Software Archive
Read-only legacy content
17060 Discussions
F7 Card HEIGHT problem in XDK 3400 (BUG)
Andrejs_V_
If I use f7card in my project and  I put  on form ( in any window of project) card, card-column, card-grid widget that f7card loose height for header & footer too.
Removing  card, card-column, card-grid widget don't correct a problem.
And as I see in folder /css/index remain uib-card.less file that don't need in project but I can't remove this file from project.
Elroy_A_Intel
I have escalated this to the App Designer team to look into your issue.
Brian_W_Intel
Are you placing the Framework 7 card inside the other card, or are they just on the same page with one another?
Also, is this a new project or an existing one?
Andrejs_V_
I can reproduce it in new or existing project.
You can add f7card in one page and add simple card in another page - and You get this .
You can remove simple card , but effect still on in project/ And for new f7card also, If You remove all f7card frm project and then add again f7card. And this problem will exist;
And I added f7card simply on page,  also I was added in row wizard . anyway after adding card or card columns I got a bug.
Brian_W_Intel
Can you upload a project where this bug occurs? We can't seem to reproduce it over here.
Andrejs_V_
Project in attach
Main project's windows look also in second attach
