Software Archive
Read-only legacy content
Failed to fetch url
Szymon_P_
My code is:
intel.xdk.device.getRemoteData(app.url + 'some/url',"POST","some=data","success","error");
It works great in emulate tab, but if I build crosswalk for android or just android it doesnt work.
I've tried export app to chrome and check it console. This is what i get:
Uncaught ReferenceError: intel is not defined
Legacy hybrid mobile app build -> Android make a build with this works, but resolution is too high and I cant see anything except a data is downloaded from external server successfully.
EDIT
I've fixed this js error by changing
$(function(){
myFetchFunc();
to:
document.addEventListener("intel.xdk.device.ready",function(){
 myFetchFunc();
},false);
But fetching data from url is still broken in build. Works great in emulating and usb debug...
Szymon_P_
After few hours of debugging
I have made AWFUL hack but it works
font-size: 50px !important;
With legacy android build
This is app only for my own use, so I could do that, because it doesn't look well now.
The same code but builded with crosswalk doesn't work.
Szymon_P_
Pamela_H_Intel
Szymon,
Perhaps you have not specified a needed plugin for the build (core plugins are automatically included in the emulator and Debug features, but not in builds). See forum thread 561120.
Pamela
PaulF_IntelCorp
I'm guessing that you might be getting hit by the white list (domain access) gremlin -- see the white list doc on this page: https://software.intel.com/en-us/xdk/docs/xdk-doc-quick-links
Szymon_P_
Thanks, I have created new rule:
http://* + external
It didn't work.
Pamela_H_Intel
Szymon,
You do want to use the Crosswalk for Android build. Your app does work with Crosswalk - that is what USB debug uses. Perhaps there is an App Version Code issue. Try uninstalling the app from your device and then install the Crosswalk build.
Hamilton_Tenório_da_
Valued Contributor I
If you have included JQuery, you can use something like that:
    $.ajax({
        type: "POST",
        url: "http://xxxxxxxxxxxxxxxxxxxxxxxx",
        data: wpost,
        success: function(retorno) {funFuncao(retorno);},
        dataType: 'json'
I used this with Cordova Android/iOS
