Software Archive
Read-only legacy content
iOs statusbar
Alessandro_S_
I have a problem on my iPhone 4/iPhone5 cordova build: the status bar is in front of the app with transparency (see attachment)
The correct behaviour would be: status bar fully visible and below the app (like in android). I've downloaded org.apache.cordova.statusbar plugin but I don't understand how to configure it to reach my goal.
Can You help me?
John_H_Intel2
From the docs for the plugin, it looks like you can use this:
StatusBar.overlaysWebView(true);  // or false
Alessandro_S_
thank you for the reply. I'll try. No other solution?
Alessandro_S_
Ok it works! but still a problem! when I click on header of my app and I drag down the app shifts to down and bounce again to the top. What's happening? Should I use some check while building or some setting in my index.htm?
