Software Archive
Read-only legacy content
17060 Discussions
F200 USB 3 Cable expansion
ali_a_3
i need a long cable for my application, so i use the USB 3.0 cable extension (1.8m) unfortunately the F200 sensor stops from working?
what is the method to extend the cable length?
samontab
Valued Contributor II
Try different cables from different makers. Some might work.
ali_a_3
i try with many cables manufactures. unfortunately i cant find a solution
Please i need some help
mugabi__samuel
the longer the cable, the less the quality of signal output (signal attenuation)
You could probably consult intel to see if they sell any longer cables for your camera. (Special Order)
