Software Archive
Read-only legacy content
F200 IR and Depth streams not working
Elad_P_
Hello.
Using the SDK samples, I can see the RGB streams but not the IR and Depth streams. I get Init failed on those.
I have tried uninstalling and reinstalling the SDK and DCM.
I tried both USB 3.0 ports on the back panel.
I'm attaching a bunch of support files I think may assist such as the SDK info (the PC2 file), and logs I managed to activate from the SDM management utilities.
V4 of the SDK on a Win10 64.
CPU: i3-4170
Board: Asus H81M-A
Bios: 2105 x64
Elad
Ariska_Hidayat
If my experience when I use windows 10 the first time. I also experienced the same problem. I am also confused what to do. Then I uninstall the old version and some apps related to realsense. Then install again DCM and SDK. Restart and then update windows. After that realsense camera can work well. thx
Xusheng_L_Intel
We are investigating this issue and will keep you post when we find root cause. Thanks!
Elad_P_
Hi David,
Is there any update on this?
Can it be a hardware issue with the F200?
joab_s_
I've got the same problem ,
I didn't find the solution yet,
 but my guess is maybe the device (camera) is not getting enough power, because I tried on my notebook that has 4 RAM, CORE 3 4th and it didn't work, then I tried on another notebook more new than my notebook that has 16 RAM , CORE 7 and it worked.
Elad_P_
Thanks Joab.
Can you say what is the make and model of the notebook it did work on?
