Software Archive
Read-only legacy content
17061 Discussions
F200 stuck 15fps in colour stream
serin_j_
Had to flash my windows install to deal with a Maya problem - am now faced with a problem wherein my brand new F200 won't go past 15fps in the SDK's capture viewer or in Faceshift(the program I bought the sensor for)
It does start off around 19fps but then drops back to 15 and stays there. The same can be said for faceshifts fps counter.
Is there a setting somewhere I'm missing or has it derped itself?
Any help would be much appreciated.
For reference my pc is as follows:
5960X
Titan X
Sabertooth x99
32gb ram @ 2400mhz.
And SATA ssd's for storage
samontab
Valued Contributor II
Maybe it has auto exposure on. Point to something well lit, e.g. outside at daytime, it should work faster if that's the case.
You should be able to change exposure time through the SDK, this value will change the fps until you get to the max.
