendan_P_
初学者
1,149 次查看
I'm running R2 and I've installed both drivers. Windows is also up to date.
The Capture Viewer runs fine but opening any of the example projects causes the crash mentioned above. When I try to run any of the Unity example projects from the editor, I get the following error:
Unable to initialize all modalities
UnityEngine.MonoBehaviour:print(Object)
RSUnityToolkit.SenseToolkitManager:OnEnable() (at Assets/RSUnityToolkit/Internals/RealSenseInput/SenseToolkitManager.cs:283)
RSUnityToolkit.SenseToolkitManager:Update() (at Assets/RSUnityToolkit/Internals/RealSenseInput/SenseToolkitManager.cs:478)
Is it just a power draw issue? I'll have to go but a powered USB 3.0 hub to test this out, and I'll report back. But if anyone has another solution you can save me a bit of time and money.
Thanks!
0 项奖励
Poh_Kit_C_
初学者
1,149 次查看
I'm having similar issues and I think its a hardware problem.
I purchased 2 cameras. One is working perfectly on the 2 systems I tested it on running windows 8.1 and 8GB of RAM.
The other camera slows down and crashes after a few seconds. The camera lights then go on and off intermittently.
Does the powered USB hub solve this problem?
Anyway to get a replacement camera?
0 项奖励
samontab
重要分销商 II
1,149 次查看
It may be the cable itself. I remember reading somewhere that some units had defective cables...
I also have noticed that when using more than one camera, the system does not work well. Try using different USB ports, disconnecting and connecting it again, and rebooting the computer.
If the error persists, it probably is hardware related...
The powered USB hub could solve the issue if that particular unit needs more power, but it may be another thing...
0 项奖励
Poh_Kit_C_
初学者
1,149 次查看
Still freezes and turns off with the powered hub.
Any way to get a replacement unit?
Contacted click and they directed me here.
0 项奖励
回复
