Software Archive
Read-only legacy content
17060 Discussions
Execution failed for task ':mergeArmv7ReleaseResources'.
rezki_a_
Executing task ':mergeArmv7ReleaseResources' (up-to-date check took 0.015 secs) due to:
  No history is available.
All input files are considered out-of-date for incremental task ':mergeArmv7ReleaseResources'.
Unable do incremental execution: full task run
QueuedCruncher is using .../android-sdk/build-tools/25.0.0/aapt
AAPT err(Facade for 1867754352) : No Delegate set : lost message:libpng error: Not a PNG file
:mergeArmv7ReleaseResources FAILED
:mergeArmv7ReleaseResources (Thread[main,5,main]) completed. Took 0.539 secs.
FAILURE: Build failed with an exception.
* What went wrong:
> Some file crunching failed, see logs for details
* Try:
Run with --stacktrace option to get the stack trace. Run with --debug option to get more log output.
BUILD FAILED
Total time: 26.068 secs
Stopped 0 compiler daemon(s).
Error: Error code 1 for command: .../cordova_project/platforms/android/gradlew with args: cdvBuildRelease,-b,.../cordova_project/platforms/android/build.gradle,--no-daemon,-Pandroid.useDeprecatedNdk=true,--info
PaulF_IntelCorp
Please use your other thread > https://software.intel.com/en-us/forums/intel-xdk/topic/707312 < I'm closing this one.
