Software Archive
Read-only legacy content
17060 Discussions
Facebook signature key generation
Karl_J_
Few weeks ago I tried to generate facebook app signature key but nothing happened.
I wonder if this issue has been fixed?
Thanks in advance
Brandon_K_Intel
How did you attempt to generate the app signature for your application?
Karl_J_
I had this facebook App ID and I pasted it into build section. As much as I understood, Intel XDK was supposed to generate key from it, but it didnt
Karl_J_
I also followed this tutorial https://software.intel.com/en-us/html5/articles/integrating-facebook-functionality-into-hybrid-apps-using-the-intel-xdk
but when I started setting it up and when I reached the point where I have to copy facebook app ID to credentials part, then no key was generated by Intel XDK. Plz help
Brandon_K_Intel
The key hashes are inside of the android keystore that is used to sign your application. Will you please send an email to html5tools@intel.com to retrieve the key that is needed to finish initializing your application?
Amrita_C_Intel
The Facebook plugin you are referencing is the deprecated one. please use this updated one.
https://github.com/Wizcorp/phonegap-facebook-plugin
