Software Archive
Read-only legacy content
17060 Discussions
galileo gen 2 connecting to wifi network
leo1234
hi guys
i want to connect my galileo gen 2 with wifi network. and i used intel N-6025 wireless card. what should i do??
ps: in the putty, i can not use the command "connmanctl".  and  i put the "intel linux for sd card-image" in my sd card. should i put iot devkit image
into sd card and remove linux image?
regards
leo
Matthias_H_Intel
probably you are referring to 6205 rather than 6025 as I'm not aware of N-6025?
According to http://www.intel.com/support/wireless/wlan/sb/CS-034398.htm it should be supported with iwlwifi for quite a while. Not sure whether your Linux image would support. Check "modinfo iwlwifi" "modprobe iwlwifi".
The Intel(R) IoT developer kit SD card image supports this card - I think I saw it running with this card already
leo1234
i am sorry . i typed wrong.  i used 6205. and should i remove the linux for sd card and put iot devkit in my sd card?
for 6205,  should i download iwlwifi for it ?
NagaVenkat_K_Intel
You can create a bootable SD card using this link and try testing your card following the instructions from https://software.intel.com/en-us/node/519953
Stewart_C_Intel
For any Linux, including our Yocto version, the firmware for a particular wifi card is stored in a specific location, typically  /lib/firmware. If ypu check that directory you will see what cards are already supported. Its a simple matter to add support for a new card by adding the new firmware to that directory. This firmware is a binary image that is independent of the host OS, ie the same firmware is loaded whether the card is installed in Galileo board, or in a laptop running windows. Most wifi cards are in fact built using an embedded ARM processor.
More info can be found at https://wireless.wiki.kernel.org/en/users/Drivers/iwlwifi including the latest firmware images.
In addition to the firmware you do need a "front end"  that allows you to specify SSID, and other features. For Galileo we have included connman as part of the IOTdevkit SD image.
